Topic: Using an Arduino, an accelerometer and LEDs... (Read 2948 times) previous topic - next topic
Cadet
Apr 13, 2011, 12:15 pm Last Edit: Apr 13, 2011, 03:20 pm by Cadet Reason: 1
Hi guys,
I'm a complete beginner at both programming and circuitry so I'd really like some sound advice on my project!
I'm making an 'Artist Book' on digital designs. The book itself resembles a hard drive.
I wanted to add some interactivity by having the logo on the cover light up when the user lifts it or moves it.
So far I have an accelerometer (ADXL335), 2 Voltage regulators and an Arduino uno to complete this task.
I'd like to know:
how feasible this idea is,
whether I could complete it before the beginning of May
what kind of LED's are most powerful, cost effective and require no ventilation
how I would go about coding the arduio to carry out this function.
Any advice at all would be greatly appreciated.
Thanks!
Isaac
AWOL
You'll need to read about the low-power modes, and try to choose an accelerometer with a "knock" interrupt.
Don't post your email address in a forum - not sensible.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
Cadet
I already have the accelerometer, voltage regulators and arduino.. So what is the 'knock' interrupts function?
Low-power modes.. Okay, how does this affect the project.. What is it?
I have no idea about forums but yes I've removed my e-mail, thanks.
AWOL
#3
Apr 13, 2011, 03:33 pm Last Edit: Apr 13, 2011, 03:36 pm by AWOL Reason: 1
Quote
Which accelerometer?
The knock or tap interrupt is a feature of some accelerometers that allows you to wake up some other item (like an Arduino) if the accelerometer is subjected to a sharp tap.
It is used in disk drives to force the controller to retract the heads, or in phones to perform some functions, like cancel an alarm or answer a call.
The low power modes allow your Arduino to go to sleep until woken up by, say, a tap interrupt.
Whilst in low power, they consume far less power than when running normally, so prolonging battery life.
Cadet
It's a triple axis accelerometer by Breakout the code is (ADXL335)
Okay is get the tap/knock interrupt, it has it according to the manufacturer.
So low power mode is something that can be programmed e.g. using Processing for Mac?
AWOL
Quote
I don't understand what you mean - I thought the Arduino was going to be standalone, ie not connected to a host?
Cadet
Don't you have to program it to carry out a certain function? I was told I had to use Processing to do this..
AWOL
Quote
No, you use Processing if you want the PC to do something in response to input from a connected Arduino, like plot a graph based on captured data.
Are you confusing Processing with the Arduino IDE?
Cadet
I guess so, I'm only repeating what I've been told but I did think it was odd that I shouldn't use the native programming software for the arduino.
I'd really just like to know how I should begin coding it to carry out this function and if the use of RGB LED's would be feasible?
AWOL
Hook the accelerometer to the analogue inputs, and get programming.
Cadet
Okay, where could I find a good tutorial on how to hook the accelerometer to the arduino? I'm coming up with blanks online.
AWOL
Cadet
AWOL
Up there, on the left, where it says "Main site" "Blog" "Playground"
Close, very close.
http://bildr.org/2011/03/adxl345-arduino/
Cadet
