Loading...
Pages: [1]   Go Down
Author Topic: Help with PCF8574 port expander and relay  (Read 979 times)
Canada
Offline Offline
Newbie
View Profile
Can anyone point me to an example of a PCF8574 port expander circuit that controls a number of relays with a coil of 5 volts.  I can get the arduino to control an led without a problem but not a relay.  I'm sure it is because the PCF8574 doesnt have enough juice to activate the coil.
Any help or advise would be greatly appreciated.
Logged
Netherlands
Offline Offline
Sr. Member
A naughty mind is a joy forever.
View Profile
The Playground has a lot of examples how to connect all kinds of stuff.
http://arduino.cc/playground/uploads/Main/relays.pdf
In this example it's assumed the relay is driven by an arduino pin, but you could drive it with an output of the PCF8574 as well.
Logged
Canada
Offline Offline
Newbie
View Profile
Kind of tried that circuit, but probably did something wrong and didn't have the exact components.  Couple guestion I have is what is all the stuff to the right of the diode, and will this work with these parts with the PCF8574?  Or would it need to be modified?  If it will work I'll order the exact parts right now.
« Last Edit: April 17, 2011, 04:06:58 pm by k3v1np » Logged
Netherlands
Offline Offline
Sr. Member
View Profile
That's the relay.
The relay in the circuit is just an... example, many different types exist.
The magnetic coil is connected at "1 & 16" in this circuit. (which may be different on other relays).
At the right side S1, O1 and P1 are connectors of the switch inside the relay.
These may also differ on other relays.
There shouldn't be a difference whether you use an arduino-pin or an output-pin of the pcf8574.
Both drive their pins with 0 or 5 volts.
Logged
Canada
Offline Offline
Newbie
View Profile
I was able to get the example circuit below to work off the arduino pin but not a pin off the PCF8574.
I'm able to blink an LED from a pin off the the PCF8574 by connecting it like this ...
+5 ------- (+)LED(-) ------330 ohm Resistor-------- PCF8574 P0 pin 4
Using the following code ...
Code:
#include <Wire.h>
#define expander 0x20 //expander address with 3 address pins grounded
  Wire.begin();
  expanderWrite(B11111111); //turn all ports high
  expanderWrite(B00000000); //turn all ports low
void expanderWrite(byte _data ) {
  Wire.beginTransmission(expander);
  Wire.send(_data);
  Wire.endTransmission();
I think I understand why its working this way, but please someone correct me if I'm wrong.  When the arduino turns an i/o port high it is sourced to positive and when the PCF8574 turns the i/o port high it sinks it to ground.  (hope my terminology is correct as well).
If my thinking is correct then what do I need to change in order to get the relay circuit above to work with the PCF8574?
Logged
Pages: [1]   Go Up
Print
Jump to:
