tensa:
i was able to implement the filter thanks for this guide it was really helpful...thank you very much
but i dont know how to relate these values to motor's rpm of a quadcopter so i will stabilize, can anybody post links to guides like this?
You will need to use a PID controller to give roll,pitch,yaw outputs when the orientation deviates from 0,0,0. However, I have used these filters on a quadcopter and they suffer from the problem of linear acceleration affecting the pitch and roll. The filters are fast enough, smooth and very stable (calculation time was 80micros for twin Kalmans on an Arduino Due) but you'd probably be better off using Mahonys DCM or Madgwicks filter - they're less sensitive to linear acceleration but a bit more prone to noise (vibration from the motors).
You'll find plenty of links via Google for any of this stuff.
system
February 18, 2013, 5:12pm
398
i want to work with MPU-6050-Triple Axis Accelerometer Gyro can it be done
system
February 18, 2013, 5:30pm
399
i want the same guide for MPU-6050-Triple Axis Accelerometer Gyro
system
February 20, 2013, 12:52pm
400
the same think , so my ,i'd like this idea and i would like someone to share us the GUIDE of IMU 6050 and arduino
Lauszus
February 20, 2013, 1:44pm
401
The setup is very similar just note that if you are using an Arduino running at 5V you might damage the IMU as it's only running at 3.3V, but some breakout boards have a logic level circuit built-in. If not use have to use a logic level converter like this one: https://www.sparkfun.com/products/8745 .
To connect the Arduino with the MPU-6050, you need to connect it as it says in the following comment: https://www.sparkfun.com/products/11028#comment-50b3c165ce395f484d000000 .
Hopes this helps you out for now, as I havn't got time to write a guide at the moment.
Regards
Lauszus
system
March 13, 2013, 5:48pm
402
Hi Lauszus,
I make a little customisation of your source for digital IMUs so it can work with Minimu-9 board , hope you don't mind.But there is something wrong here is what i get:
....(the board is on the ground and i don't touch it the whole time)
X: 180.00 Y: 180.01
X: 180.05 Y: 180.06
X: 180.22 Y: 180.14
X: 180.51 Y: 180.16
X: 180.82 Y: 180.11
X: 181.07 Y: 180.04
X: 181.42 Y: 179.92
X: 181.79 Y: 179.80
X: 182.22 Y: 179.65
X: 182.72 Y: 179.46
X: 183.23 Y: 179.28
X: 183.85 Y: 179.08
X: 184.54 Y: 178.80
X: 185.26 Y: 178.48
X: 185.99 Y: 178.02
X: 186.60 Y: 177.45
X: 187.54 Y: 176.95
X: 188.54 Y: 176.43
X: 189.64 Y: 175.72
X: 190.82 Y: 175.03
X: 192.13 Y: 174.37
X: 280.48 Y: 86.86
X: 280.43 Y: 86.66
X: 280.32 Y: 86.91
X: 280.19 Y: 87.02
X: 280.09 Y: 87.10
X: 279.97 Y: 87.32
X: 279.81 Y: 87.84
X: 279.71 Y: 87.88
X: 279.60 Y: 88.26
X: 279.51 Y: 88.09
X: 279.38 Y: 88.20
X: 279.27 Y: 88.09
X: 279.10 Y: 88.24
X: 278.96 Y: 88.26
X: 278.80 Y: 88.56
...(finally the X stopped growing and the Y stopped getting lower)
X: 278.61 Y: 89.11
X: 278.44 Y: 89.23
X: 278.29 Y: 89.41
X: 278.25 Y: 88.81
X: 278.07 Y: 89.24
X: 277.85 Y: 89.62
X: 277.68 Y: 89.88
X: 277.53 Y: 90.03
X: 277.36 Y: 90.22
X: 277.24 Y: 90.48
X: 277.12 Y: 90.17
X: 276.99 Y: 90.08
X: 276.90 Y: 89.87
X: 276.76 Y: 89.84
X: 276.61 Y: 89.97
X: 276.44 Y: 90.35
X: 276.26 Y: 90.62
X: 276.12 Y: 90.84
X: 276.02 Y: 90.76
X: 275.78 Y: 91.38
X: 275.67 Y: 91.39
