Topic: arduino programing error.. HELP>>!!! (Read 772 times) previous topic - next topic
ianfeng
can anyone help me with my programing?
my code is
const int lcdPin = (10,11,12,13,14,15,16);
const int switchpin = 2;
// variables will change:
int switchState = 0;
int potPin = 2;
int buzzerPin = 1;
int greenPin = 11;
int greenbuttonPin = 13;
int bluePin = 9;
int bluetiltPin = 15;
int redPin = 10;
int redbuttonPin = 17;
int yellowPin = 12;
int yellowbuttonPin = 9;
int color =0;
boolean chosen,buttonPushed = false;
long startMillis,previousMillis;
int switchStateGreen,switchStateRed,switchStateBlue,switchStateYellow = LOW;
 // initialize the LCD pin as an output:
 pinMode(lcdPin, OUTPUT);
 // initialize the switch pin as an input:
 pinMode(potPin, INPUT);
 // initialize the green LED pin as an output:
 pinMode(greenPin, OUTPUT);
 // initialize the greenarm button pin as an input:
 pinMode(greenbuttonPin, INPUT);
 // initialize the blue LED pin as an output:
 pinMode(bluePin, OUTPUT);
 // initialize the bluearm tilt pin as an input:
 pinMode(bluetiltPin, INPUT);
 // initialize the red LED pin as an output:
 pinMode(redPin, OUTPUT);
 // initialize the redarm button pin as an input:
 pinMode(redbuttonPin, INPUT);
 // initialize the yellow LED pin as an output:
 pinMode(yellowPin, OUTPUT);
 // initialize the yellowarm button pin as an input:
 pinMode(yellowbuttonPin, INPUT);
void loop(){
 //choose level
 while(!chosen){
   lcd.print("ChooseMode");
   level = analogRead(potPin);
   if (level <300){
     level = 1;
   else if (level >300 && level <600){
     if (wins >5 ){
       level = 2;
     else {
       lcd.setCursor(0,0);
       lcd.print("Beat level 1");
       lcd.setCursor(0,1);
       lcd.print("first!");
   else if (level >600){
     if (wins >10 ){
       level = 3;
     else {
       lcd.setCursor(0,0);
       lcd.print("Beat level 2");
       lcd.setCursor(0,1);
   chosen = true;
 //play levels
 while(level==1){
   level1();
 while(level==2){
   level2();
 while(level==3){
   level3();
void checkButtons(){
 switchStateGreen = digitalRead(greenbuttonPin);
 switchStateBlue = digitalRead(bluetiltPin);
 switchStateRed = digitalRead(redbuttonPin);
 switchStateYellow = digitalRead(yellowbuttonPin);
 if (switchStateYellow == HIGH || switchStateBlue == HIGH ||switchStateRed == HIGH ||switchStateBlue == HIGH) {
   buttonPushed = true;
void level1() {
 lcd.print("Challenge Mode");
 delay(2000);
 lcd.print("ready...");
 //which button? Random colour light up
 //want to select random color
 color = int(random(1,4));
 if (color = 1) {
   //light Green ARM
   startMillis = millis();
   while( startMillis - previousMillis > 1000){
     previousMillis = millis();
     //light green arm
     digitalWrite(greenPin,HIGH);
     lcd.print("green");
     while (!buttonPushed) {
       //check button state;
       checkButtons();
     if (switchStateRed == HIGH ||switchStateBlue == HIGH ||switchStateYellow == HIGH ) {
       lcd.print("incorrect");
       delay(2000);
       digitalWrite(greenPin,LOW);
       wins=0;
     else if (switchStateGreen == HIGH) {
       lcd.print("correct");
       delay(2000);
       chosen = true;
       digitalWrite(buzzerPin,HIGH);
       wins++;
   lcd.print("Missed Green!");
   ///END of Green Section
 if (color = 2) {
   //light Blue ARM
     //light blue arm
     digitalWrite(bluePin,HIGH);
     lcd.print("blue");
       checkButtons();
       delay(2000);
       digitalWrite(bluePin,LOW);
       wins=0;
     else if (switchStateBlue == HIGH) {
       delay(2000);
       chosen = true;
       wins++;
   lcd.print("Missed Blue!");
   ///END of Blue Section
 if (color = 3) {
   //light Red ARM
     //light red arm
     digitalWrite(redPin,HIGH);
     lcd.print("red");
       checkButtons();
     if (switchStateRed == HIGH ||switchStateRed == HIGH ||switchStateYellow == HIGH ) {
       delay(2000);
       digitalWrite(redPin,LOW);
     else if (switchStateRed == HIGH) {
       delay(2000);
       chosen = true;
   lcd.print("Missed Red!");
   ///END of Red Section
 if (color = 4) {
   //light Yellow ARM
     //light yellow arm
     digitalWrite(yellowPin,HIGH);
     lcd.print("yellow");
       checkButtons();
     if (switchStateYellow == HIGH ||switchStateYellow == HIGH ||switchStateYellow == HIGH ) {
       delay(2000);
       digitalWrite(yellowPin,LOW);
       wins=0;
     else if (switchStateYellow == HIGH) {
       delay(2000);
       chosen = true;
       wins++;
   lcd.print("Missed Yellow!");
   ///END of Yellow Section
 //when 5 wins in a row drop the ball out
 if (wins >5){
   digitalWrite(ballSolenoid, HIGH);
   chosen =false;
   level =0;
i had error on
toy_programingggf.cpp: In function 'void loop()':
toy_programingggf:53: error: 'lcd' was not declared in this scope
toy_programingggf:54: error: 'level' was not declared in this scope
toy_programingggf:59: error: 'wins' was not declared in this scope
toy_programingggf:70: error: 'wins' was not declared in this scope
toy_programingggf:85: error: 'level' was not declared in this scope
toy_programingggf:88: error: 'level' was not declared in this scope
toy_programingggf:89: error: 'level2' was not declared in this scope
toy_programingggf:91: error: 'level' was not declared in this scope
toy_programingggf:92: error: 'level3' was not declared in this scope
toy_programingggf.cpp: In function 'void level1()':
toy_programingggf:115: error: 'lcd' was not declared in this scope
toy_programingggf:147: error: 'wins' was not declared in this scope
toy_programingggf:156: error: 'wins' was not declared in this scope
toy_programingggf:186: error: 'wins' was not declared in this scope
toy_programingggf:196: error: 'wins' was not declared in this scope
toy_programingggf:260: error: 'wins' was not declared in this scope
toy_programingggf:269: error: 'wins' was not declared in this scope
toy_programingggf:277: error: 'wins' was not declared in this scope
toy_programingggf:278: error: 'ballSolenoid' was not declared in this scope
toy_programingggf:280: error: 'level' was not declared in this scope
i cant fix this.. pls help..
nickgammon
Why is this a poll, where we can choose between "d", "d" and "d"?
And please use the "code" tag (select your code and hit the # button).
More info:
AWOL
#2
Apr 16, 2011, 10:50 am Last Edit: Apr 16, 2011, 11:01 am by AWOL Reason: 1
I don't think that the compiler error message could be much clearer.
You haven't declared anything called "lcd".
I think there may be a dangerous assumption going on here:
Fortunately, your are lucky, because LOW == 0, which is what got written to all those variables anyway.
(Vote for d - Yay!)
nickgammon
More info:
AWOL
No, not that one!
Good luck with that one.
nickgammon
More info:
