Topic: Measuring LED pulses (Read 198 times) previous topic - next topic
HamsterG
Ok so i asked a similar question the other day, but admittedly I worded it very poorly.I want to measure the amount of time an led is on for.So imagine that i have 2 arduinos and one is simply turning an led on and off for random amounts of time, and i have a second arduino, i want to use this second arduino to measure the length of each pulse and then print this value to serial monitor
Any help would be greatly appreciated, Thanks in advance!
UKHeliBob
Save the value of millis() when the LED turns on.
Save the value of millis() when the LED turns off
The difference is the pulse length
Are the two Arduinos connected in any way ?
Do you actually need to use two Arduinos ?
HamsterG
#2
Dec 14, 2018, 03:06 pm Last Edit: Dec 14, 2018, 03:12 pm by HamsterG
No I dont need to use 2, i just need to be able to measure the length of time an led is on for.
So how would i go about using millis() to do this then?
LandonW
When digitalwrite is high you'll need a variable to attach the current millis value to and same for when digitalwrite is low.  Then subtract those two values.
HamsterG
so here are a few things ive done but im strggling still:
x = millis();
s();
y = millis();
xy = x - y;
test();
void test() {
  if((xy > 4999) &&
    (xy >= 5255))
  {Serial.print(".");
  }else{
    Serial.print("-");}
But it only ever prints "-", why is that?
LandonW
 X = millis
StartTime = X
EndTime = Y. (However, still X because X is a "time stamp variable" but the value has changed with millis.
So
EndTimeX - StartTimeX = duration
HamsterG
X = millis
StartTime = X
So
Sorry i don't quite follow your code, how do you declare all these variables
LandonW
Unsigned Long TimeNow;
Unsigned Long StartTime;
Unsigned Long EndTimd;
TimeNow = millis();
//When LED gets turned on
StartTime = TimeNow;
//When LED gets turned off
EndTime = TimeNow;
EndTime - StartTime = duration.
Post the code that you have.
HamsterG
This is the part that matters:
long time;
long x;
long y;
long xy;
int ledPin = 13;
time = millis();
pinMode(ledPin, OUTPUT);
x = millis();
s();
y = millis();
xy = x - y;
test();
x = millis();
o();
y = millis();
xy = x - y;
test();
x = millis();
s();
LandonW
The line right after loop is part of the problem. You need time = Millis
You listed time in the globals but didn't use it.
Also use Unsigned Long. Long lets you use negative numbers and we don't need that to measure time.
UKHeliBob
What do those mysterious functions that you have not posted do ?
What is it that is turning the LED on and off ?
Why don't you use descriptive names for your variables ?
LandonW
I suspect that measuring how long an LED was on is not the actual project... I could be wrong though.
posting the true and full code using code tags would be extremely beneficial.
Wawa
  if(xy > 4999 && xy >= 5255) // why that
It says "if xy is more than 4999 and more than 5254"
The second test seems useless.
Leo..
