Topic: Accessing SD Card (Read 2792 times) previous topic - next topic
struthio
Hello,
I'm trying to connect SD (microSD) card to Arduino (Arduino Nano in fact).
I connected all pins as required MISO, MOSI, CLK, SS. But I cannot read SD data contents.
Once per 10 or 20 tries library manages to get CARD info such as manufacturer, serial number etc. but it never manage to read FAT16.
I tried to format card under windows/linux/windows + sd formatter and none of this helps.
I also tried fat16 lib and sdlib and its example info app.
Can anybody help ? I planned to use sd card as a storage for datalogger, but now I cannot log anything!
PaulS
Quote
How?
Quote
Those are not the only pins that need to be connected. What about power and ground?
Quote
Using what code?
struthio
Yes, I also connect SD to power (Arduino 3V3 and GND pins)
As for logging than core now is irrelevant, because I cannot even init card with example app that comes with FAT16 lib:
Code: [Select]
* This sketch attempts to initialize a SD card and analyze its format.
#include <Fat16.h>
#include <Fat16util.h> // use functions to print strings from flash memory
SdCard card;
Fat16 file;
void sdError(void) {
  if (card.errorCode) {
    PgmPrintln("SD error");
    PgmPrint("errorCode: ");
    Serial.println(card.errorCode, HEX);
    PgmPrint("errorData: ");
    Serial.println(card.errorData, HEX);
  return;
uint8_t cidDmp(void) {
  cid_t cid;
  if (!card.readCID(&cid)) {
    PgmPrintln("readCID failed");
    sdError();
    while(1);
  PgmPrint("\nManufacturer ID: ");
  Serial.println(cid.mid, HEX);
  PgmPrint("OEM ID: ");
  Serial.print(cid.oid[0]);
  Serial.println(cid.oid[1]);
  PgmPrint("Product: ");
  for (uint8_t i = 0; i < 5; i++)Serial.print(cid.pnm[i]);
  PgmPrint("\nVersion: ");
  Serial.print(cid.prv_n, DEC);
  Serial.print('.');
  Serial.println(cid.prv_m, DEC);
  PgmPrint("Serial number: ");
  Serial.println(cid.psn);
  PgmPrint("Manufacturing date: ");
  Serial.print(cid.mdt_month);
  Serial.print('/');
  Serial.println(2000 + cid.mdt_year_low + (cid.mdt_year_high <<4));
  return 1;
* print partition info
uint8_t partitionInfo(void) {
  mbr_t* mbr = (mbr_t*)Fat16::dbgCacheBlock(0);
  if (mbr == 0) {
    PgmPrintln("partitionInfo: cacheBlock(0) failed");
    return 0;
  uint8_t good = 0;
  for (uint8_t i = 0; i < 4; i++) {
    if ((mbr->part[i].boot & 0X7F) != 0 ||
        (mbr->part[i].firstSector == 0 && mbr->part[i].totalSectors != 0)) {
          // not a valid partition table
          return 0;
    if (mbr->part[i].firstSector != 0 && mbr->part[i].totalSectors != 0) {
      //might be ok
      good = 1;
  if (!good) return 0;
  PgmPrintln("Partition  Table:");
  PgmPrintln("part,boot,type,start,size");
    Serial.print(i+1);
    Serial.print(',');
    Serial.print(mbr->part[i].boot, HEX);
    Serial.print(',');
    Serial.print(mbr->part[i].type, HEX);
    Serial.print(',');
    Serial.print(mbr->part[i].firstSector);
    Serial.print(',');
    Serial.println(mbr->part[i].totalSectors);
  return 1;
* print info for FAT volume
uint8_t volumeInfo(uint8_t part) {
  uint8_t volumeType = 0;
  if (part > 4) {
    PgmPrintln("volumeInfo: invalid partition number");
    return 0;
  if (mbr == 0) {
    PgmPrintln("volumeInfo: cacheBlock(0) failed");
    return 0;
  bpb_t* bpb = &(((fbs_t*)mbr)->bpb);
  if (part != 0) {
    if ((mbr->part[part-1].boot & 0X7F) !=0  ||
      mbr->part[part-1].totalSectors < 100 ||
      mbr->part[part-1].firstSector == 0) {
        //not a valid partition
        return 0;
     fbs_t* fbs = (fbs_t*)Fat16::dbgCacheBlock(mbr->part[part-1].firstSector);
     if (fbs == 0) {
       PgmPrintln("volumeInfo cacheBlock(fat boot sector) failed");
       return 0;
     if (fbs->bootSectorSig0 != 0X55 || fbs->bootSectorSig1 != 0XAA) {
       PgmPrintln("Bad FAT boot sector signature for partition: ");
       Serial.println(part, DEC);
       return 0;
     bpb = &fbs->bpb;
  if (bpb->bytesPerSector != 512 ||
      bpb->fatCount == 0 ||
      bpb->reservedSectorCount == 0 ||
