Loading...
Pages: [1]   Go Down
Author Topic: Optiboot Atmega 88 16mhz works fine, no luck with 8mhz@3v3  (Read 1153 times)
UK, Bristol
Offline Offline
Newbie
Arduino are Fun, pity i'm so dim :)
View Profile
Hi
Well i'v built 1 atmega88 16mhz 5v based on sparks mini pro. Bad picture, looks much better in person and smaller ...honest smiley
Well having no luck compiling http://code.google.com/p/optiboot/source/browse/#hg%2Foptiboot%2Fbootloaders%2Foptiboot
Code:
D:\WinAVR-20100110\optiboot\New folder>make atmega88
makefile:328: *** target pattern contains no `%'.  Stop.
I've nearly completed 8mhz 3v3 so that would be next 'help' i'll need smiley
Thanks, Phil
« Last Edit: April 25, 2011, 02:02:35 pm by Sadders » Logged
UK, Bristol
Offline Offline
Newbie
View Profile
Well appear to be getting closer.
Found http://www.neonile.com/tutorials/19-electronics-and-robotics/196-atmega8-arduino-bootloader
For which got optiboot source downloaded and i'm able to compile everything but Atmega 88
Code:
D:\WinAVR-20100110\optiboot\optiboot\bootloaders\optiboot>make atmega88
avr-gcc -g -Wall -Os -fno-inline-small-functions -fno-split-wide-types -mshort-c
alls -mmcu=atmega88 -DF_CPU=16000000L   '-DLED_START_FLASHES=3' '-DBAUD_RATE=115
200'   -c -o optiboot.o optiboot.c
200' -Wl,--section-start=.text=0x3e00 -Wl,--relax -nostartfiles -Wl,--gc-section
s -o optiboot_atmega88.elf optiboot.o
d:/winavr-20100110/bin/../lib/gcc/avr/4.3.3/../../../../avr/bin/ld.exe: address
0x3ffa of optiboot_atmega88.elf section .text is not within region text
make: *** [optiboot_atmega88.elf] Error 1
rm optiboot.o
So any thoughts ??
Thanks,Phil
Logged
UK, Bristol
Offline Offline
Newbie
View Profile
well tried un-install/install of winavr still no joy.
Logged
UK, Bristol
Offline Offline
Newbie
View Profile
update so far:
Well i got bootloader running and could upload using Uno without p328 fitted. All fine and good.
But couldn't use my at90usb162 usb>serial just wouldn't talk.
Tried millions of thing ie fixed it till it broke smiley Till finally i cut off mcu and put another on but didn't change anything !!! Bugger. Turned out dragon was at fault...doh.
Well i didn't notice but AVR dragon started to have a problem using ISP. At first thought my fault then pcb everything other but dragon. (if you own one and don't know READ this http://www.aplomb.nl/TechStuff/Dragon/Dragon.html) Simple fix little dirty once broken, still working again now.
Well where i'm at.
Well i can compile code no errors. I found adding
Code:
atmega88: LDSECTION  = --section-start=.text=0x1e00
Now this is one problem i have. I just can't remember what worked.
 Boot flash size 256 words boot address=$0f00
which $0f00(word)*2=0x1e00
Code:
# ATmega88
atmega88: TARGET = atmega88
atmega88: MCU_TARGET = atmega88
atmega88: CFLAGS += '-DLED_START_FLASHES=3' '-DBAUD_RATE=115200'
atmega88: AVR_FREQ = 16000000L
atmega88: $(PROGRAM)_atmega88.hex
atmega88: $(PROGRAM)_atmega88.lst
atmega88_isp: atmega88
atmega88_isp: TARGET = atmega88
atmega88_isp: MCU_TARGET = atmega88
# 2.7V brownout
atmega88_isp: HFUSE = DD
# Low power xtal (16MHz) 16KCK/14CK+65ms
atemga88_isp: LFUSE = FF
# 512 byte boot
atmega88_isp: EFUSE = 04
atmega88_isp: isp
And other problem i have 'Fuses'
I have EXT=0xFC High=0xDD Low=0xFF . 04 EXT/efuse just wouldn't take in studio.
Lockbit=0xCF  LPM/SPM locked other s all open.
