Topic: CREATING A PROJECT FROM SCRATCH ( PART 1 - Getting Started & LoRa nodes ) (Read 758 times) previous topic - next topic
lastchancename
I've been starting out on a relatively complex project - and decided to document* the development, obstacles, debugging and successes along the way.
The goal is a portable order-capture, food preparation, and annunciator system for small regional catered fairs etc.
Place an order & pay, keep the food pipeline informed, tell the customer it's ready and clear the order & update stock levels.
THE ATTACHED SERIES OF DOCUMENTS OUTLINE THE WHOLE PROJECT IMPLEMENTATION - it may take a while as this is a spare time effort.
PART-1 specifically addresses the starting point, and my first attempt at using LoRa radios - because it was interesting, and I had the parts nearby.
I'm lucky to have an oscilloscope - but it wasn't really necessary - as the issues were either my errors - or typical early development problems!
ATTACHED PDF
* Documentation of your own projects should start the same time you lift the first pencil, part or paper - it can spiral out of control really easily - and will be impossible to undertand or pass-on six months from now!
CONTINUED in PART 2
Experienced responders have a nose for laziness, (they were beginners once)... Sure, there are trolls, know-it-alls, and pretenders - but the help you'll get here is about as good as it gets - if you try to help youself!.
