Topic: {SOLVED}HELP i cant figure out how i use this code for the 4051 multiplexer (Read 191 times) previous topic - next topic
Markf2017
Hello,
im quite new to this so i dont really understand it but im working on a project and i have to read out 8 analog sensors but the arduino that i have to use only has 5 analog pins, so i looked around and i found something called a multiplexer but i cant figure out how i use this. i found some example code but i cant figure out how it works and how i can get my readings for it.
im referring to this example code:
Code: [Select]
 * codeexample for useing a 4051 * analog multiplexer / demultiplexer
 * by david c. and tomek n.* for k3 / malm� h�gskola
 * edited by Ross R.
 * edited by Igor de Oliveira Sá.
int r0 = 0;      //value of select pin at the 4051 (s0)
int r1 = 0;      //value of select pin at the 4051 (s1)
int r2 = 0;      //value of select pin at the 4051 (s2)
int s0 = 2;
int s1 = 3;
int s2 = 4;
int count = 0;   //which y pin we are selecting
void setup(){
  pinMode(s0, OUTPUT);
  pinMode(s1, OUTPUT);
  pinMode(s2, OUTPUT);
void loop () {
  for (count=0; count<=7; count++) {
    // select the bit
    r0 = bitRead(count,0);    // use this with arduino 0013 (and newer versions)
    r1 = bitRead(count,1);    // use this with arduino 0013 (and newer versions)
    r2 = bitRead(count,2);    // use this with arduino 0013 (and newer versions)
    //r0 = count & 0x01;      // old version of setting the bits
    //r1 = (count>>1) & 0x01;      // old version of setting the bits
    //r2 = (count>>2) & 0x01;      // old version of setting the bits
    digitalWrite(s0, r0);
    digitalWrite(s1, r1);
    digitalWrite(s2, r2);
    //Either read or write the multiplexed pin here
i found it on this page: http://playground.arduino.cc/learning/4051
and this is a example of the code where im doing my readings from:
Code: [Select]
int Vibsensor;
int readU1;
int readV1;
int readW1;
int readU2;
int readV2;
int readW2;
int readDC;
Serial.begin(9600);      //Only for debugging
Serial.println("TEST");
readU1 = analogRead(A0);
get_tempU1();
readV1 = analogRead(A1);
get_tempV1();
readW1 = analogRead(A2);
get_tempW1();
readU2 = analogRead(A3);
get_tempU2();
readV2 = analogRead(A4);
get_tempV2();
readW2 = analogRead(A5);
get_tempW2();
readDC = analogRead(A6);
get_tempDC();
Vibsensor = analogRead(A7);
get_Vibration();
delay(8000);
//PowerSupply U1 pin: A0
void get_tempU1()
float tempU1C = readU1 * 0.217226044 - 61.1111111;
float tempU1F = tempU1C + 273.15;
Serial.println("           ");
Serial.println("****PowerSupply U1****");
Serial.println("Temp: ");
Serial.print(tempU1C);
Serial.print(" °C");
Serial.println("Fahr: ");
Serial.print(tempU1F);
Serial.print(" °F");
Serial.println("**********************");
//PowerSupply V1 pin: A1
void get_tempV1()
float tempV1C = readV1 * 0.217226044 - 61.1111111;
float tempV1F = tempV1C + 273.15;
Serial.println("****PowerSupply V1****");
Serial.print(tempV1C);
Serial.print(tempV1F);
void get_Vibration()
//While sensor is not moving, analog pin receive 1023~1024 value
if (Vibsensor < 1022) {
Serial.print("Sensor Value: ");
Serial.println(Vibsensor);
else {
delay(100); //Small delay
//PowerSupply W1 pin: A2
void get_tempW1() {
float tempW1C = readW1 * 0.217226044 - 61.1111111;
float tempW1F = tempW1C + 273.15;
Serial.println("****PowerSupply W2****");
Serial.print(tempW1C);
Serial.print(tempW1F);
//Drive U2 pin: A3
void get_tempU2() {
float tempU2C = readU2 * 0.217226044 - 61.1111111;
float tempU2F = tempU2C + 273.15;
Serial.println("*******Drive U2*******");
Serial.print(tempU2C);
Serial.print(tempU2F);
//Drive V2 pin: A4
void get_tempV2() {
float tempV2C = readV2 * 0.217226044 - 61.1111111;
float tempV2F = tempV2C + 273.15;
Serial.println("*******Drive v2*******");
Serial.print(tempV2C);
Serial.print(tempV2F);
//Drive W2 pin: A5
void get_tempW2() {
float tempW2C = readW2 * 0.217226044 - 61.1111111;
float tempW2F = tempW2C + 273.15;
Serial.println("*******Drive W2*******");
Serial.print(tempW2C);
Serial.print(tempW2F);
//DC Link pin: A6
void get_tempDC() {
float tempDCC = readDC * 0.217226044 - 61.1111111;
float tempDCF = tempDCC + 273.15;
Serial.println("******* DCLink *******");
Serial.print(tempDCC);
Serial.print(tempDCF);
sherzaad
Hello,
Ok, so if you look at a datasheet for the 4015 this is the pin description:
so of the Arduino you wire up E,S1,S2 and S3 to the digital IO and Z to one of the analog inputs.
Your sensors analog outputs to Y0 through Y7 (if using 8 sensors that is)
so in code probably something like this:
Code: [Select]
//define digital pin used to connect to 4051
#define S1 4
#define S2 5
#define S3 6
#define EN 7
uint8_t sensor_select = 0;
  //initialise digital pins
  pinMode(S1, OUTPUT);
  digitalWrite(S1, LOW);
  pinMode(S2, OUTPUT);
  digitalWrite(S2, LOW);
  pinMode(S3, OUTPUT);
  digitalWrite(S3, LOW);
  pinMode(EN, OUTPUT);
  digitalWrite(EN, HIGH);
  Serial.println("READY!");
  uint16_t x;
  digitalWrite(EN, LOW); //enable output Z
  analogRead(A0); //output Z connected to A0
  x = analogRead(A0);
  digitalWrite(EN, HIGH); //diaable output Z
  Serial.print("MUX Input ");
  Serial.print(sensor_select, DEC);
  Serial.print(" selected, readout: ");
  Serial.println(x, DEC); //raw value printed out
  sensor_select = (sensor_select + 1) % 8; //increment selection 0-7 cyclicly
  //update select inputs based on "sensor_select" value
  digitalWrite(S1, (sensor_select & 0x01));
  digitalWrite(S2, ((sensor_select >> 1) & 0x01));
  digitalWrite(S3, ((sensor_select >> 2) & 0x01));
  delay(1000); //loop updates every second
Markf2017
Thank's sherzaad with some modifications i got my code to work
Code: [Select]
#define S1 4
#define S2 5
#define S3 6
#define EN 7
int vibSensor;
  get_tempU1();
  get_tempV1();
  get_tempW1();
  get_tempU2();
  get_tempV2();
  get_tempW2();
  get_tempDC();
 get_Vibration();
//PowerSupply U1 pin 0
void get_tempU1()
  uint16_t x;
  sensor_select = 0;
  x = analogRead(A0);
  float tempU1C = x * 0.217226044 - 61.1111111;
  digitalWrite(EN, HIGH); //disable output Z
//PowerSupply V1 pin 1
void get_tempV1()
  uint16_t x;
  sensor_select = 1;
  x = analogRead(A0);
  float tempV1C = x * 0.217226044 - 61.1111111;
//PowerSupply W1 pin 2
void get_tempW1() {
  uint16_t x;
  sensor_select = 2;
  x = analogRead(A0);
  float tempW1C = x * 0.217226044 - 61.1111111;
//Drive U2 pin 3
void get_tempU2() {
  uint16_t x;
  sensor_select = 3;
  x = analogRead(A0);
  float tempU2C = x * 0.217226044 - 61.1111111;
//Drive V2 pin 4
void get_tempV2() {
  uint16_t x;
  sensor_select = 4;
  x = analogRead(A0);
  float tempV2C = x * 0.217226044 - 61.1111111;
//Drive W2 pin 5
void get_tempW2() {
  uint16_t x;
  sensor_select = 5;
  x = analogRead(A0);
  float tempW2C = x * 0.217226044 - 61.1111111;
//DC Link pin 6
void get_tempDC() {
  uint16_t x;
  sensor_select = 6;
  x = analogRead(A0);
  float tempDCC = x * 0.217226044 - 61.1111111;
//Vibration sensor pin 7
  uint16_t x;
  sensor_select = 7;
  vibSensor = analogRead(A0);
  if (vibSensor < 1022) {
    Serial.println(vibSensor);
  else {
UKHeliBob
It looks like you could reduce the number of functions in the program by passing the sensor number as a parameter and returning the value read to the calling program
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
sherzaad
some modifications huh! ;)
but as @UKHeliBob mentioned you could have made a better job at coding and reduce a LOT of repetition.
but for a newbie, that was a good effort! :)
