Topic: Modbus TCP Client for Kostal Inverter (Read 257 times) previous topic - next topic
MaggoB
I am using Modbus_master_test Software to read several Registers of Kostal Solar Inverter. However it seems that only adress 4003 (Inverter Modbus On) is working properly. If I try to request adress 40005 I get meaningless values in the result array. (any non defined values). If I try to request higher adresses my Lan gets somehow disturbed..
Can anyone help me out?
regards
Markus
Juraj
#1
Dec 12, 2018, 09:50 pm Last Edit: Dec 13, 2018, 11:08 am by Juraj
Kostal has SunSpec Modbus like my Fronius. I don't have time to see to Kostal details now, but you can check my project https://github.com/jandrassy/Regulator
SunSpec registers (I could not find Kostal or general version)
https://www.fronius.com/~/downloads/Solar%20Energy/Operating%20Instructions/42%2C0410%2C2049.pdf
You can't write an Arduino sketch if you didn't learn programming. Not the language, but the concepts of programming - algorithms and data types.
MaggoB
Thanks for quick reply.
I did a test using CAS Modbus Scanner, which works properly
Request UID of Inverter, which shall be the value of Addr 04
Request:
$47 = ID of Inverter
$03 = function code
$04= addr
$01=Number of Bytes
[08:24:28] => Poll: 47 03 00 04 00 01
Response:
$03 = function code
$01=Number of Bytes
$47=Content of register
[08:32:49] <= Response: 47 03 02 00 47
Arduino Code: (Is this correct?)
int regs[100];
const int SMA_UID = 71;
res = modbusRequest(SMA_UID, 40003, 1, regs);
reg[0]=??? //shall be 71??
Juraj
Request:
$03 = function code
$04= addr
$01=Number of Bytes
Response:
$03 = function code
$01=Number of Bytes
int regs[100];
if you want the value of register  "well-known value. 1 Uniquely identifies this as a SunSpec Common Model block" then use address 40002, because addresses in docs are 1 based and the system has them 0 based
MaggoB
Read Out Register 4
Arduino Code:
Serial.print("Error :");Serial.println(res);
if (modbusError(res)) {  return false;}
else  { Serial.print("Register 4003 Content:");Serial.println(regs[0]);}
Kostal Doku
Addr (hex)    Addr (dec)    Description    Unit    Format    N1)    Access    Function Code
0x04                4                   MODBUS Unit-ID  -    U16            1      R/W       0x03
Result Serial Monitor
Error :0
Register 4003 Content:1  (shall be 71 !!)
Juraj
Read Out Register 4
Arduino Code:
Kostal Doku
Error :0
read 0x04 or 0x03 not 40003, if you want the uid register
registers over 40000 are SunSpec register
MaggoB
Hello Juraj,
thanks a lot for your great support. I can read the registers now!!!
Just another related problem: how to convert the 4 byte register into float varaible. See attached screenshot. I would need the float32 value in my code.
Juraj
Hello Juraj,
  uint16_t reg1 = 28310;
  uint16_t reg2 = 16780;
  union {
    uint16_t ints[2];
    float f;
  } int2fUnion;
  int2fUnion.ints[0] = reg1;
  int2fUnion.ints[1] = reg2;
  float f = int2fUnion.f;
MaggoB
thank you very much for your great support
