Topic: Who to blame, user, tool or microcontroller? (Read 549 times) previous topic - next topic
sterretje
Dec 10, 2018, 01:13 pm Last Edit: Dec 10, 2018, 01:20 pm by sterretje
In an attempt to help another user, I extracted a part of the code and put it in a stand-alone sketch. This is supposed to give an 8MHz square wave on pin 11 of an Uno
Code: [Select]
#define PIN11
  cli();
#ifdef PIN11
  DDRB |= (1 << 3);//pin 11
  TCCR2A = (1 << COM2A0) | (1 << WGM21) | (1 << WGM20);
  TCCR2B = (1 << WGM22) | (1 << CS20);
  OCR2A = 0;//(F_CPU)/(2*(X+1))
#else
  DDRB |= (1 << 1);//pin 9
  TCCR1A = (1 << COM1A0) | (1 << WGM11) | (1 << WGM10);
  TCCR1B = (1 << WGM13) | (1 << WGM12) | (1 << CS10);
  OCR1A = 0;//(F_CPU)/(2*(X+1))
#endif
I also (last week) acquired a relatively cheap logic analyser (Sparkfun version of Saleae); max 24MHz / samples.
The code seems to work; when enlarging the view, the frequency is 8MHz. But I observe gaps in the output as shown below at roughly every 150us; there is a slight variation.
Question is what possible causes are.
1)
328P processor; I doubt it.
2)
Pulseview / logic analyser; can be.
3)
User who does not know how to work with Pulseview / logic analyser; can't be excluded from the options.
Anybody any thoughts?
The connections are relatively simple. GND to GND with 10cm dupont,
CH0 and CH1 to D9 and D11 via 15cm dupont.
Sorry for the poor quality picture.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
sterretje
The code shows that I'm also trying to user timer1 instead of timer2; it basically exhibits the same behaviour plus something else that I have to check in the datasheet.
pert
I was thinking it was the millis() interrupt but when I changed your sketch to override the core library's main(), the output stayed the same. Then I noticed that when I change the sample rate on PulseView to 24 MHz the gaps disappear (though there is still some smaller variation in the frequency).
The logic analyzer is really a great tool. I got one of the Chinese Saleae Logic 8 clones for free as a promo and it's been really helpful for a couple of projects now.
pert
sterretje
Note that I used cli() in the beginning of setup.
I will have a look at the video tomorrow.
DrAzzy
You're viewing an 8MHz signal with only 16MHz sample rate - I think it's an artifact of the sampling rate. Can you increase the sample rate? I suspect you'll see that you actually have a clean signal if you do.
Interrupts won't interfere with it - it'll work fine with interrupts enabled, it's using hardware output compare.
ATtiny core for 841+1634+828 and x313/x4/x5/x61/x7/x8 series Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts (some assembled), mosfets and awesome prototyping board in my store http://tindie.com/stores/DrAzzy
sterretje
Thanks people for the replies.
@pert, Unless I miss something, I do not think that that is it. I know that the timing can be slightly off and hence can I see e.g. every N pulses a miss. But not every 1200 periods a miss of 80 periods.
@DrAzzy, as far as I can recall, 24Mhz still exhibits the behaviour. I'm aware that I'm working at the limits of what this little logic analyser can do and that 24MHz is not much of an improvement over 16MHz but it's the maximum that is supported. At 24MHz, the duty cycle becomes 66% instead of 50%; that one I can explain ;)
I suspect that this has to do with the transfer from the logic analyser to my Windows 8 system. Just wanted to exclude user error or an abused processor; for the latter I will hook it up to another Uno or a Leo and see.
I will also contact Sparkfun to find out what the memory depth is; I could not find that in the spec. If that's only 2k, it might explain.
Next on the list an oscilloscope with reasonable specs. A 50MHz, 100MS/s will probably do in the AVR environment; correction allowed ;)
pert
sterretje
I'm just not seeing it :( I have no output, he just has a different frequency / duty cycle (if I understand it correctly).
I will keep it on "user error" or "expected equipment behaviour" ;)
Thanks for the efforts.
pert
#9
Dec 11, 2018, 08:44 am Last Edit: Dec 11, 2018, 08:44 am by pert Reason: Embed image
It looks like just the same phenomenon to me. The expected frequency interspersed with periodic gaps:
Anyway, take it or leave it. I don't claim to know what I'm talking about. It's just that I've noticed the same phenomenon myself and remembered seeing the Dave Jones mention this "trap for young players" in a video I watched recently.
sterretje
Quote
I'm not un-thankful; appreciate the help.
Quote
Ah, I see now. Will toy further when I have a chance to play around reducing the generated frequency.
Thanks again.
I'll have to sort something else out as well; might be related to this but also might be related to the use of timer1 instead of timer2. Also generating a 8MHz signal ;)
pert
When you get a chance, give it a try just to be sure. I'm fairly certain we have the same logic analyzer. You'll see them with different stickers but I think they all have the same hardware and firmware inside, copied from the Saleae Logic 8. I get the same output as in the picture you posted at 16 MHz.
sterretje
#12
Dec 11, 2018, 02:43 pm Last Edit: Dec 11, 2018, 02:53 pm by sterretje
Although I'm convinced that I did see the same behaviour yesterday, I did not manage to reproduce today at 24MHz. I've tried several different sample settings.
The only thing noticeable now is the swapping of high and low at occasion what can be explained because the sample time is just slightly of from the 8MHz (or vice versa).
Smajdalf
+1
OP is sampling close to the Nyquist frequency and suffer from aliasing.
Banned forever by Coding Badly for "trolling". Good luck with such attitude.
ChrisTenone
No idea about your problem, but I really dig that rhinoceros table top!
What, I need to say something else too?
