Topic: expected primary expression before else. (Read 358 times) previous topic - next topic
kevinvalverde98
Dec 10, 2018, 01:43 am Last Edit: Dec 10, 2018, 01:48 am by kevinvalverde98
Hello,
Im doing a school project basing myself in an arduino project found online. My issue is that when I run the code, several errors start to pop up. First, it asks me to write an 'if' before the 'else' that's giving me problems. So, I write the if before the else and then another error pops up and asks me for a '(' before else. I type the '(' before else and then another error pops up which tells me it's expecting a primary-expression before else and that's where I don't know what else to do. I've attached a document with the code and I've highlighted in yellow the section that's giving me trouble.
Delta_G
Code: [Select]
for (int i = 0; i <= 7; i++) // reading 8 pixel { if (tpa.getPoint(i)>29)
 {Serial.print("#");
 Serial.print(" ");
 gesture[i][0]=1;}
 {Serial.print(".");
 Serial.print(" ");
 gesture[i][0]=0;}
There's the first part of your loop.  I see the else.  What if should that else be going with?  else only makes any sense after an if statement.
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
sterretje
#2
Dec 10, 2018, 02:06 am Last Edit: Dec 10, 2018, 02:07 am by sterretje
Attach your ino file, not some stupid PDF.
Code: [Select]
{Serial.print(".");
Serial.print(" ");
gesture[i][0]=0;}
There is no if, you've commented it out. You also commented out the {
Don't put multiple statements on one line. There are a few exceptions where it can be considered acceptable but the below is not one of them
Code: [Select]
for (int y = 0; y<=7; y++){sum+=gesture[y][0];} Serial.println(sum); // sum of 8 pixel
Something like this can be reduced to one line of code ( and not by putting all statements on one line ).
Code: [Select]
switch(n1) {
case 0 : SSD1306_char3216(10, 25, '0', oled_buf); break;
case 1 : SSD1306_char3216(10, 25, '1', oled_buf); break;
case 2 : SSD1306_char3216(10, 25, '2', oled_buf); break;
case 3 : SSD1306_char3216(10, 25, '3', oled_buf); break;
case 4 : SSD1306_char3216(10, 25, '4', oled_buf); break;
case 5 : SSD1306_char3216(10, 25, '5', oled_buf); break;
case 6 : SSD1306_char3216(10, 25, '6', oled_buf); break;
case 7 : SSD1306_char3216(10, 25, '7', oled_buf); break;
case 8 : SSD1306_char3216(10, 25, '8', oled_buf); break;
case 9 : SSD1306_char3216(10, 25, '9', oled_buf); break; }
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
kevinvalverde98
Here's the INO document. Apologies.
CrossRoads
Try it like this
Code: [Select]
    if (tpa.getPoint(i) > 29)
    { Serial.print("#");
      Serial.print(" ");
      gesture[i][0] = 1;
    { Serial.print(".");
      Serial.print(" ");
      gesture[i][0] = 0;
kevinvalverde98
Hello,
I tried the code the way you told me to, and that error is now done with. However, It's now telling me "expected unqualified-id before 'for' " as an error in this code line: for (int y = 0; y<=7; y++){sum+=gesture[y][0];} Serial.println(sum); // sum of 8 pixel.
Delta_G
post the updated code.
You can leave off all those array definitions at the beginning if it will allow you to post the rest inline with code tags.
|| | ||| | || | ||  ~Woodstock
jremington
#7
Dec 10, 2018, 03:08 am Last Edit: Dec 10, 2018, 03:12 am by jremington
This line, and the ones below it, are "waving in the breeze" and not in a function, like setup() or loop().
Code: [Select]
You MUST keep track of your parentheses and brackets. The Arduino editor makes that easy -- if you set the cursor on a paren or bracket it will show you the matching one.
kevinvalverde98
This is the code that's giving the error "expected unqualified-id before 'for' "
 Serial.println(" ");delay(100);   // speed of reading
 //////////////////////////////////////////////////////////////////////////////////////standby
 if (sum==8){sflag=1; Serial.println("standby");}
 else {sum=0;}
 //////////////////////////////////////////////////////////////////////////////////////progress
 if (sflag==1 && sum!=8){
   Serial.println("start gesture");
   gcount=0;
   c=0;
   sum=0;
   while (sum<8)
     {sum=0;
      for (int i = 0; i <= 7; i++) { if (tpa.getPoint(i)>29)
        {Serial.print("#");
         Serial.print(" ");
         gesture[gcount]=1;}
        {Serial.print(".");
         Serial.print(" ");
         gesture[gcount]=0;}
       for (int y = 0; y<=7; y++) {sum+=gesture[y][gcount];delay(5);} // sum of 8 pixel
       Serial.println(" "); delay(50); // speed of reading
       gcount++; // lentgh of gesture
     Serial.print("sum : "); Serial.println(sum);
     Serial.print("lentgh of gesture : "); Serial.println(gcount);
     delay(5);
     for (int c=0; c<=7; c++){
       for (int z=0; z<=gcount; z++)
         {tgesture[c]+=gesture[c][z];delay(5);}
       Serial.println("processing");}
     tgesture[0]+= tgesture[1];
     tgesture[2]+= tgesture[3];
     tgesture[4]+= tgesture[5];
     tgesture[6]+= tgesture[7];
     tgesture[0]+= tgesture[2];
     tgesture[4]+= tgesture[6];
     if (tgesture[0]<tgesture[4])
        { vol+=(gcount/2);     Serial.print("volume up");}
     if (tgesture[4]<tgesture[0])
        {vol-=(gcount/2);   Serial.print("volume down");}
   sflag=0;
   sum=0;
   SSD1306_clear(oled_buf);
   switch (vol)
   { case 1 : SSD1306_bitmap(0, 0,v1, 128, 64, oled_buf); break;
     case 2 : SSD1306_bitmap(0, 0,v2, 128, 64, oled_buf); break;
     case 3 : SSD1306_bitmap(0, 0,v3, 128, 64, oled_buf); break;
     case 4 : SSD1306_bitmap(0, 0,v4, 128, 64, oled_buf); break;
     case 5 : SSD1306_bitmap(0, 0,v5, 128, 64, oled_buf); break;
     case 6 : SSD1306_bitmap(0, 0,v6, 128, 64, oled_buf); break;
     case 7 : SSD1306_bitmap(0, 0,v7, 128, 64, oled_buf); break;
     case 8 : SSD1306_bitmap(0, 0,v8, 128, 64, oled_buf); break;
     case 9 : SSD1306_bitmap(0, 0,v9, 128, 64, oled_buf); break;
     case 10 : SSD1306_bitmap(0, 0,v10, 128, 64, oled_buf); break;
     case 11 : SSD1306_bitmap(0, 0,v11, 128, 64, oled_buf); break;  }
   SSD1306_display(oled_buf);
sterretje
#9
Dec 10, 2018, 03:58 am Last Edit: Dec 10, 2018, 03:58 am by sterretje
He did ;) As attachement.
