Topic: Bi-direction optocoupler for One-Wire DS18B20 temperature sensors (Read 2877 times) previous topic - next topic
DaveO
Looking to use a number of DS18B20 temperature sensors all linked on the same data line ( with separate power supply - ie.. not in parasite mode )
Can anyone tell me if it is possible to isolate the data line from the sensor to the boards input pin with a 2 way optocoupler ?
If so, what would be the best part number to use ?
gorbs
If I've understood it correctly (*and I stand to be corrected as a noob!) you don't need to isolate the sensors with an external power supply.
You should be able to happily run multiple sensors (in non-parasite mode) in parallel off three wires - shared 5V external on one wire, shared data on another (going to arduino) and shared GND which is tied between the 5V supply and the arduino. You'll still need a 4k7 ohm resistor at the start of the run between data and 5V.
Is there a reason you want to isolate them?
DaveO
It is the shared data to the Arduino pin that I am looking to isolate.  Everything else to & from the board is to be isolated either with transistors, MOSFETs, relays or optocouplers.
With the length of the wires being used, I thought it would be best to isolate all pins.
tkbyd
This question relates to answer in...
http://arduino.cc/forum/index.php/topic,58324.0.html
A "bi-directional opto-isolator" is a difficult concept to grasp in this context
graynomad
#4
Apr 19, 2011, 03:04 pm Last Edit: Apr 19, 2011, 03:09 pm by Graynomad Reason: 1
There are bi-directional I2C transceivers, maybe they will work.
Also look at the ADUM1200/1201/1250/1251
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
