Topic: building the IDE within Eclipse (Read 286 times) previous topic - next topic
lamikam
I followed the instructions here - https://github.com/arduino/Arduino/wiki/Building-Arduino  and was able to build the ide. I had to install the 32-bit java 1.8 sdk as instructed.  Now, I want to build the IDE project from eclipse 64-bit IDE.  Is that possible?
WizIO
yep, I make all my Arduino ports in Eclipse+CDT and GCC
it is difficult to write instructions how to set eclipse(gcc) options
New C++ project
Project properties:
Set GCC path, folders, libraries search paths, linker script
GCC C and C++ settings... and compile
westfw
Quote
I believe that he's talking about building the IDE itself, not building Arduino Sketches.
That means Java, and perhaps a bunch of other stuff (aren't some pieces written in go, these days?)
I have no idea.  If you really like the Eclipse editor and source-browsing features, I imagine you could get pretty far using the standard Eclipse Java environment, and then still use "ant" in the cli to do the actual (rather complex) build...
