Topic: how do I get arduino to read black and white? (Read 1 time) previous topic - next topic
I have this idea for a black and white photograph to be scrolled across in front of a sensor which reads the shade of black/white at any point in time and send this data to arduino.
a) what kind of sensor do I need?
b) can this sensor read 'shades' or can it only tell if it's black or white?
If I understand correctly you want to build some sort of greyscale scanner?
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Yes. A greyscale scanner is what I'm after. So I would need to build it? There's nothing already on the market?
Yes, they're called "scanners" or "fax machines".
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
A QTI Sensor can tells shades of gray if you hook it up to an analog pin.  Of you could overkill it and get a Linescan Imaging Sensor that pretty much takes a picture of your picture and saves it.  Or, you could buy a light to frequency IC (TSL230R) and get your math on.
...or you could just scan it.  You've got some options here.
Confirm your email address
Thank you for subscribing!
via Egeo 16
Torino, 10131
