Loading...
Pages: [1]   Go Down
Author Topic: An eaiser to use SD library  (Read 1318 times)
0
Offline Offline
Edison Member
Arduino rocks
View Profile
The native Arduino SD library was add to 022 as a wrapper for SdFat to make access to SD cards simpler.
I have updated SdFat to make it easier to use, added almost all features of the native SD library plus many new features.
Error handling has been improved and SPI access to the SD card has been rewritten.  Try running the examples below with no SD card to see a sample message.
Typical sketches in the new SdFat have fewer line of code than the native SD library.  Sketches generally take a few bytes less flash than the native library even with the new features and error handling.
The new library can be downloaded here http://code.google.com/p/beta-lib/downloads/list.
I have ported two example from the native SD library as an illustration.  I would appreciate any comments on the new SdFat library so I can improve it.
Here is the DumPFile example:
Code:
 SD card file dump - modified for the ne SdFat library by Bill Greiman
 This example shows how to read a file from the SD card using the
 new SdFat library and send it over the serial port.
 The circuit:
 * SD card attached to SPI bus as follows:
 ** MOSI - pin 11
 ** MISO - pin 12
 ** CLK - pin 13
 ** CS - pin 4
 created  22 December 2010
 modified Apr 11 2011 by Bill Greiman
 This example code is in the public domain.
#include <SdFat.h>
SdFat sd;  // Almost the same object as SD in the native SD library
SdFile dataFile;  // file to read from
// On the Ethernet Shield, CS is pin 4. SdFat handles setting SS
const int chipSelect = 4;
  //  initialize SdFat or print a detailed error message and halt
  //  Use half speed like native library.
  //  change to SPI_FULL_SPEED for more performance.
  if (!sd.init(SPI_HALF_SPEED, chipSelect))sd.initErrorHalt();
  // open data file
  if (!dataFile.open("datalog.txt", O_READ)) {
    sd.errorHalt("error opening datalog.txt");
  int data;
  //  copy file to Serial
  while ((data = dataFile.read()) >= 0) Serial.write(data);
void loop() {}
Here is the ReadWrite.pde example:
Code:
  SD card read/write - modified by Bill Greiman for SdFat
 This example shows how to read and write data to and from an SD card file
 The circuit:
 ** MOSI - pin 11
 ** MISO - pin 12
 ** CLK - pin 13
 ** CS - pin 4
 created   Nov 2010
 by David A. Mellis
 updated 2 Dec 2010
 by Tom Igoe
 modified by Bill Greiman 11 Apr 2011
#include <SdFat.h>
SdFat sd;
SdFile myFile;
  // Initialize SdFat or print a detailed error message and halt
  if (!sd.init(SPI_HALF_SPEED, chipSelect)) sd.initErrorHalt();
  // open the file for write at end like the Native SD library
  if (!myFile.open("test.txt", O_WRITE | O_CREAT | O_APPEND)) {
    sd.errorHalt("error opening test.txt for write");
  // if the file opened okay, write to it:
  Serial.print("Writing to test.txt...");
  myFile.println("testing 1, 2, 3.");
  // close the file:
  myFile.close();
  Serial.println("done.");
  // re-open the file for reading:
  if (!myFile.open("test.txt", O_READ)) {
    sd.errorHalt("error opening test.txt for read");
  Serial.println("test.txt:");
  // read from the file until there's nothing else in it:
  int data;
  while ((data = myFile.read()) >= 0) Serial.write(data);
  // close the file:
  myFile.close();
// nothing happens after setup
« Last Edit: April 11, 2011, 12:53:50 pm by fat16lib » Logged
Houston
Offline Offline
Jr. Member
Electronics is just part of life.
View Profile
I'm trying to use your library with the arduino spi library. sorry to bother you again but can you please help me out with the code?
Code:
#include <SPI.h>
#include <SdFat.h>
int CS_pin = 8;
int DCS_pin = 9;
int DREQ_pin = 7;
int XRST_pin = 6;
int MP3_CS_pin = 10;
SdFat sd;
SdFile myFile;
byte dat[10000];
int index = 0;
  pinMode(MP3_CS_pin, OUTPUT);
  pinMode(CS_pin, OUTPUT);
  pinMode(DREQ_pin, INPUT);
  pinMode(DCS_pin, OUTPUT);
  pinMode(XRST_pin, OUTPUT);
void playSong(){
  for(int i = 0; i < index; i++){
    SPI.transfer(dat[i]);
  digitalWrite(MP3_CS_pin, HIGH);
  digitalWrite(CS_pin, HIGH);
  digitalWrite(DCS_pin, HIGH);
  delay(100);
  if (!sd.init(SPI_HALF_SPEED, MP3_CS_pin)) sd.initErrorHalt();
  if (!myFile.open("song1.mp3", O_READ)) {
    sd.errorHalt("error opening song1.mp3 for read");
  Serial.println("song1.mp3:");
  int data;
  while ((data = myFile.read()) >= 0){
    Serial.write(data);
    dat[index++] = data;
  myFile.close();
 SPI.begin();
 SPI.setBitOrder(MSBFIRST);
 SPI.setDataMode(SPI_MODE1);
 //max SDI clock freq = CLKI/7 and (datasheet) CLKI = 36.864, hence max clock = 5MHz
 //SPI clock arduino = 16MHz. 16/ 4 = 4MHz -- ok!
 SPI.setClockDivider(SPI_CLOCK_DIV4);
 digitalWrite(XRST_pin, LOW);
 delay(100);
 digitalWrite(XRST_pin, HIGH);
 delay(5);
 // CHIP Write
 // sets sci_mode register, SM_SDINEW, SM_TESTS, SM_STREAM.  pg 25, 26
 byte aux;
 digitalWrite(CS_pin, LOW);
 delay(1);
 SPI.transfer(0x02);  //write command
 SPI.transfer(0x00); //SDI_MODE register
 //extract and send higher byte of data
 //0x0400
 aux = 0x08A0 >> 8;
 SPI.transfer(aux);
 //extract and send lower byte of data
 aux = 0x08A0 & 0b11111111;
 SPI.transfer(aux);
 //wait for the chip to finish executing command
 while (!DREQ_pin){};
 delay(1);
 // Start SINE test
 digitalWrite(DCS_pin, LOW);
 delay(1);
 playSong();
 delay(200);
sorry to bother you so much but i've been at this for like 2 weeks now and im super frustrated >.<
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
Leonidas,
This post is about a new library that has not been tested on the Sanguino.
The Sanguino support is so poor that I have given up testing SdFat on the 644.  I did not write the Arduino SPI library.
Sorry I can't be of more help.  I stopped using my Sanguino because of problems like this.
Logged
Houston
Offline Offline
Jr. Member
View Profile
no this is on the arduino uno. i think i might do the same thing u did.
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
Making your mp3 player work is not the topic of this post.  It would be better for you to start a new topic.
Logged
Pages: [1]   Go Up
Print
Jump to:
