Loading...
Pages: [1]   Go Down
Author Topic: 12V Led Strip PWM  (Read 1209 times)
Offline Offline
Newbie
View Profile
Hi guys
I've buyed some RGB-Led Strips common cathode. And now i like to control them from my Arduino.
Because they are common cathode strips i need to control them with a pnp-transistor, right? So, i've buyed three IRF5303 Mosfets.
http://www.redrok.com/MOSFET_IRF5305_-55V_-31A_6mO_Vth-4.0_TO-220.pdf
My Problem is how to control this Mosfets from the Arduino?
When connect 12v + to the drain and the + from the led to source the led is on. but how can i use the p-channel mosfet as a switch to turn off the led's.
thanks in advanche
paynoise
ps: sorry for my bad english...
Logged
0
Offline Offline
Faraday Member
ruggedcircuits.com
View Profile
WWW
You can do something like this:
http://ruggedcircuits.com/html/circuit__11.html
Replace the +6V in the schematic with your +12V (and the AOD417 with your IRF5303).
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, speaker, microphone, light sensor, potentiometer, pushbuttons
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
If you'd chosen a logic-level p-channel MOSFET you could have simply level-shifted with a zener diode and a pull-up on the gate...  You'll need an NPN or n-channel transistor to drive the gate with full voltage swing.
Logged
Offline Offline
Newbie
View Profile
@Rugged Circuits
can i use this 9014 (http://www.datasheetcatalog.org/datasheet/WINGS/9014.pdf)transistors instead of this 2N7000? Can i use the same resistors which you used in the circuit?
Logged
0
Offline Offline
Faraday Member
ruggedcircuits.com
View Profile
WWW
Yes, that should work. I don't think the resistors will need to change.
Beat707: MIDI drum machine / sequencer / groove-box for Arduino
Logged
Offline Offline
Newbie
View Profile
thanks a lot. i'll try it this evening...
Logged
Pages: [1]   Go Up
Print
Jump to:
