Topic: Arduino uno programming over OTA with ESP8266 (Read 881 times) previous topic - next topic
Juraj
Yes, but it comes nothing when i start the serial monitor ?
it should not print to Serial Monitor. it will communicate with ATmega over Serial.
try to find the network. the name should start "ESP8266-Module".
You can't write an Arduino sketch if you didn't learn programming. Not the language, but the concepts of programming - algorithms and data types.
Juraj
it is possible that the firmware uses ssid and password remembered in esp8266. then it connected to your WiFi network. try the WiFiLink library WiFiWebServer example. but use the WiFiLink library from my repository, not from library Manager.
https://github.com/jandrassy/arduino-library-wifilink
Itsch
i have this libary, the wifi is not in the list i have onther options to find it ?
Itsch
i can search it but its not add, have it an safety type and a password ?
Juraj
#34
Jan 12, 2019, 02:27 pm Last Edit: Jan 12, 2019, 02:30 pm by Juraj
run the example sketch. it doesn't want ssid or password
Itsch
It dosent work i dont find a WiFi Network with the name ESP8266-Module
Juraj
run an example of the WiFiLink library. if WiFiLink is connected to the network, the example will print the IP address
Itsch
Okay ich have do this, and i have the IP adress but what can i do with this to get the WiFi Connection ?
Juraj
if you have an IP address you have a connection. didn't the example print SSID, IP Address and RSSI?
