Topic: Using potentiometer to adjust resistance (Read 823 times) previous topic - next topic
nighterfighter
Hey guys, this is a really noob question, sorry-
I am trying to make a LED "dimmer" by using a sliding pot to adjust the resistance in the circuit.
I have the + side of a battery directly connected to one leg of the pot. I have my LEDs wired in parallel, then connected to the - end of the battery. My question is this-
Do I need to hook the Wiper end of the pot to the LEDs, or the other leg directly to the LEDs?
Here is a quick picture of what I have-
Thanks!
http://img251.imageshack.us/img251/6030/leddimmer.png
RuggedCircuits
Looks right, though perhaps not the most efficient way to do it. LED's are generally placed in series so they all have the same brightness (same current). You may see one LED quite a bit brighter than the others.
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, speaker, microphone, light sensor, potentiometer, pushbuttons
nighterfighter
Thanks for answering my question on the pot- I thought I should hook it to the wiper. So what should the other end of the pot go to?
Ah, thanks for that! I had a brain fart on the series vs parallel thing. I was thinking voltage determined the brightness, but of course LEDs are current driven!
Thanks.
RuggedCircuits
Nothing, or the wiper. We have a little writeup on this topic here:
http://ruggedcircuits.com/html/circuit__15.html
Beat707: MIDI drum machine / sequencer / groove-box for Arduino
nighterfighter
Thanks, that helps.
So just so I'm sure-
If I wire the LEDs in series, they will all have the same brightness?
RuggedCircuits
Yes, assuming they're all exactly the same (i.e., XX mA cause YY lumens). There will be some part-to-part variation but if they're the same part number the brightness should be fairly equal.
The drawback, of course, is that your voltage source now has to be at least as high as the sum of your LED forward voltage drops added up.
The Rugged Motor Driver: two H-bridges, more power than an L298, fully protected
nighterfighter
That won't be a problem.
Thanks for the help.
