Topic: HELP!! How to using this scheme Arduino---router---internet---router---Arduino (Read 176 times) previous topic - next topic
totti_dbw
Hello, I have 2 Arduino mega and 2 w5100 ethernet shield, i want both arduino can communication via internet using ethernet shield and wifi router, each example if I push the button at first arduino, the second arduino led will ON, but i have stuck with UDp ethernet send receive didn't work ,anyone have an example?
from ethernet shield to router i use straight LAN cable Cat 6. Thank You
PaulS
With the ethernet shield, the Arduino can act as a client, making requests to servers, or it can act as a server, handling requests from clients.
Which role should each of your Arduinos perform? When you have that sorted out, making the client make a GET request, to have a server turn on an LED, is trivial, as is handling the request on the server.
totti_dbw
Oke, I have change my role to my arduino to be (arduino+ethernet shield w5100) --- LAN Cable --- (arduino+ethernet shield w5100) for simple arduino to arduino communication ( example if I push the button at first arduino, the second arduino led will ON)
I use UDP Send Receive example, but the task can't perform like i want.
I attach UDPSendReceiveString.ino i confused to change the program, because i'm newbie with arduino programming
Can You help me? Thank You
PaulS
Quote
The code does something. You failed to describe what it actually does.
You expect the code to do something. All that hand-waving your are doing is pretty, but useless. FACTS are useful.
