Topic: One Crazy Sketch (Read 4887 times) previous topic - next topic
Coding Badly
Apr 17, 2011, 08:28 am Last Edit: Apr 17, 2011, 08:31 am by Coding Badly Reason: 1
The hardware...
  • 328P processor on a breadboard.
  • Jumper from pin 3 to pin 8.
The environment...
  • Windows Vista
  • Arduino iDE 0022
  • All libraries removed.
The code...
Code: [Select]
void setup( void )
 Serial.begin( 115200 );
 analogWrite( 3, 127 );
void loop( void )
 static bool DoOnce = true;
 static unsigned Loops;
 if ( DoOnce )
   ++Loops;
   Serial.println( Loops );
   DoOnce = false;
The expected result...
  • A single "1" should be output to Serial.
The actual result...
  • Lots of "1' output to Serial.  (processor resets on its own)
  • Numbers greater than "1" output to Serial.
The question...
  • Can anyone reproduce the problem?  (please try it on any 328 or 168 based board)
sudar
I am setting it up in my breadboard to try it.
Meanwhile are you using an external clock crystal?
Coding Badly
Quote
Thank you!  This thing has been driving me batty.  At this point, my only theory is that the stack is becoming corrupt.  I believe, for the theory to be true, there has to be an interrupt service routine in the mix.  But, I'm down to USART RX (which should never fire) and TIMER0 OVF (which is used in every Arduino application every written).
Quote
16 MHz.  With the exception of no bootloader, it should be functionally equivalent to an Arduino.
udoklein
If you think an ISR is involbed: add CLI() and see if the problem still happens.
Did you already try to disassemble it?
Check out my experiments http://blog.blinkenlight.net
sudar
Well this is strange. For me nothing get's printed in the serial monitor.
I was using Atmega 328P
Coding Badly
Thanks!  Great idea...
Quote
void setup( void )
 cli();
...snip
...this is much worse.  I'm starting to think this processor has been damaged.
Quote
void loop( void )
 cli();
...snip
...this is much better.  But it still fails.
Quote
I did.  I could not find anything suspicious.
I also tried Arduino 0021.  The behaviour is a bit better (less frequent failures; that could be coincidence) but it too fails.
Coding Badly
Quote
What happens if you remove the jumper?
Try putting a 3 second delay at the top of setup.
Coding Badly
For me, the three second delay has made the symptoms much worse.
What the heck is going on!  :0  =(
udoklein
What happens if you remove the analogWrite? What if you remove the jumper? What is you power supply?
Coding Badly
#9
Apr 17, 2011, 10:06 am Last Edit: Apr 17, 2011, 10:12 am by Coding Badly Reason: 1
Problem disappears.
Quote
Problem disappears.
Quote
Powered USB hub.  Consistently provides 5.12 volts.
I've also tried the latest version of WinAVR (20100110).
Coding Badly
Another fun wrinkle.  This seems to behave correctly...
Code: [Select]
#include <avr/io.h>
void HardwareSerial_write(uint8_t c)
  while (!((UCSR0A) & (1 << UDRE0)));
  UDR0 = c;
void HardwareSerial_begin( long baud )
  uint16_t baud_setting;
  UCSR0A = 1 << U2X0;
  baud_setting = (F_CPU / 4 / baud - 1) / 2;
  UBRR0 = baud_setting;
//  UCSR0B |= (1 << RXEN0);
  UCSR0B |= (1 << TXEN0);
void setup( void )
  HardwareSerial_begin( 115200 );
void loop( void )
  if ( DoOnce )
    ++Loops;
    HardwareSerial_write( '*' );
    DoOnce = false;
nickgammon
On a Uno, the problem does not occur.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
nickgammon
The hardware...
What is your wiring, exactly? Maybe put a 0.1uF capacitor there for decoupling.
Coding Badly
Quote
10K resistor from +5 to RESET.  Pushbutton to ground so I can reset the processor.
TX and RX connected to a Pololu AVR Programmer.
0.1uF capacitor across VCC and GND at the processor.
16 MHz crystal + capacitors from Evil Mad Science connected to XTAL pins.
AVCC connected to +5 volts.
Analog side GND connected to ground.
AREF unconnected.
SCK, MOSI, and MISO connected to the Programmer.
I've tried with and without and LED + series resistor on pin 3.
Quote
Across VCC and GND?
Coding Badly
Quote
Thank you for testing!
A single "1" was output?  Anything different if you click the Reset button?
