Topic: sensor with pulse with modulation and pin (Read 702 times) previous topic - next topic
cantore
May be I am doing a stupid question but: if sensor like water flow ones are like a switch that every turn make the output going high for a short time, why have they 3 pins?
I think it would be sufficent to have 2. Using a pull up resistor, one must be connected to digital_in and to the resistor going at 5v and the second connected to GND.
What's the reason of using one more pin? thanks
retrolefty
It depends on the sensor. If it's a 'passive' sensor using say a magnetic reed switch that senses a magnet spinning on the flow meter's impeller then only two wires would be required. However if the sensor uses a 'active' sensor, say a hall effect magnetic switch then the hall effect devices requires a voltage source to operate, so needs three wires.
cantore
hall effect is a good example, you're right! May be my water flow sensor uses this principle. Thanks
robtillaart
Quote
Questions are not stupid, they cannot be, people NOT asking them might be :)
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
