Topic: Arduino uno programming over OTA with ESP8266 (Read 2585 times) previous topic - next topic
Itsch
'WL_IDLE_STATUS' was not declared in this scope
Juraj
#61
Feb 02, 2019, 05:27 pm Last Edit: Feb 02, 2019, 05:29 pm by Juraj
it is not a complete sketch. only a modified setup() for WiFiLink examples.
You can't write an Arduino sketch if you didn't learn programming. Not the language, but the concepts of programming - algorithms and data types.
Itsch
Okaey, i integrate it in any one Wifi link example sketch? or i save it and drop in the example folder from WiFi Link and Upload the ArduinoFirmwareEsp again ?
Juraj
why would you put in in the example folder? save the modified example to your sketches folder.
why would you upload the firmware? run in Uno the sketch that uses the firmware
Itsch
I Conect the ESP8266 in the Flash mode to the PC and load the ArduinoFirmwareEsp sketch to the Esp8266?
then i conect the Esp8266 in run mode to the arduino uno with RX:6 TX:7, pick any WiFi Link example, integrate the Wifi.begin Sktech from you and load it to the Arduino uno ?
Juraj
what else?
Itsch
Finally the Web Panel works   :)  i´m stupid the only problem was the configuration i pick 4M(1M SPIFFS) but my ESP have 1MB that´s why i must pick 1M(512K SPIFFS)
thank you very mutch for help
Itsch
now work WiFi Link but what must i do for OTA Upload to my Arduino uno ?
you means i only need the dfu libary from you?
i integrate this to my libary folder, Change the GPIO5 in "esp8266-serial-arduinouno-hacked.cpp" to GPIO0,  delet the // from #define MCU_OTA ?
and i need the ArduinoOTA library too ?
Juraj
the esp8266 ArduinoOTA library in firmware is for OTA upload of new version of the firmware.
the dfu library flashes the Atmega328p from outside over Serial so no library for Uno is required.but the reset must be wired
Itsch
only the firmware ? not a sketch ? how can i uploade the sktech ota ?
Juraj
#70
Feb 18, 2019, 09:48 pm Last Edit: Feb 18, 2019, 09:49 pm by Juraj
the dfu library flashes the Atmega328p from outside over Serial so no library for Uno is required. but the reset must be wired
Quote
For OTA with esp8266 module/board/shield, the reset pin of the ATmega must be connected to an ESP GPIO pin. Default in dfu library is GPIO5. You can change it to GPIO0, as it is on pinout header on most ESP modules. Star Otto and Uno WiFi have special setting hardcoded.
https://www.arduino.cc/en/Guide/ArduinoUnoWiFi#toc7
yes, select Uno WiFi if you used the dfu library from the zip linked in README