I'm using AVR Studio to flash+dragon. When i use avrdude+ 'make atmega88_isp' Get error from 'atmega88_isp: HFUSE = DD' coming out as '0x' on verify.
I've read so much totaly lost as to what right.
Well i did try and make sure hardware was working and as much as i can tell its fine smiley
Used isp to upload blinky and something for serial out put. I can read TX line in IDE using uno.
Thanks, Phil
Logged
UK, Bristol
Offline Offline
Newbie
View Profile
Hi
Well still no luck understanding whats going wrong for me.
Kind thinking something about my setup must be wrong?
And kinda surprised at no comments, have i done something wrong?
Phil
Logged
SF Bay Area (USA)
Offline Offline
Faraday Member
Strongly opinionated, but not official!
View Profile
There's a typo in the makefile on the LFUSE line for mega88:
Code:
it should read
Code:
atmega88_isp: LFUSE = FF
I dug out the atmega88's I bought a while ago for purposes of exploring non-standard cpus.  It turns out that they're the atmega88pa version, so I had additional signature issues because the avrdude distributed with arduino does not know about the 88p.  But after that, and fixing the typo above, and fixing the section_start issue that you found, I was able to burn a bootloader using "make atmega88_isp", got blinking lights on reset, and was able to upload and run sketches...
Logged
UK, Bristol
Offline Offline
Newbie
View Profile
Hi
Thanks for that, typo was a pain. I could change it but ended up Ultraedit to open it then copy&paste into notepad. Changed it a little and added 8mhz (hope got fuses right).
Boards.txt only other think i'm really unsure about
Code:
atmega88o.name=[Optiboot] Arduino NG or older w/ ATmega88 16Mhz
atmega88o.upload.protocol=stk500
atmega88o.upload.maximum_size=7680
atmega88o.upload.speed=115200
atmega88o.bootloader.low_fuses=0xff
atmega88o.bootloader.high_fuses=0xdd
atmega88o.bootloader.extended_fuses=0x04
atmega88o.bootloader.path=optiboot
atmega88o.bootloader.file=optiboot_atmega88_16mhz.hex
atmega88o.bootloader.unlock_bits=0x3F
atmega88o.bootloader.lock_bits=0x0F
atmega88o.build.mcu=atmega88
atmega88o.build.f_cpu=16000000L
atmega88o.build.core=arduino:arduino
atmega888o.name=[Optiboot] Arduino NG or older w/ ATmega88 8Mhz
atmega888o.upload.protocol=stk500
atmega888o.upload.maximum_size=7680
atmega888o.upload.speed=115200
atmega888o.bootloader.low_fuses=0xff
atmega888o.bootloader.high_fuses=0xdd
atmega888o.bootloader.extended_fuses=0x04
atmega888o.bootloader.path=optiboot
atmega888o.bootloader.file=optiboot_atmega88_8mhz.hex
atmega888o.bootloader.unlock_bits=0x3F
atmega888o.bootloader.lock_bits=0x0F
atmega888o.build.mcu=atmega88
atmega888o.build.f_cpu=8000000L
atmega888o.build.core=arduino:arduino
Must admit i've not read much about its format and so on. So must likely wrong
Not been all bad mind i've had some success. But once i started thought get it right and completed so don't have to figure out at later date how did this work again smiley
Where i'm at now. Well re compile Sparks usb/serial bootloader for at90usb162 which worked. Worked fine with 16mhz88 till i locked myself out fixing make file ...bugger. tried to replace mcu but damage pcb so mad dash to rebuild another.
Got 8mhz88 3v3 but can't upload to it. Has bootloader installed, hit reset led flashes.
16mhz 5v crystal appears to be duff worked up till point avrdude changed fuses to use crystal but couldn't read it after that. So minor fix fingers crossed smiley
I'll get ft232 monday so how i fair with that. Thanks again for taking time to put 88 to pcb and sharing your success smiley
So it goes on....
Logged
UK, Bristol
Offline Offline
Newbie
View Profile
Hi
Well i'll have to give up ;( 2 x pcb's and 4 mcu's is my limit. Wanted to use them up but not quite like this..lol
Well i can say Atmega 88 16mhz does work fine. In the zip is very minor change and complied hex.
Thanks, Phil
Logged
Pages: [1]   Go Up
Print
Jump to:
