Topic: Help powering Adrduino UNO and servos from Lithium Ion battery (Read 1 time) previous topic - next topic
blazen
I need some help for my senior design project. The general idea of the design is I am using the Arduino UNO combined with the VRbot voice recognition module to control two linear servos/actuators.
Firgelli L12 -R Linear Servos:
http://store.firgelli.com/l12-r-linear-ser12.html
I used an H-bridge IC L293D and followed the tutorial here to forward and reverse the actuators:
http://luckylarry.co.uk/arduino-projects/control-a-dc-motor-with-arduino-and-l293d-chip/
I have everything working correctly but I need some help on making it portable. I'm using a 7.4V 2200mAh rechargeable lithium ion battery to power everything found below:
Li-Ion 18650 7.4V 2200 mAh Rechargeable Battery module with PCB:
http://www.all-battery.com/li-ion1865074v2200mahrechargeablebatterymodulewithpcb.aspx
How can I safely and correctly power both the servos and Arduino board using just one battery. Can I connect the battery directly to both the servos and Vin of the Arduino? Any help would be great!
zoomkat
You probably need to get a UBEC like below.
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=14310
Google forum search: Use Google Advanced Search and use Http://forum.arduino.cc/index in the "site or domain:" box.
budabob07
Instead of buying a UBEC, just get a $1 lm7805cv and hook it up
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