      bpb->sectorsPerCluster == 0 ||
      (bpb->sectorsPerCluster & (bpb->sectorsPerCluster - 1)) != 0) {
        // not valid FAT volume
        return 0;
  uint32_t totalBlocks = bpb->totalSectors16 ? bpb->totalSectors16 : bpb->totalSectors32;
  uint32_t fatSize = bpb->sectorsPerFat16;
  if (fatSize == 0) {
    // first entry of FAT32 structure is FatSize32
    // don't ask why this works
    fatSize = *(&bpb->totalSectors32 + 1);
  uint16_t rootDirSectors = (32*bpb->rootDirEntryCount + 511)/512;
  uint32_t firstDataSector = bpb->reservedSectorCount +
                                 bpb->fatCount*fatSize + rootDirSectors;
  uint32_t dataBlockCount = totalBlocks - firstDataSector;
  uint32_t clusterCount = dataBlockCount/bpb->sectorsPerCluster;
  if (part) {
    PgmPrint("FAT Volume info for partition: ");
    PgmPrintln("FAT Volume is super floppy format");
  if (clusterCount < 4085) {
    volumeType = 12;
  } else if (clusterCount < 65525) {
    volumeType = 16;
    volumeType = 32;
  PgmPrint("Volume is FAT");
  Serial.println(volumeType, DEC);
  PgmPrint("clusterSize: ");
  Serial.println(bpb->sectorsPerCluster, DEC);
  PgmPrint("clusterCount: ");
  Serial.println(clusterCount);
  PgmPrint("fatCount: ");
  Serial.println(bpb->fatCount, DEC);
  PgmPrint("fatSize: ");
  Serial.println(fatSize);
  PgmPrint("totalBlocks: ");
  Serial.println(totalBlocks);
  return volumeType;
  PgmPrint("FreeRam: ");
  Serial.println(FreeRam(), DEC);
  PgmPrintln("\ntype any character to start");
  while (!Serial.available());
  Serial.flush();
  int8_t part = -1;
  uint32_t t0 = millis();
  if (!card.init()) {
    PgmPrintln("card.init failed");
    sdError();
    return;
  uint32_t d = millis()- t0;
  PgmPrint("\ninit time: ");Serial.println(d);
  cidDmp();
  uint32_t size = card.cardSize();
  PgmPrint("Card Size(blocks): ");
  Serial.println(size);
  if (size < 1000) {
    PgmPrint("Quitting, bad size");
    return;
  Fat16::dbgSetDev(&card);
  if (partitionInfo()) {
    for (uint8_t i = 1; i < 5; i++) {
      if (volumeInfo(i) == 16) part = i;
    PgmPrintln("Card is not MBR trying super floppy");
    if (volumeInfo(0) == 16) part = 0;
  if (part >= 0) {
    if (!Fat16::init(&card, part)) {
      PgmPrintln("Can't init volume");
      return;
    uint16_t index = 0;
    dir_t d;
    PgmPrintln("Root Directory:");
    PgmPrintln("name     ext att size");
    uint8_t nd = 0;
    //list up to 20 files
    while ((Fat16::readDir(&d, &index)) && nd++ < 20) {
      for (uint8_t i = 0; i < 11; i++) {
        if (i == 8)Serial.print(' ');
        Serial.print((char)d.name[i]);
      Serial.print(' ');
      Serial.print(d.attributes, HEX);
      Serial.print(' ');
      Serial.println(d.fileSize);
      index++;
    PgmPrintln("\nDone");
    PgmPrintln("FAT16 volume not found");
It 19 for 20 tries cannot init card, once in time it init card and read manufacturer, serial number, product and manuf. date.
But even then it says that FAT16 is not found! And I (as written before) formatted card in FAT16 fs (confirmed that under windows and linux)
I tried also sdFAT lib.
Tried this with Kingston and sandisk 1GB microSD card in SD adapter
struthio
here is an example of executing SdFatInfo from SdFatLib:
Code: [Select]
A
init time: 308
Card type: SD1
readCID failedSD error
errorCode: E
errorData: 1B
init time: 367
Card type: SD1
errorCode: D
errorData: FC
init time: 311
Card type: SD1
errorCode: E
errorData: 12
init time: 309
Card type: SD1
errorCode: E
errorData: 1
init time: 304
Card type: SD1
errorCode: E
errorData: 7F
init time: 366
Card type: SD1
Manufacturer ID: 2
OEM ID: TM
Product: SD01G
Version: 2.8
Serial number: 2398457241
Manufacturing date: 1/2007
cardSize: 2012160 (512 byte blocks)
flashEraseSize: 128 blocks
eraseSingleBlock: true
part,boot,type,start,length
read partition table failedSD error
errorCode: 3
errorData: 20
As you see it took 6 attempts to receive data from SD card - but even then no info about FAT filesystem was received.
