Topic: Adafuit PN532 draining battery (Read 194 times) previous topic - next topic
mbasile
Hey guys, I have a question for everyone. I would like to make my program more efficient in terms of saving battery power. I currently have an adafruit PN532 NFC reader connected to a SparkFun Fio V3 that powers a servo to lock and unlock my front door when the card is detected. It is being powered through the micro USB port by an external 16,000 mAh battery pack (the same ones commonly used for charging phones on the go).
However, it seems that after 3 days of having the unit powered the battery is already halfway gone. Can you all look at my code to see if there are any inefficiencies within it that would cause the battery to be drained so fast. Is the PN532 is constantly being polled and asking (is there a card.... is the a card now??) and draining my battery?
Code: [Select]
 #include <Wire.h>
 #include<Servo.h>
 #include<SPI.h>
 #include <Adafruit_PN532.h>
#include "Servo.h"
#include "Wire.h"
#include "SPI.h"
#include "Adafruit_PN532.h"
#define PN532_IRQ   (7)
#define PN532_RESET (3)
Adafruit_PN532 nfc(PN532_IRQ, PN532_RESET);
Servo myservo;  // create servo object to control a servo
int servoPin = 9;  // servo pin on Arduino
int lockState = 2;  // IMPORTANT: if state = 1; locked, state = 2; unlocked
int doorLock;
  Serial.println("Hello!");
  // find Adafruit RFID/NFC shield
  nfc.begin();
  uint32_t versiondata = nfc.getFirmwareVersion();
  if (! versiondata) {
    Serial.print("Didn't find PN532 board");
    while (1); // halt
  // Got ok data, print it out!
  Serial.print("Found chip PN5"); Serial.println((versiondata >> 24) & 0xFF, HEX);
  Serial.print("Firmware ver. "); Serial.print((versiondata >> 16) & 0xFF, DEC);
  Serial.print('.'); Serial.println((versiondata >> 8) & 0xFF, DEC);
  // configure board to read RFID tags
  nfc.SAMConfig();
//***********LOOP************
unsigned digit = 0;
void loop(void) {
  uint8_t success;
  uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 };  // Buffer to store the returned UID
  uint8_t uidLength;                        // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
  // Wait for an ISO14443A type cards (Mifare, etc.).  When one is found
  // 'uid' will be populated with the UID, and uidLength will indicate
  // if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
  success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
  uint32_t cardidentifier = 0;
  if (success) {
    // Display some basic information about the card
    Serial.println("Found an ISO14443A card");
    Serial.println("Card detected #");
    // turn the four byte UID of a mifare classic into a single variable #
    cardidentifier = uid[3];
    cardidentifier <<= 8; cardidentifier |= uid[2];
    cardidentifier <<= 8; cardidentifier |= uid[1];
    cardidentifier <<= 8; cardidentifier |= uid[0];
    Serial.println(cardidentifier);
    Serial.println("Add this tag # to code");
    // repeat this for loop as many times as you have RFID cards
    switch (cardidentifier) {
      case 1303311769:    // these are the tags numbers
        lockUnlock();
        myservo.detach();
        delay(2000);      // do not allow the card to read for x second(s)
      case 1694073287:
        lockUnlock();
        myservo.detach();
      case 1694526935:
        lockUnlock();
        myservo.detach();
      case 1304635385:
        lockUnlock();
        myservo.detach();
      case 1245611012:
        lockUnlock();
        myservo.detach();
      case 3723402814:
        lockUnlock();
        myservo.detach();
void lockUnlock() { // locks or unlocks door
  myservo.attach(servoPin);
  if (lockState == 1) {
    myservo.write(180);    // unlock the door
    delay(500);            // move servo for X second(s)
    lockState = 2;
  else if (lockState == 2) {
    myservo.write(0);     // lock the door
    lockState = 1;
  myservo.detach();
J-M-L
Yes the code is polling continually. Have you tried to see how much it draws and if that matches with your battery's drop ?
If I remember correctly there's an IRQ pin on the PN532 breakout shield - you could use that to wake up your arduino system instead of polling but The PN532 still needs to be powered (and configured) as your tags are passive and this is what blasts energy onto the cards.
Which version of the board you have? Adaftuit's  v1.0 and v1.3 of the breakout boards have a problem where SVDD is connected directly to VDD instead of being left floating. This has no effect on the functionality of the boards, but does cause some extra current to be drawn.
Hello - Please do not PM me for help,  others will benefit as well if you post your question publicly on the forums.
Bonjour Pas de messages privés SVP, postez dans le forum directement pour que ça profite à tous
mbasile
I have the V1.3, in the code i have set the IRQ to pin 7 on the Fio V3, am i not setting it up per what you're talking about? (waking it up). Also, should i (or do I) have to cut the trace between pin 2 and the IRQ on the NFC shield?
J-M-L
#3
Dec 09, 2018, 11:07 pm Last Edit: Dec 09, 2018, 11:23 pm by J-M-L
I would start by measuring current draw. What you'll save sleeping your arduino might be relatively small compared to what is drawn by the PN532 shield (you can expect the chip to draw 100mA when looking for a card)
You say you went thru 8000 mAh in 3 days that's a draw of ~110mA for the system... not that bad when running all the time...
mbasile
#4
Dec 09, 2018, 11:39 pm Last Edit: Dec 09, 2018, 11:40 pm by mbasile
would the below code added not stop the polling continuously?
Code: [Select]
  Serial.print("Found chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
  Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
  Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
// Set the max number of retry attempts to read from a card
  // This prevents us from waiting forever for a card, which is
  // the default behaviour of the PN532.
  nfc.setPassiveActivationRetries(0xFF);
except i would want to change 0xFF to say 0x01 for just one poll right? then wouldnt it stop asking "wheres the card..."
J-M-L
What would you gain? The loop would still loop...
mbasile
What is the point of the below?
Code: [Select]
 I thought 0xFF meant it is continuously polling for a card
Then wouldn't this look one time, and then give up until a card presents itself?
Code: [Select]
  nfc.setPassiveActivationRetries(1);
J-M-L
And then the loop loops and you ask again... so it's similar
mbasile
So they have added that to the NFC library and it's pointless? Per adafruit, this should be initiated in the setup and before the
Code: [Select]
  nfc.SAMConfig();
So why would they say that this would solve the polling problem. I understand why it would continuously keep looping (its a loop), but i cant understand then why adafruit would say this would simply be the solution to the problem..
J-M-L
mbasile
Ah, I just re-read it, now it makes sense as to what that line of code is allowing to happen. For my case it is essentially pointless.
J-M-L
mbasile
Sometimes it just helps to have someone tell you you're wrong haha