X: 275.47 Y: 91.74
X: 275.32 Y: 91.92
X: 275.16 Y: 92.18
X: 275.07 Y: 92.02
X: 274.95 Y: 92.17
X: 274.83 Y: 92.30
X: 274.68 Y: 92.31
X: 274.52 Y: 92.53
X: 274.43 Y: 92.53
X: 274.27 Y: 92.90
X: 274.18 Y: 92.90
X: 274.03 Y: 92.95
..(and all over again)
and here is my source
#include <Wire.h>
#include <L3G.h>
#include <LSM303.h>
L3G gyro;
LSM303 compass;
double zeroValue[5] = {-200, 44, 660, -18.5, 52.3}; // Found by experimenting
/* All the angles start at 180 degrees */
double gyroXangle = 180;
double gyroYangle = 180;
double compAngleX = 180;
double compAngleY = 180;
unsigned long timer;
/* Kalman filter variables and constants */
const double Q_angleX = 0.001; // Process noise covariance for the accelerometer - Sw
const double Q_gyroX = 0.003; // Process noise covariance for the gyro - Sw
const double R_angleX = 0.03; // Measurement noise covariance - Sv
double angleX = 180; // The angle output from the Kalman filter
double biasX = 0; // The gyro bias calculated by the Kalman filter
double PX_00 = 0, PX_01 = 0, PX_10 = 0, PX_11 = 0;
double dtX, yX, SX;
double KX_0, KX_1;
double kalmanX(double newAngle, double newRate, double dtime) {
// KasBot V2 - Kalman filter module - http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1284738418
// See also http://www.x-firm.com/?page_id=145
// with slightly modifications by Kristian Lauszus
// See http://academic.csuohio.edu/simond/courses/eec644/kalman.pdf and
// http://www.cs.unc.edu/~welch/media/pdf/kalman_intro.pdf for more information
dtX = dtime / 1000000; // Convert from microseconds to seconds
// Discrete Kalman filter time update equations - Time Update ("Predict")
// Update xhat - Project the state ahead
angleX += dtX * (newRate - biasX);
// Update estimation error covariance - Project the error covariance ahead
PX_00 += -dtX * (PX_10 + PX_01) + Q_angleX * dtX;
PX_01 += -dtX * PX_11;
PX_10 += -dtX * PX_11;
PX_11 += +Q_gyroX * dtX;
// Discrete Kalman filter measurement update equations - Measurement Update ("Correct")
// Calculate Kalman gain - Compute the Kalman gain
SX = PX_00 + R_angleX;
KX_0 = PX_00 / SX;
KX_1 = PX_10 / SX;
// Calculate angle and resting rate - Update estimate with measurement zk
yX = newAngle - angleX;
angleX += KX_0 * yX;
biasX += KX_1 * yX;
// Calculate estimation error covariance - Update the error covariance
PX_00 -= KX_0 * PX_00;
PX_01 -= KX_0 * PX_01;
PX_10 -= KX_1 * PX_00;
PX_11 -= KX_1 * PX_01;
return angleX;
const double Q_angleY = 0.001; // Process noise covariance for the accelerometer - Sw
const double Q_gyroY = 0.003; // Process noise covariance for the gyro - Sw
const double R_angleY = 0.03; // Measurement noise covariance - Sv
double angleY = 180; // The angle output from the Kalman filter
double biasY = 0; // The gyro bias calculated by the Kalman filter
double PY_00 = 0, PY_01 = 0, PY_10 = 0, PY_11 = 0;
double dtY, yY, SY;
double KY_0, KY_1;
double kalmanY(double newAngle, double newRate, double dtime) {
dtY = dtime / 1000000; // Convert from microseconds to seconds
angleY += dtY * (newRate - biasY);
PY_00 += -dtY * (PY_10 + PY_01) + Q_angleY * dtY;
PY_01 += -dtY * PY_11;
PY_10 += -dtY * PY_11;
PY_11 += +Q_gyroY * dtY;
SY = PY_00 + R_angleY;
KY_0 = PY_00 / SY;
KY_1 = PY_10 / SY;
yY = newAngle - angleY;
angleY += KY_0 * yY;
