Topic: extra character ftp code of surfertim (Read 258 times) previous topic - next topic
mikeztrainer
every time i run the sketch and press 'f',it first has an error "SD OPEN FAIL" first.
i need to press 'f' again to transfer the file.is it normal?
i tried changing the sdcard and format it,still got the same result.
i also tried in other laptop,download new arduino.i version use 1.6.5
i dont where that weird character came from.
mikeztrainer
Give us the file from your pc and the one from the se card (if you are not using plain ascii but uft8 or utf16 then depending on what your file's content is you can see weird bytes because you'll need multiple bytes for one character symbol)
this solves my problem.many thanks
