Topic: Arduino MKR Zero destroyed? (Read 724 times) previous topic - next topic
Thomjay
Hello community,
Today I tested some Code on the Arduino MKR Zero, uploaded a few sketches and then suddenly I lost USB connection between Arduino IDE and the Arduino board. The Arduino can not be recognized by the IDE anymore. If I wand to upload a sketch, the IDE says that no board is connected.
To decrease the number of possible error sources, I did the following:
- restarted notebook and IDE (Windows)
- connected Arduino to all my USB ports
- tried another usb cable
- other usb devices run without problems
My sketch tries to establish a connection between the Arduino MKR Zero and a sensor via UART (Serial1) and I tried to receive UART bytes per interrupt (SERCOM5_Handler()). At first I only wanted to log the data on serial monitor (Serial) so that I peeked the UART bytes and printed them to serial monitor. At times the program did the work and I saw sensor data on the serial monitor but one sketch upload then ptobably killed the arduino maybe. Since then the IDE could not reach the board.
My questions are:
- which options are there to rescue the board?
- is it so easy do destroy a board by pure software sketches?
- which options do I have to analyse the fault source?
I hope someone knows the problem and can help me, thanks!
pert
Try this:
  • Start an upload
  • Watch the black console window at the bottom of the Arduino IDE window. As soon as it says something like "Sketch uses 9592 bytes (3%) of program storage space. Maximum is 262144 bytes.", press and release the reset button on the MKRZERO.
Thomjay
Thanks for your reply. I tried your suggestion but without success. No Board can be found by the IDE.
ballscrewbob
Disconnect everything from the board except the USB cable that you know for sure works for upload.
Then "quickly double tap the reset button" That should put it into bootloader mode on a new COM port.
If that fails you could have damaged the board.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
Juraj
the USB is handled by tour sketch (in the part added by the Arduino core). if your sketch fails/hangs then USB is not handled. then the bootloader can do it. after double pressing the reset button the bootloader is active for 10 seconds and you have the port.
You can't write an Arduino sketch if you didn't learn programming. Not the language, but the concepts of programming - algorithms and data types.
Thomjay
#5
Dec 11, 2018, 10:30 am Last Edit: Dec 11, 2018, 10:36 am by Thomjay
Hi I tried your ideas and double clicked the reset button. But it didn't work. Furthermore I don't have access to a COM port.
If the board is damaged, is there a way to check/verify this?
Juraj
#6
Dec 11, 2018, 11:57 am Last Edit: Dec 11, 2018, 11:58 am by Juraj
after the double reset you have the com port for 10 seconds, to upload a working sketch
Thomjay
No I don't have the com port. I wanted to upload an empty sketch to override the fault sketch with your method. But after double resetting the IDE didn't offer a COM port for 10 seconds. Uploading the sketch without choosing a COM port during the 10 seconds also fails.
Juraj
try to start the upload and then the double reset.
Thomjay
I already did. Before, during and after upload, I think device is dead.. But I don't know the reason. I hope the next Arduino won't get damaged too...
ballscrewbob
When you say you dont have a COM port are you using windows 10 ?
If so some versions of windows 10 HIDE the COM ports and you need to re-enable the display in device manager using the SHOW HIDDEN DEVICES.
Some further help HERE
Thomjay
Yes I'm using windows 10.
But now I could test it with a second board (arduino micro). With the same USB cable at the same notebook I could upload a sketch without any problems. So I estimate the MKR Zero is dead. I must wait for a new MKR Zero a few days to upload my sensor sketch. But next time I won't use the SERCOM5_Handler() to receive any byte per interrupt. Instead I try to solve the problem with polling in serialEvent(). I'm not sure but I think it has something to do with it. Another thing could be that the sensor killed the Arduino..
ballscrewbob
What you haven't said is what happens in device manager ?
Does windows device manager show anything at all not necessarily a com port but a failed device of some sort ?
Does windows make the HARDWARE FOUND noise at all ?
If you have access to a good JTAG device you could try to reset the device and replace the bootloader.
Thomjay
#13
Dec 11, 2018, 07:08 pm Last Edit: Dec 11, 2018, 07:10 pm by Thomjay
in device manager nothing happened when using the MKR Zero. I deleted after your post all entries with COM ports. After connecting the device manager didn't change anything, no failed device or something like that. There was also no hardware sound after plug in.
With the new arduino micro, there is hardware sound and two new entries in device manager:
- Arduino Micro (COM3)
- Arduino Micro bootloader (COM4)
I don't have a JTAG device or another programmer, so replacing the bootloader is no option.
