Loading...
Pages: [1]   Go Down
Author Topic: 24Mhz High Precision Crystal Clock Oscillator  (Read 1471 times)
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
I was browsing around on eBay and came upon these 24Mhz Clock Crystals and was wondering if it was possible to upgrade the close of my Pro Mini Ardunio. Have anyone tried this?
Thank you.
http://cgi.ebay.com/5-x-24Mhz-High-Precision-Crystal-Clock-Oscillator_W0QQitemZ300530157957QQcategoryZ16145QQcmdZViewItemQQ_trksidZp5197.m263QQ_trkparmsZalgo%3DSIC%26itu%3DUCI%252BIA%252BUA%252BFICS%252BUFI%252BDDSIC%26otn%3D10%26pmod%3D380327208085%252B280602239060%252B310180759687%26po%3DLVI%26ps%3D63%26clkid%3D8414260650658597966
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
24 MHz is beyond the specifications.  Others have reported success over-clocking AVR processors but it is always a gamble.  It is your application so you will have to decide if it is worth the risk.
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
See section 8.2 of the ATMega328 datasheet for more discussion of the crystals to use.
See this note in particular from Tables 8-3 & 8-5.
"If the crystal frequency exceeds the specification of the device (depends on VCC), the CKDIV8
Fuse can be programmed in order to divide the internal frequency by 8. It must be ensured
that the resulting divided clock meets the frequency specification of the device."
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Thanks for the post.  I assumed CKDIV8 only applied to the internal oscillator.
Logged
Lancashire, UK
Offline Offline
Edison Member
View Profile
WWW
Nothing like making life difficult. Other than the technical implications of whether it will run at 24Mhz, it will introduce a lot of non-trivial timing issues, particularly with serial and uploading sketches.
Logged
Pages: [1]   Go Up
Print
Jump to:
