A quick update:
I started playing around a bit more and fixed the problem. It seems that i needed to drop the comma after the sensor request (dht.temperature) instead of (dht.temperature, 1). I'm not sure why that matters. I'm getting serial prints using the previuos codes.
Sorry, missed a comment in between.
I'm pretty sure I'm sampling every thirty seconds. However, I just realized that my code is getting the data several times in each iteration. I'd think that this would simply get the old values, but perhaps not. I've done some code revisions. I also changed the temperature format to the US standard Fahrenheit, to allow my girlfriend to use the system.
Right now the system is working. I'm still getting checksum errors at about half the rate.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
* Sensors: DHT22 dataline connected to pin 7. Suggested 4.7k Pull-up used
Analog Pin 0 is a photocell to detect light levels
Analog Pin 1 is a motion sensor
* Based on code:
* Created 22 April 2011
* By Jeffrey Sun
* http://code.google.com/p/pachubelibrary/
* and
* robtillart
* http://arduino.cc/forum/index.php/topic,58531.0.html
* http://arduino.cc/playground/Main/DHTLib
#include <dht.h>
#include "ERxPachube.h"
#include <Ethernet.h>
#include <SPI.h>
dht DHT;
#define DHT22_PIN 7
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x21, 0xE3 };
byte ip[] = { 192, 168, 1, 20 }; // no DHCP so we set our own IP address
float TempC = (DHT.temperature, 1);
float Humidity =(DHT.humidity, 1);
float TempF;
float OldTemp = TempF;
float OldHumidity = Humidity;
#define PACHUBE_API_KEY "Your API Key HERE" // fill in your API key PACHUBE_API_KEY
#define PACHUBE_FEED_ID 34665 // fill in your feed id
ERxPachubeDataOut dataout(PACHUBE_API_KEY, PACHUBE_FEED_ID);
void PrintDataStream(const ERxPachube& pachube);
Ethernet.begin(mac, ip);
dataout.addData(0);
dataout.addData(1);
dataout.addData(2);
dataout.addData(3);
Serial.println("+++++++++++++++++++++++++++++++++++++++++++++++++");
float fSensorData = 15.23;
int chk = DHT.read22(DHT22_PIN);
switch (chk)
case 0: Serial.print("OK,\t"); TempC = (DHT.temperature); Humidity = (DHT.humidity); break;
case -1: Serial.print("Checksum error,\t"); break;
case -2: Serial.print("Time out error,\t"); break;
default: Serial.print("Unknown error,\t"); break;
// DISPLAY DATA
//Temp = (DHT.temperature, 1);
//Humidity = (DHT.humidity, 1);
//int(Temp);
//int(Humidity);
//Serial.print(Temp);
//Serial.print(",\t");
//Serial.println(Humidity);
TempF = float((TempC * float(1.8))+32);
//Serial.print(DHT.humidity, 1);
//Serial.println(TempC);
//Serial.println(TempF);
dataout.updateData(0, analogRead(0));
dataout.updateData(1, analogRead(1));
//dataout.updateData(2, (DHT.temperature,1));
//dataout.updateData(3, (DHT.humidity,1));
dataout.updateData(2, TempF);
dataout.updateData(3, Humidity);
int status = dataout.updatePachube();
Serial.print("sync status code <OK == 200> => ");
Serial.println(status);
PrintDataStream(dataout);
OldTemp = TempF;
delay(30000);
unsigned int count = pachube.countDatastreams();
Serial.print("data count=> ");
Serial.println(count);
Serial.println("<id>,<value>");
for(unsigned int i = 0; i < count; i++)
Serial.print(pachube.getIdByIndex(i));
Serial.print(",");
Serial.print(pachube.getValueByIndex(i));
Serial.println();
The statement "float TempC = (DHT.temperature, 1); " makes little sense,
You copied it from : Serial.println(DHT.temperature, 1); where it means print the float DHT.temperature with one decimal You cannot copy that into an assigment,
Here a patched (& stripped) version of your code, not tried as I don't have the pachube lib and sensor nearby to rebuild your sketch.
Let me know how it works...
#include <dht.h>
#include <SPI.h>
dht DHT;
#define DHT22_PIN 7
byte mac[] = {
byte ip[] = {
float TempC = 0;
float Humidity = 0;
float TempF = 0;
float OldTemp = 0;
float OldHumidity = 0;
dataout.addData(0);
dataout.addData(1);
dataout.addData(2);
dataout.addData(3);
switch (chk)
case 0:
TempC = DHT.temperature;
Humidity = DHT.humidity;
break;
case -1:
break;
case -2:
break;
default:
break;
OldTemp = TempF;
delay(30000);
Serial.print(",");
Serial.println();
robtillaart,
Thank you very much!
I'm in the process of trying to reduce the number of erroneous readings with the DHT22 sensor. It seems that a 1 in 10 error rate is something to actually shoot for. Some of my test runs are scoring an error rate of closer to 4 in 10 or higher.
Has anyone had any success reducing the error rate with this sensor? I've placed the filter capacitor across the power and ground pins, but that didn't seem to have much of an effect.
More of an update:
I added in batch of code that records how often the system is getting Checksum errors. I then left the system running while I went to sleep. Lo and Behold, the error rate is consistently 45%, and I'm frequently getting abberant readings of ~55f (~12c). The room is clearly not that cold.
I know you're not supposed to check the sensor more often than every 2 seconds. I rewrote robtillaart's code a little bit (Which is like having a 4th grader trying to follow Da Vinci, his code is much more succinct):
#include <dht.h>
#include <SPI.h>
dht DHT;
#define DHT22_PIN 7
byte mac[] = {
byte ip[] = {
float TempC = 0;
float Humidity = 0;
float TempF = 0;
float OldTemp = 0;
float error = 0;
float run = 0;
float errorPerc = 0;
#define PACHUBE_API_KEY "Your API Here" // fill in your API key PACHUBE_API_KEY
dataout.addData(0);
dataout.addData(1);
dataout.addData(2);
dataout.addData(3);
delay(10000);
switch (chk)
case 0:
//Humidity = DHT.humidity;
break;
case -1:
error = error +1;
break;
case -2:
break;
default:
break;
if (TempF > 150)
TempF = OldTemp;
delay(20000);
int chk2 = DHT.read22(DHT22_PIN);
delay(10000);
switch (chk2)
case 0:
//TempC = DHT.temperature;
break;
case -1:
error = error + 1;
break;
case -2:
break;
default:
break;
if (Humidity > 101)
Humidity = OldHumidity;
if (TempF < 150)
OldTemp = TempF;
if (Humidity < 101)
run = run+2;
errorPerc = error / run;
Serial.print(errorPerc);
Serial.println("% errors");
delay(20000);
Serial.print(",");
Serial.println();
I'm trying to send information my environmental conditions to Pachube every minute. That's the goal.
I'm wondering about the requests to the sensor. The
and subsequent "case" check, is that a request from the sensor?
When I'm asking the sensor for the current humidity and temperature, are those two different requests? Should I space these out as much as possible? (This is what I did in the code above).
Or does the
request call all the sensor information, and load it into the Arduino memory, waiting for the DHT.temperature and DHT.humidity calls?
Does anyone else have a similar error rate? That's what I'm really trying to drive down.
The read22() call tries to read data from the sensor and fills the variables DHT.temperature and DHT.humidity. The return value tells if something went wrong during that "exercise". Some people work with the "good weather" scenario and leave out all the checks, that's a design choice.
NO, if you do a read22() both temperature and humidity are read. They can be obtained by reading the members DHT.temperature and DHT.humidity
Or does the
Yes, if you dive into the code of the library (don't be afraid , you see that temp and humidity are both filled in the read22() call.
MY errorrate with this sensor was definitely lower, no figures at hand.
I've posted on the retailer's website. I'll let you folks know what develops.
Thanks again!
Hi Terry, i´m new with Arduino and my first project is building a temperature-regulator. just i see your project and take parts from your code, but i can not see negative values on my display. have you got an idea, which part i must change? Sorry, i´m newbie and my english is not the best, but i hope, you or everyone can help...
thank you
olli
Basierend auf einen Artikel auf dieser Seite:
http://arduino-info.wikispaces.com/PROJECT-Temp-Humidity-Display
den aktuellen Stand findest Du hier:
http://alturl.com/rpods
/*-----( Import needed libraries )-----*/
#include <dht11.h>
#include <Wire.h>
#include <LiquidCrystal.h>
/*-----( Declare objects )-----*/
LiquidCrystal lcd(8, 9, 4, 5, 6, 7); //##### DFRobot LCD Keypadshield V1.0
// legt die pins auf dem shield fest
/* begin des tastatur-bereichs */
int lcd_key = 0; // legt nutzung der tasten fest und dann die tasten selber
int adc_key_in = 0;
#define btnRIGHT 0
#define btnUP 1
#define btnDOWN 2
#define btnLEFT 3
#define btnSELECT 4
#define btnNONE 5
/* ab hier: einlesen der werte der tasten (wiederstands gebilde mit
unterschiedlichen spannungswerten zu jeder taste...*/
int read_LCD_buttons()
adc_key_in = analogRead(0); // read the value from the sensor
// my buttons when read are centered at these valies: 0, 144, 329, 504, 741
// we add approx 50 to those values and check to see if we are close
if (adc_key_in > 1000) return btnNONE; // We make this the 1st option for speed reasons
since it will be the most likely result
if (adc_key_in < 50) return btnRIGHT;
if (adc_key_in < 195) return btnUP;
if (adc_key_in < 380) return btnDOWN;
if (adc_key_in < 555) return btnLEFT;
if (adc_key_in < 790) return btnSELECT;
return btnNONE; // when all others fail, return this...
/* das wars mit dem tastatur-bereich */
dht11 DHT11;
/*-----( Declare Constants, Pin Numbers )-----*/
#define DHT11PIN 2
float alarmwert (20);
void setup() /*----( SETUP: RUNS ONCE )----*/
lcd.begin(16,2); //##### Display Size for DFRobot LCD Keypadshield V1.0
lcd.home ();
lcd.println ("Olliduino "); //##### schreibe willkommensnachricht und springe eine zeile weiter
lcd.setCursor (0,1);
lcd.print ("2011 by olli "); //##### schreibe willkommensnachricht
lcd.home ();
delay(3000);
lcd.clear ();
}/*--(end setup )---*/
void loop() /*----( LOOP: RUNS CONSTANTLY )----*/
// digitalWrite(13, HIGH);
int chk = DHT11.read(DHT11PIN);
Serial.println("---------------------------"); //der Lesbarkeit erstmal eine Zeile
switch (chk) // teste, ob ueberhaupt daten fliessen
case 0: Serial.println("DHT11 ist OK");
Serial.print ("gelieferter Wert: ");
Serial.println ((float)DHT11.temperature,1);
break;
case -1: Serial.println("Checksum error"); break;
case -2: Serial.println("Time out error"); break;
default: Serial.println("Unknown error"); break;
Serial.print((float)alarmwert, 1);
Serial.println("C Darunter-Gibt-es-ALARM-Temperatur");
Serial.print((float)DHT11.temperature,1);
Serial.println("C IST-Temperatur");
if ( DHT11.temperature < alarmwert )
Serial.println("### !!! Alarm erreicht !!! ###");
lcd.setCursor (15,0); //##### schreibe ab zeichen 14 in zeile 1 (zeile 1 ist gleich 0)
lcd.print("!");
digitalWrite(13, LOW);
Serial.println("Alarm nicht erreicht, alles OK");
lcd.print("*");
//lcd.noAutoscroll();
lcd.print(alarmwert,0);
lcd.print("Cs ");
lcd.print((float)DHT11.temperature,1);
lcd.print("Ci ");
lcd.print((float)DHT11.humidity,1);
lcd.print("%");
// jetzt lesen wir noch die tasten ein und machen was draus
lcd_key = read_LCD_buttons(); // read the buttons
switch (lcd_key) // depending on which button was pushed, we perform an action
case btnRIGHT:
lcd.setCursor (0,0);
lcd.print("> ");
break;
case btnLEFT:
lcd.print("<");
break;
case btnUP:
alarmwert = alarmwert + 1;
lcd.print("^");
break;
case btnDOWN:
alarmwert = alarmwert - 1;
lcd.print("v");
break;
case btnSELECT:
lcd.print("*");
break;
case btnNONE:
lcd.print(" ");
break;
/* --(end main loop )-- */
updated the code to support Arduino 1.0 - as allways comments still welcome
Hi Rob,
Thank you so much for writing such an easy to use library!
I wanted to ask you a question if I may -
I'm using the DHT-11,
I tried supplying it with different voltages (3V, 3.3V, 5V - using the
Arduino Uno's 3V,5V and the Arduino Fio's 3.3V power supply)
and for each voltage there are different readings for the temperature and humidity (a
very big difference between 3V and 5V).
what is the correct voltage that it should be supplied with?
(or is there a way to work around this?)
according to the datasheet it can be supplied with 3V - 5.5V.
thanks!
you may,
what is the correct voltage that it should be supplied with?Ac
As you say according to the datasheet, any voltage between 3 and 5.5V should work. I only can confirm that the readings makes good sense at 5Volt.
External powersupply for the sensor? does also make sense if the sensor is a bit further away, long wires.
If you use 3.5 volt and you take longer delays between the readings, does the accuracy of the reading increase?
I just wanted to say THANK YOU for all of the work! I just received a Freetronics Eleven and the DHT22 sensor. I tried the Library suggested, but just kept getting error during the compile process. And then I found your tutorial!!! Although it took me a bit to figure out how to create the Library from your work, once I did, everything started working. Now I am trying to figure out how to combine the Dew Point and C to F conversion from the DHT11 sketch with the DHT22 sketch so I can have the most information from just the one sketch.
Thanks again,
Hi all,
At first I want to thank you for the library. Very nice and succint.
However, I noticed that in about 50% of all cases I'm getting a checksum error. This happens both, using 3.3V or 5V power supply.
Does anyone now whether this is a hardware problem (low cost sensor?) or a timing problem while retrieving the data from the sensor?
I read that someone else also had this problem. Any solution? Typical situation :
DHT22, Checksum error, 48.7, 1665.4
DHT22, Checksum error, 48.1, 846.2
DHT22, OK, 48.5, 27.0
DHT22, Checksum error, 48.4, 846.2
DHT22, OK, 48.3, 27.0
Thanks for any help!
Any solution?
You might need a pull up resistor (eg 4K) between +5V and the dataline.
How long is the line between the arduino and the sensor?
Rob
updated the code to 0.1.03;
- added code to reflect faulty reading in temperature (-999) and humidity (-999) if there is a timeout. So if a sketch does not test the return value of read11() or read22() you will still see it clearly.
As allways comments still welcome
One suggestion for the code is to replace or augment the read11 and read22 routines by one unique read routine that would detect which one it is and return 11 or 22 in chk.
I'm not sure it is so easy, but for example, having both [2] and [4] zero with a DHT22 should almost never happen, right ?
They are the lsB if I get it right, so humidity has to be 25.6, 51.2 or 76.8 for byte[4] to be zero.
Then in that case temperature has to be precisely 25.6 etc.
Pretty unusual.
To be even more confident, there could be a "confidence" variable based on previous measurements:
increase/decrease a uint8_t counter for every non/zero value with saturation @ +127/-128, so DHT11 goes from zero @reset to -128 and DHT22 to +127.
Another thing is to replace the double by an int in tenths of degrees. So for DHT11 it would return array[0]*10;
Don't mix error state with configuration information. That said, one could make a function int determine() that does just that. Typically it is called just once and remembered - you just needs one byte to keep the 11/22 flag of 8 sensors.
possible but one could only account readings for which [2] and [4] are zero AND the checksum is OK.
Assuming a valid reading, both numbers have one decimal place 0..9 =>10 possible values. This implies that the chance would be about one in hundred for an individual reading to have two 0's as decimal. That is a small chance but too big imho to make a reliable determine() function, it is definitely not deterministic. Multiple readings with will improve this number but as the device needs 2 seconds between readings so determine() function becomes quite time consuming.
Note that especially for the DHT11 one can use a (running) average to get a higher precision - and thus decimal places ).
Hi robtllaart
robtillaart:
I would change the follow code in read22() and read11() functions from
int rv = read(pin);
if (rv != 0)
to
int rv = read(pin);
if (rv != DHTLIB_OK)
No functionally change but improves readability.
That is very keen eye! I will change it asap
Thanks,
Rob
updated on the playground to version 0.1.04
- added the rv != DHTLIB_OK as suggested by jrbenito (thanks)
- added #define DHTLIB_INVALID_VALUE -999 to remove that magic number from the lib too.
Rob
