Topic: MKR Zero - PWM Burst (Read 436 times) previous topic - next topic
lgoll88
Dec 04, 2018, 08:37 am Last Edit: Dec 04, 2018, 08:47 am by lgoll88
Hello guys and girls,
i have a MKR Zero and want to generate a PWM Burst (Frequency 1kHz and duty cycle of 30 %).
My target is to generate exactly 300 Pulses or 500 Pulses and so on, when a button is pressed.
I already read the topic on : https://forum.arduino.cc/index.php?topic=346731.0
But there is always a continious PWM generation. My example is already generating a 1kHz with 30% duty cycle, but continiously.
Can anyone help me please?
//Output 1kHz 30% duty cycle
  REG_GCLK_GENDIV = GCLK_GENDIV_DIV(1) |          // Divide the 48MHz clock source by divisor 1: 48MHz/1=48MHz
                    GCLK_GENDIV_ID(4);            // Select Generic Clock (GCLK) 4
  while (GCLK->STATUS.bit.SYNCBUSY);              // Wait for synchronization
  REG_GCLK_GENCTRL = GCLK_GENCTRL_IDC |           // Set the duty cycle to 50/50 HIGH/LOW
                     GCLK_GENCTRL_GENEN |         // Enable GCLK4
                     GCLK_GENCTRL_SRC_DFLL48M |   // Set the 48MHz clock source
                     GCLK_GENCTRL_ID(4);          // Select GCLK4
  // Enable the port multiplexer for the digital pin D7
  PORT->Group[g_APinDescription[7].ulPort].PINCFG[g_APinDescription[7].ulPin].bit.PMUXEN = 1;
  // Connect the TCC0 timer to digital output D7 - port pins are paired odd PMUO and even PMUXE
  // F & E specify the timers: TCC0, TCC1 and TCC2
  PORT->Group[g_APinDescription[6].ulPort].PMUX[g_APinDescription[6].ulPin >> 1].reg = PORT_PMUX_PMUXO_F;
  // Feed GCLK4 to TCC0 and TCC1
  REG_GCLK_CLKCTRL = GCLK_CLKCTRL_CLKEN |         // Enable GCLK4 to TCC0 and TCC1
                     GCLK_CLKCTRL_GEN_GCLK4 |     // Select GCLK4
                     GCLK_CLKCTRL_ID_TCC0_TCC1;   // Feed GCLK4 to TCC0 and TCC1
  // Dual slope PWM operation: timers countinuously count up to PER register value then down 0
  REG_TCC0_WAVE |= TCC_WAVE_POL(0xF) |         // Reverse the output polarity on all TCC0 outputs
                    TCC_WAVE_WAVEGEN_DSBOTH;    // Setup dual slope PWM on TCC0
  while (TCC0->SYNCBUSY.bit.WAVE);               // Wait for synchronization
  // Each timer counts up to a maximum or TOP value set by the PER register,
  // this determines the frequency of the PWM operation:
  REG_TCC0_PER = 24000;                          // Set the frequency of the PWM on TCC0 to 1kHz
  while (TCC0->SYNCBUSY.bit.PER);                // Wait for synchronization
  // Set the PWM signal to output 30% duty cycle
  REG_TCC0_CC3 = 8000;         // TCC0 CC3 - on D7
  while (TCC0->SYNCBUSY.bit.CC3);                // Wait for synchronization
  // Divide the 48MHz signal by 1 giving 48MHz (20.83ns) TCC0 timer tick and enable the outputs
  REG_TCC0_CTRLA |= TCC_CTRLA_PRESCALER_DIV1 |    // Divide GCLK4 by 1
                    TCC_CTRLA_ENABLE;             // Enable the TCC0 output
  while (TCC0->SYNCBUSY.bit.ENABLE);              // Wait for synchronization
void loop() { }
MartinL
#1
Dec 04, 2018, 10:10 am Last Edit: Dec 04, 2018, 10:12 am by MartinL
Hi Igoll88,
Probably the easiest way to generate a burst of 300 PWM pulses, is to activate the timer's interrupt service routine (ISR), get it to count the number of timer pulses and shut itself down when the pulse count reaches 300.
Here's some code that generates 300 pulses at 1kHz, 30% duty-cycle, every second on digital pin D6:
// Output a burst of 300 pulses at 1kHz, 30% duty-cycle on digital pin D6
  GCLK->GENDIV.reg = GCLK_GENDIV_DIV(1) |          // Divide the 48MHz clock source by divisor 3: 48MHz/1=48MHz
  GCLK->GENCTRL.reg = GCLK_GENCTRL_IDC |           // Set the duty cycle to 50/50 HIGH/LOW
  // Enable the port multiplexer for the TCC0 PWM channel 2 (digital pin D6), SAMD21 pin PA20
  PORT->Group[g_APinDescription[6].ulPort].PINCFG[g_APinDescription[6].ulPin].bit.PMUXEN = 1;
  // Connect the TCC0 timer to the port outputs - port pins are paired odd PMUO and even PMUXE
  PORT->Group[g_APinDescription[6].ulPort].PMUX[g_APinDescription[6].ulPin >> 1].reg |= PORT_PMUX_PMUXE_F;
  GCLK->CLKCTRL.reg = GCLK_CLKCTRL_CLKEN |         // Enable GCLK4 to TCC0 and TCC1
  NVIC_SetPriority(TCC0_IRQn, 0);    // Set the Nested Vector Interrupt Controller (NVIC) priority for TCC0 to 0 (highest)
  NVIC_EnableIRQ(TCC0_IRQn);         // Connect TCC0 to Nested Vector Interrupt Controller (NVIC)
  TCC0->WAVE.reg |= TCC_WAVE_WAVEGEN_NPWM;          // Setup normal single slope PWM on TCC0
  TCC0->PER.reg = 47999;                           // Set the frequency of the PWM on TCC0 to 1Hz ((48MHz/1000)-1=47999)
  TCC0->CC[2].reg = 0;                             // Initialially set 0% duty cycle on D6
  while (TCC0->SYNCBUSY.bit.CC2);                  // Wait for synchronization
  TCC0->CTRLA.bit.ENABLE = 1;                      // Enable the TCC0 counter
  // Output a burst of 300 PWM pulses at 1kHz, 30% duty cycle every second
  TCC0->INTENSET.bit.OVF = 1;                     // Enable overflow (OVF) interrupts on TCC0
  delay(1000);                                    // Wait 1 second
void TCC0_Handler()
  static volatile uint32_t counter;
  if (TCC0->INTENSET.bit.OVF && TCC0->INTFLAG.bit.OVF)
    if (counter == 0)
      counter++;
      TCC0->CCB[2].reg = 14399;                        // TCC0 CCB2 - 30% duty cycle on D6 (using buffered CCBx register)
      while (TCC0->SYNCBUSY.bit.CCB2);                 // Wait for synchronization
    else if (counter < 300)                           // Have we counted up to 300?
      counter++;                                      // Increment the counter and continue
      counter = 0;                                    // Reset the counter
      TCC0->CCB[2].reg = 0;                           // TCC0 CCB2 - 0% duty cycle on D6 (using buffered CCBx register)
      TCC0->INTENCLR.bit.OVF = 1;                     // Disable overflow (OVF) interrupts on TCC0
    TCC0->INTFLAG.bit.OVF = 1;                        // Clear the interrupt flag