biasY += KY_1 * yY;
PY_00 -= KY_0 * PY_00;
PY_01 -= KY_0 * PY_01;
PY_10 -= KY_1 * PY_00;
PY_11 -= KY_1 * PY_01;
return angleY;
int readGyroX(void) {
int data;
data =gyro.g.x;
return data;
int readGyroY(void) {
int data;
data = gyro.g.y;
return data;
double getXangle() {
double accXval = (double)readAccX()-zeroValue[0];
double accZval = (double)readAccZ()-zeroValue[2];
double angle = (atan2(accXval,accZval)+PI)*RAD_TO_DEG;
return angle;
double getYangle() {
double accYval = (double)readAccY()-zeroValue[1];
double angle = (atan2(accYval,accZval)+PI)*RAD_TO_DEG;
return angle;
int readAccX(void) {
int data;
data = compass.a.x;
return data;
int readAccY(void) {
int data;
data = compass.a.y;
return data;
int readAccZ(void) {
int data;
data =compass.a.z;
return data;
Wire.begin();
if (!gyro.init())
Serial.println("Failed to autodetect gyro type!");
while (1);
gyro.enableDefault();
compass.init();
compass.enableDefault();
timer = micros();
gyro.read();
compass.read();
double gyroXrate = (((double)readGyroX()-zeroValue[3])/14.375);
gyroXangle += gyroXrate*((double)(micros()-timer)/1000000); // Without any filter
double gyroYrate = -(((double)readGyroY()-zeroValue[4])/14.375);
gyroYangle += gyroYrate*((double)(micros()-timer)/1000000); // Without any filter
double accXangle = getXangle();
double accYangle = getYangle();
compAngleX = (0.93*(compAngleX+(gyroXrate*(double)(micros()-timer)/1000000)))+(0.07*accXangle);
compAngleY = (0.93*(compAngleY+(gyroYrate*(double)(micros()-timer)/1000000)))+(0.07*accYangle);
double xAngle = kalmanX(accXangle, gyroXrate, (double)(micros() - timer)); // calculate the angle using a Kalman filter
double yAngle = kalmanY(accYangle, gyroYrate, (double)(micros() - timer)); // calculate the angle using a Kalman filter
timer = micros();
Serial.print("X: ");Serial.print(xAngle);Serial.print("\t");
Serial.print("Y: ");Serial.print(yAngle);Serial.print("\t");
Serial.print("\n");
delay(10);
Could you please take a look of my source and tell me what I am doing wrong.I want to thank you in advance for your time.
Stanislav.
Lauszus
March 13, 2013, 11:42pm
403
system
March 14, 2013, 9:31am
404
Lauszus:
@stunito0o0
It looks like you are reading the magnetometer (compass) and not the accelerometer.
Btw the newest version of the code can be found here: GitHub - TKJElectronics/KalmanFilter: This is a Kalman filter used to calculate the angle, rate and bias from from the input of an accelerometer/magnetometer and a gyroscope. .
Hi again,
I thought too that it might be the compass data I am reading so i opened the example for the "LSM303.h" libraly and here is the source:
#include <Wire.h>
#include <LSM303.h>
LSM303 compass;
Wire.begin();
compass.init();
compass.read();
Serial.print("A ");
Serial.print((int)compass.a.x);
Serial.print(" Y: ");
Serial.print((int)compass.a.y);
Serial.print(" Z: ");
Serial.print((int)compass.a.z);
Serial.print(" M ");
Serial.print((int)compass.m.x);
Serial.print((int)compass.m.y);
Serial.println((int)compass.m.z);
delay(100);
According to the example "compass.a.x","compass.a.y" and "compass.a.z" are for reading the acc data.I will really appreciate if you take another look of my code.I think that when i was customising your source i might have deleted something important.Thank you again for your time.
