I am trying out the max demo and want to connect an arduino to it using the Analog/Digital MUX Breakout board from Sparkun (
http://www.sparkfun.com/products/9056 )and Andrew Benson's SensorBox.
I cant get it working and was hoping someone could correct my code below, which is modified from his that uses the older 4051 multiplexer. Any ideas what I am doing wrong in the code?
// Code for multiplexing Analog inputs and getting all the others into MaxMSP
//Andrew Benson
//http://pixlpa.com
char analogValue[96];//array of analog values
char current=0;//current position of analog value in array
int digVal;//digital pins bits are packed into a single variable
char imask = 128;//index bytes start with 1
char theEnd = 255;//byte to signal message end to Max patch
//set multiplexer control pins
#define mpinA 5
#define mpinB 6
#define mpinC 7
#define mpinD 8
//bit-packed truth tables per pin CHANGED for THE SPARKFUN BOARD: http://www.sparkfun.com/products/9056
char mpinAmask[8] = {LOW,HIGH,LOW,HIGH,LOW,HIGH,LOW,HIGH};
char mpinBmask[8] = {LOW,LOW,HIGH,HIGH,LOW,LOW,HIGH,HIGH};
char mpinCmask[8] = {LOW,LOW,LOW,LOW,HIGH,HIGH,HIGH,HIGH};
char mpinDmask[8] = {HIGH,LOW,HIGH,LOW,HIGH,LOW,HIGH,LOW};
//select analog channels to multiplex
char is_muxPIN[6] = {1,0,0,0,0,0};//currently just uses A0. change to multiplex other inputs
char muxcount;//variable to store the number of multiplexed inputs
void setup(void) {
digVal=0;
muxcount=0;
for (int i = 0;i<6;i++){
muxcount+=is_muxPIN[i];
for (int i = 2;i<14;i++){
digitalWrite(i,HIGH);//enable pullups
if(muxcount>0){
pinMode(mpinA,OUTPUT);
pinMode(mpinB,OUTPUT);
pinMode(mpinC,OUTPUT);
pinMode(mpinD,OUTPUT);
while (establishContact()==0){delay(100);} //wait for 99 byte
//uses serial.write() to avoid needless symbol creation in MaxMSP
digVal=0; //reset digital value to 0
//read digital pins
for (int i = 0;i<11;i++){
if(muxcount>0){
if((i!=mpinA)&&(i!=mpinB)&&(i!=mpinC)) digVal |= (digitalRead(i+2)<<i);
else digVal |= (digitalRead(i+2)<<i);
//read analog pins
for (int g = 0;g<6;g++){
packValue(g);
char total = current+1;
sendOFF(total);//send everything to Max
current=0;//reset analog value counter
delay(10);//wait 10 milliseconds
//see if someone tried to turn us off:
if(establishContact()==1) {
while(establishContact()==0) {delay(100);}//go into idle mode
void sendOFF(char total){
//Send analog values in the format 0x81 a1 a2.....0xFF
Serial.write(imask|1);
for (int i = 0;i<total;i++){
Serial.write(analogValue[i]);
Serial.write(theEnd);//ends analog stream
Serial.write((imask|2));
Serial.write((digVal&127));
Serial.write(digVal>>7);
Serial.write(theEnd);//ends digital message
//read an analog pin and then pack into low/high bytes
void packValue(int index) {
if(is_muxPIN[index]==1) muxAnalog(index);
else regAnalog(index);
char establishContact(void){
if (Serial.available() > 0) {
char checkup = Serial.read();
if (checkup==99) return 1;
else return 0;
else return 0;
//function for handling multiplexed analog reading
void muxAnalog(char index){
for (int f=0;f<8;f++){
//set the multiplex control pins
digitalWrite(mpinA,mpinAmask[f]);
digitalWrite(mpinB,mpinBmask[f]);
digitalWrite(mpinC,mpinCmask[f]);
delayMicroseconds(50);//allow analog signal to settle
regAnalog(index);
void regAnalog(char index) {
int tempA = analogRead(index);
analogValue[current]=tempA & 127;
current++;
analogValue[current] = (tempA>>7);
current++;
