Topic: MultiTrans: Multi Channel Transceiver (just 1 pin per transceiver!) (Read 338 times) previous topic - next topic
feklee
After extensive stress tests and after months of use in production, I'm happy to announce MultiTrans, an implementation of a multi channel transceiver. Find MultiTrans in the Arduino library manager or in the GitHub repo feklee/multitrans.
New in version 1.2 is binary communication, i.e. sending and receiving messages that may include the null character.
I'm happy to answer any questions!
Features:
  • Transceiver: Transmit and receive simultaneously via a single pin. (No clock line needed.)
  • Multi channel: Multiple pins can transceive simultaneously.
  • Collision detection: One pin can start sending without worrying if the other side is sending as well. Collisions are automatically detected and circumvented. No information is lost.
  • Maximum uni-directional data rates on an Arduino Uno / Pro Mini:
    • Communication with one peer: 12 kbit/s
    • Communication with four peers: 3 kbit/s
    Bi-directional data rates are a little less than half of the above rates in each direction.
Limitations:
  • Buffers:
    • The buffer on the transmitting end can contain 256 bits at the most. For each character, 21 bits are necessary. This equates to 12 characters.
    • The buffer on the receiving end can only contain up to 255 pin change events.
    • Flushing the buffer on the receiving end takes some time.
    The system is thus best used for short bursts of data with sufficient idle time in between.
  • No built-in error checking. You may want to implement your own error checking, to take care of:
    • If you have a flaky connection between the Arduinos, for example due to bad electrical contacts, then bits may get lost.
    • Theoretically, i.e. if timing is perfectly right, the collision detection built into MultiTrans may fail resulting in bit loss.
  • It only works with AVR based Arduinos. In fact, code so far has only been tested with the Arduino Pro Mini and the Arduino Uno.
  • Timers are occupied:
    • 8-bit Timer/Counter2 (TC2), for transmitting
    • 16-bit Timer/Counter1 (TC1), for receiving
Examples:
  • Simple: bi directional communication between two Arduinos
  • Triangle: Arduinos communicating in a triangle
  • Stress test (advanced): testing maximum and minimum data rates with five Arduinos all communicating simultaneously
Robin2
Interesting. I am bookmarking this in the hope I find time to try it.
Have you any information about the maximum length of wire over which the system works?
I presume you need a GND connection as well as the data wire?
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
feklee
Sorry for the late reply. I didn't see your response as I forgot to subscribe to the topic. Yes, I'm very interested that other people try the library and I'm happy to get feedback!
I use it over distances of about 150 mm. It's digital communication. So I presume the maximum distance is comparable to that of SoftwareSerial.
Quote
Yes, I had to obey the laws of physics. ;)
Robin2
I, too, had forgotten about it, and I doubt if I will get time to try it for a few more days.
I would expect a regular Serial connection to work over a much greater distance - certainly 1500mm and maybe 5000.
...R
