Loading...
Pages: [1]   Go Down
Author Topic: Serial -> 7 - Segment display  (Read 1046 times)
Offline Offline
Jr. Member
View Profile
Hey there,
I try to control 4 7 segment displays with two of these registers http://www.alldatasheet.com/datasheet-pdf/pdf/51041/FAIRCHILD/DM74LS164N.html
I connected the reset pins, the clock pins, and on both of them I connected serial in 1 and 2 .
the serial in inputs of the second one are connected with the last output (OH) of the first register.
Now I cannot figure out how to send serial data to it from the arduino.
Which is the clock pin, which is the serial out pin, how can I access them?
I really dont know how i can get this work  smiley-confuse
- Flo
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
Any pin you want them to be, it is down to your software.
See :- http://www.arduino.cc/en/Tutorial/ShiftOut
Note that for four 7 Segment displays you will need four shift registers not two.
Logged
Offline Offline
Jr. Member
View Profile
i got it to work now.
it was just a the and gate input of the registers.
I need two 8 bit registers, or four 4bit ...
it works now
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
Not sure that make any sense.
Quote
? a seven segment display has seven segment hence you need seven outputs. Unless of course you don't actually have a seven segment display but a decoder chip driving the seven segment display, which is something different from what you said.
Logged
Offline Offline
Jr. Member
View Profile
yeah sorry,  i meant that there is  an AND gate at the inputs of my serial in parallel out shift registers.
and yeah i meant driving the drivers...
i was just so happy that it finally worked ...
- Flo
« Last Edit: April 12, 2011, 06:45:51 am by Flub » Logged
Pages: [1]   Go Up
Print
Jump to:
