Topic: Installing drivers on arduino nano (Read 2718 times) previous topic - next topic
ChickenLittle
So are you saying to reboot my computer sterretje.
Thanks so much.
ChickenLittle
I restarted and updated my computer the Arduino IDE also said updates were available for the boards so I updated that to and I still get the same error message when I upload my code.
Thanks so much.
ballscrewbob
Do you get the same error if you just have the NANO connected (removed from your other PCB) with NOTHING else connected to the board using either the OLD or the new bootloader ?
Beginning to suspect it may be something you have or had connected to the board.
A schematic might also be useful for your project at this time too.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
ChickenLittle
No I still get the same error when I upload the code to the Nano when it is not connected to anything.  Also I never drew a schematic for my project.
Thanks so much.
ChickenLittle
When I change the Processor to ATMege328P(Old Bootloader) instead of ATMega328P I get the error message "port busy"
ChickenLittle
Someone please tell me how to get the code on to my board should I try using a different computer?
Thanks.
sterretje
It might still have been busy with a previous attempt to upload.
Of course you can and should try. Do you still get the "comX not found" error?
And buy another Nano; nobody knows what you have done with this one except you. Try that one without connecting it to your circuit.
And provide a schematic; I know you did not make one but make one now so we can have an idea what possibly can be / can have gone wrong.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
ChickenLittle
Okay I will buy another Arduino NANO.
ChickenLittle
Actually never mind I fixed the problem without getting another board.
So thanks to everyone for your help.
pert
ChickenLittle please take a minute to describe your solution. That will help anyone else who has the same problem in the future and finds this thread. The information will also help us to do a better job providing support.
