Loading...
Pages: [1]   Go Down
Author Topic: Schematics of Arduino using ATMEGA8  (Read 1495 times)
Offline Offline
Newbie
View Profile
Does anybody have a schematics of Arduino using ATMEGA8? Is this arduino work similar to that of Arduino made from ATMEGA328? Please do reply for both ..
Logged
Scotland
Offline Offline
God Member
Have you had your Arduino fix today?
View Profile
WWW
Its the same pin-out as the 168/328. Should work the same, you need to update boards.txt to include the chip.
Drew.
Logged
Drew.
(MyPCB MANUFACTURING SERVICE)
Duemilanove - UNO - Leonardo - Mega 1280 - Mega 2560 - Pro
& Way too many custom boards.
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
http://arduino.cc/en/uploads/Main/arduino_NG_schematic.png
Logged
SF Bay Area (USA)
Offline Offline
Faraday Member
Strongly opinionated, but not official!
View Profile
You can pop an atmega8 directly into any of the modern boards (uno, etc.)  It's completely pin-compatible.
(although some of the pins that say "pwm" on the board won't be, any more.)
Logged
Offline Offline
Newbie
View Profile
Thanx for schematics but can anyone explain these in that circuit?
What's that blank box(top left corner)?
Where this block gets connected to main circuit?
There are 2 Vin( one in power, other in that blank box). What is Vin?( in know its input to circuit) & where should it be connected to the atmega chip?
PWR_SEL(left bottom corner)?
P$1 P$2 (in USB)?
What's X3?
lastly where M8RXD & M8TXD should be connected?
Logged
Offline Offline
Brattain Member
View Profile
That's the external power connector. A 7-12vdc wall wart power module or a battery can plug into that connector if you are going to use external power for the board.
It's shown be wired to the input of the on-board +5vdc regulator via D1 diode. The diode is to protect the board from mistake of applying reverse polarity voltage to the external connector.
Vin is the external voltage (7-12vdc), it wires to two places the input of the voltage regulator (IC2) and pin 1 of the shield power connector. There is no connection directly to the atmega chip as anything over +5vdc would destroy the chip.
That's a jumper connector. You install a jumper clip to connect pin 1 to pin 2 when you want to power the board via the external power. You install the jumper clip to connect pin 2 to pin 3 if you wish to use USB voltage to power the board.
P$1 P$2 (in USB)?
These are connections to the metal shell of the USB connector and wire to ground.
What's X3?
These are trace pads run to the optional I/O pins of the serial converter chip. These I/O pins are not accessible to the Arduino, but with custom PC software one could utilize them.
To pins 1 and 2 of the serial converter chip (U4) to resistors R11 and R12. These are the serial data signals to communicate with the atmega via the USB serial link.
Lefty
« Last Edit: April 19, 2011, 10:36:34 am by retrolefty » Logged
Offline Offline
Newbie
View Profile
I still cant understand about Vin. Please Explain Is that having any specific value?
Is Vin an input to 'Power'? What should i do with Vin?
Are Vin & Vcc 2 separate power sources?
What's r2 100_NM & r3 100_NM? Are they capacitors? What are its values?
What is difference between Vin,Vcc, Power connector?
I connect a 9V battery instead of wall wart module to supply power for it. If I do so should I connect another power source for Vcc?
What is value of Vcc?
Also where is that "shield power connector"?
Logged
Pages: [1]   Go Up
Print
Jump to:
