Pages: 1 2 [3]   Go Down
Author Topic: Class for both DHT11 and DHT 22 (temperature & humidity)  (Read 18966 times)
Netherlands
updated the code to 0.1.03;
+ added code to reflect faulty reading in temperature (-999)  and humidity (-999)  if there is a timeout. So if a sketch does not test the return value of read11() or read22() you will still see it clearly.
As allways comments still welcome
« Last Edit: July 09, 2012, 01:54:38 pm by robtillaart » Logged
Rob Tillaart
Belgium
Just Do it (with Arduino of course)
One suggestion for the code is to replace or augment the read11 and read22 routines by one unique read routine that would detect which one it is and return 11 or 22 in chk.
I'm not sure it is _so_ easy, but for example, having both [2] and [4] zero with a DHT22 should almost never happen, right ?
They are the lsB if I get it right, so humidity has to be 25.6, 51.2 or 76.8 for byte[4] to be zero.
Then in that case temperature has to be precisely 25.6 etc.
Pretty unusual.
To be even more confident, there could be a "confidence" variable based on previous measurements:
increase/decrease  a uint8_t counter for every non/zero value with saturation @ +127/-128, so DHT11 goes from zero @reset to -128 and DHT22 to +127.
Another thing is to replace the double by an int in tenths of degrees. So for DHT11 it would return array[0]*10;
Netherlands
Don't mix error state with configuration information. That said, one could make a function int determine() that does just that. Typically it is called just once and remembered - you just needs one byte to keep the 11/22 flag of 8 sensors.
possible but one could only account readings for which [2] and [4] are zero AND the checksum is OK.
Assuming a valid reading, both numbers have one decimal place 0..9 =>10 possible values. This implies that the chance would be about one in hundred for an individual reading to have two 0's as decimal. That is a small chance but too big imho to make a reliable determine() function, it is definitely not deterministic. Multiple readings with will improve this number but as the device needs 2 seconds between readings so determine() function becomes quite time consuming.
Note that especially for the DHT11 one can use a (running) average to get a higher precision - and thus decimal places ).
« Last Edit: October 14, 2012, 07:47:49 am by robtillaart » Logged
Rob Tillaart
Hi robtllaart
I would change the follow code in read22() and read11() functions from
int rv = read(pin);
        if (rv != 0)
to
int rv = read(pin);
        if (rv != DHTLIB_OK)
No functionally change but improves readability.
Netherlands
That is very keen eye!  I will change it asap
Thanks,
Rob
Rob Tillaart
Netherlands
updated on the playground to version 0.1.04
+ added the rv != DHTLIB_OK as suggested by jrbenito (thanks)
+ added #define DHTLIB_INVALID_VALUE  -999  to remove that magic number from the lib too.
Rob
Rob Tillaart
Rob
Wow! Very good too.
Thanks for this code and best regards,
Benito.
Niagara Region
Nice library.  However, it does not work correctly for negative temperatures.  I'm using version 0.1.04.  When a negative temperature is measured the class will return DHTLIB_ERROR_CHECKSUM.  The problem is at line 74 in dht.cpp.  Here bits[2] is modified, which makes the checksum calculation incorrect.  There are, of course, many ways to fix the problem.  I have fixed it by changing the code in the following way.
Old Code:
        int sign = 1;
        if (bits[2] & 0x80) // negative temperature
                bits[2] = bits[2] & 0x7F;
                sign = -1;
        temperature = sign * word(bits[2], bits[3]) * 0.1;
New Code:
                temperature = word(bits[2]&0x7F, bits[3]) * 0.1;
                temperature = -1.0 * temperature;
                temperature = word(bits[2], bits[3]) * 0.1;
Thanks for the library, and with this fix it is just perfect for me!
Netherlands
Thanks for this feedback, I'll fix it a.s.a.p.
Rob Tillaart
Netherlands
- http://playground.arduino.cc//Main/DHTLib -
updated the playground article to include the patch above.
Thanks again!
Rob Tillaart
Pages: 1 2 [3]   Go Up