I've only stripped the arrays (hopefully).
Code: [Select]
#include "Wire.h"
#include "TPA81.h"
#include "ssd1306.h"
#include "DHT.h"
// Create new TPA81 instance
TPA81 tpa;
#define VCCSTATE SSD1306_SWITCHCAPVCC
#define WIDTH     128
#define HEIGHT     64
#define PAGES       8
#define OLED_RST    9
#define OLED_DC     8
#define OLED_CS    10
#define SPI_MOSI   11    /* connect to the DIN pin of OLED */
#define SPI_SCK    13
uint8_t oled_buf[WIDTH * HEIGHT / 8];
int gesture[8][20];
int tgesture[8];
int sum=0;
int sflag; // standby flag
int gcount;
int c;
int ex;
int vol=5;
const uint8_t v1 [] PROGMEM = {
// stripped
const uint8_t v2 [] PROGMEM = {
// stripped
const uint8_t v3 [] PROGMEM = {
// stripped
const uint8_t v4 [] PROGMEM = {
// stripped
const uint8_t v5 [] PROGMEM = {
// stripped
const uint8_t v6 [] PROGMEM = {
// stripped
const uint8_t v7 [] PROGMEM = {
// stripped
const uint8_t v8 [] PROGMEM = {
// stripped
const uint8_t v9 [] PROGMEM = {
// stripped
const uint8_t v10 [] PROGMEM = {
// stripped
const uint8_t v11 [] PROGMEM = {
// stripped
void dsply(int input){
 int n1,n2;
 if (input<10){ SSD1306_char3216(10, 25, '0', oled_buf);
 switch(input)
 { case 0 : SSD1306_char3216(26, 25, '0', oled_buf); break;
 case 1 : SSD1306_char3216(26, 25, '1', oled_buf); break;
 case 2 : SSD1306_char3216(26, 25, '2', oled_buf); break;
 case 3 : SSD1306_char3216(26, 25, '3', oled_buf); break;
 case 4 : SSD1306_char3216(26, 25, '4', oled_buf); break;
 case 5 : SSD1306_char3216(26, 25, '5', oled_buf); break;
 case 6 : SSD1306_char3216(26, 25, '6', oled_buf); break;
 case 7 : SSD1306_char3216(26, 25, '7', oled_buf); break;
 case 8 : SSD1306_char3216(26, 25, '8', oled_buf); break;
 case 9 : SSD1306_char3216(26, 25, '9', oled_buf); break; } }
 { n1=input/10;
 n2=input%10;
 switch(n1) {
   switch(n2) {
 Wire.begin();
 SSD1306_begin();
      Serial.print(" ");
      gesture[i][0] = 1;
      Serial.print(" ");
      gesture[i][0] = 0;
 else {sum=0;}
   gcount=0;
   c=0;
   sum=0;
   while (sum<8)
     {sum=0;
        {Serial.print("#");
         Serial.print(" ");
         gesture[i][gcount]=1;}
        {Serial.print(".");
         Serial.print(" ");
         gesture[i][gcount]=0;}
     delay(5);
   sflag=0;
   sum=0;
   switch (vol)
@kevinvalverde98, in future please use code tags as I did
type [code]
paste your code after that
type [/code] after that
sterretje
#10
Dec 10, 2018, 04:06 am Last Edit: Dec 10, 2018, 04:14 am by sterretje
Next step
properly indent your code using IDE tools -> autoformat.
This is a part of your code after autoformat
Code: [Select]
      Serial.print(" ");
      gesture[i][0] = 1;
      Serial.print(" ");
      gesture[i][0] = 0;
for (int y = 0; y <= 7; y++) {
The for statement starts at the beginning of a line; it that indicates that it's outside a function. Remove the last } before the for so the for statement is part of the loop() function.
kevinvalverde98
It started working! Thank you so much to everyone that helped me. I really appreciate y'all.
sterretje
I can not test as I don't have the specific libraries and you don't say for which board this needs to be compiled.
Please indicate where the lssd1306, tpa81 and dht libraries were downloaded from (or which ones exactly were installed through library manager) if you need further assistance.
This is an updated version of your dsply() function
Code: [Select]
  int n1, n2;
  n1 = input / 10;
  n2 = input % 10;
  SSD1306_char3216(10, 25, n1 + '0', oled_buf);
  SSD1306_char3216(10, 25, n2 + '0', oled_buf);
There is a relationship between numbers and their text representation in the asciitable and the above uses that by simply adding an offset (the character '0').
Now you have it working, you can try / play with that; not tested.