P.S. Now i rememberd that i deleted part of the source for getting the data of acc and gyro.For example "readAccX" function was something like this:
int data;
data = i2cRead(adxlAddress, 0x32);
data |= i2cRead(adxlAddress,0x33)<<8;
return data;
and i didn't understand what "data |= i2cRead(adxlAddress,0x33)<<8;" is for so i deleted it.
now it looks like this:
int data;
data = compass.a.x;
return data;
Lauszus
March 15, 2013, 11:19pm
405
Sorry I was in a hurry when I wrote the first reply.
First of all I think it will be easier for you to if you modify this example: https://github.com/pololu/LSM303/blob/master/LSM303/examples/Serial/Serial.ino to your needs.
First of all you should NOT subtract the zeroValues, as they are specific for the IMU used in the example.
I think you can use your values directly, so you don't even have to subtract any zeroValue.
Take a look at this example: https://github.com/TKJElectronics/Example-Sketch-for-IMU-including-Kalman-filter/blob/master/IMU6DOF/MPU6050/MPU6050.ino
Also you assume that the gyro has the same sensitivity as the one used in the example which is most likely not the case (take a look at your datasheet)!
system
March 15, 2013, 11:39pm
406
Lauszus
March 15, 2013, 11:44pm
407
No problem. I'm just glad you got it working
system
March 16, 2013, 8:10pm
408
Hey Lauszus!
I was hoping to learn something about using IMU effectively with the help of Kalman filtering as I came across this wonderful tutorial. The only problem I have is I have 2 separate gyro and accelerometer modules (L3G4200D and ADXL 335). How do I combine and use them according to your pin config.
gyro has pins GND, VIN, SCL, SDA, SDD, INT1, INT2 and accelerometer pins are VCC, GND,X,Y,Z,ST. Where do these pins go?
Thanks!
@psyoptica
The gyroscope is a digital gyroscope so you need to connect it to the SDA and SCL on the Arduino. See the following page for more information: Wire - Arduino Reference . Then connect VIN to 3.3V and GND to GND on the Arduino.
Your accelerometer is a analog one, so you need to connect X, Y, and Z to your analog inputs. And yet again connect VIN to 3.3V and GND to GND on the Arduino.
system
March 16, 2013, 8:31pm
410
Thanks! this really helps but aren't A4 and A5 analog input pins?
@psyoptica
Yes they are, but pins can have several capabilities.
For instance you can also use any analog pin as a digital pin like so:
pinMode(A0,OUTPUT);
digitalWrite(A0,HIGH);
You can read more about it in the datasheet: http://www.atmel.com/Images/Atmel-8271-8-bit-AVR-Microcontroller-ATmega48A-48PA-88A-88PA-168A-168PA-328-328P_datasheet.pdf .
system
March 16, 2013, 8:44pm
412
Tell me if I have configured it correctly
Acc_Gyro Arduino
3.3V <—> 3.3V
GND <—> GND
X <—> AN0
Y <—> AN1
Z <—> AN2
SDA <—> AN4
SCL <—> AN5
@psyoptica
Yes that looks correct. But beware that if there is no logic level circuit on your breakout board, you might damage the IC. So get a logic level converter if you need to use if on the long run: https://www.sparkfun.com/products/8745 .
system
March 16, 2013, 8:53pm
414
I don't think there is a need for any logic level converter device since the arduino I'm using already gives a 3.3V signal.
Thanks for the quick responses. Really hope I learn something from this tutorial.
@psyoptica
You are using an Arduino Uno, right?
Then there is need for a logic level converter! Since the ATmega328P is running at 5V.
system
March 16, 2013, 8:57pm
416
Thanks for clearing it up. Will definitely have to get a converter circuit then..
