Loading...
Pages: [1]   Go Down
Author Topic: teensyduino code  (Read 1016 times)
Offline Offline
Newbie
View Profile
I have had an arduino for a year now and just got a teensyduino 2.0.
I am still having a hard time with the code.
I wanted to make a usb controller for my computer it wold have about ten buttons on it.
This is the code I found.
I wonted to add more buttons to the code but I cant.
Can some one help.
const int pinBtnUp = 0;
const int pinLEDOutput = 11;
//Variables for the states of the SNES buttons
boolean boolBtnUp;
  //Setup the pin modes.
  pinMode( pinLEDOutput, OUTPUT );
  //Special for the Teensy is the INPUT_PULLUP
  //It enables a pullup resitor on the pin.
  pinMode( pinBtnUp, INPUT_PULLUP );
  //Zero the SNES controller button keys:
  boolBtnUp = false;
//  //debugging the start button...
  digitalWrite ( pinLEDOutput, digitalRead(pinBtnUp));
  //Progess the SNES controller buttons to send keystrokes.
  fcnProcessButtons();
//Function to process the buttons from the SNES controller
void fcnProcessButtons()
  //Assign temporary values for the buttons.
  //Remember, the SNES buttons are read as active LOW.
  //Capture their status here:
  boolean boolBtnUp = !digitalRead(pinBtnUp);
  if ( boolBtnUp )
    //Set key1 to the U key
    Keyboard.set_key1( KEY_U );
    Keyboard.set_key1( 0 );
  //Send all of the set keys.
  Keyboard.send_now();
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
DOn't have a teensy but assuming that if your code works, this should give you insight how it is done.
(code not tested or compiled)
Code:
const int pinBtnDown = 1;  // assumption pin 1 is the down
boolean boolBtnUp = false;
boolean boolBtnDown = false;
  pinMode( pinBtnDown, INPUT_PULLUP );
  boolBtnDown = !digitalRead(pinBtnDown);
  if ( boolBtnUp )
  if ( boolBtnDown )
    Keyboard.set_key1( KEY_D );
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Newbie
View Profile
Thanks but when I type U or D once they don't stop.
I press the button once and instead of there being one d it does this dddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddd.
111swords
Logged
New Hampshire
Offline Offline
God Member
There are 10 kinds of people, those who know binary, and those who don't.
View Profile
WWW
If you want to be able to handle more than 6 buttons, the code will get a bit more complicated as the USB Keyboard protocol only allows registering up to 6 keypresses at the same time (this is why the Teensyduino keyboard class has six separate methods for issuing a keypress).
Up to 6 buttons can be done fairly easily by duplicating this block of code:
Code:
  if ( boolBtnUp )
up to six times, changing the set_key# function that is called for each one, from set_key1() to set_key6().  As I said at the beginning though, writing code to handle  10 buttons becomes a non-trivial task (and you still would not be able to register more than 6 button presses at any one time)
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Quote
You need to reset the boolean to false when the key is send!
Code:
  if ( boolBtnUp )
    BoolBtnUp = false;
  if ( boolBtnDown )
give it a try
Logged
Rob Tillaart
Offline Offline
Newbie
View Profile
Are you debouncing your inputs (either with hardware or another method?).  Pressing the button "once" it still bounces open and closed for a few milliseconds (perhaps up to a couple hundred)....in a loop that runs in micro seconds this looks like a whole ton of button presses.
http://www.arduino.cc/en/Tutorial/Debounce
This little web video explains this a bit and provides some details on various hardware debouncng strategies.
http://jeremyblum.com/2011/03/07/arduino-tutorial-10-interrupts-and-hardware-debouncing/
Logged
Offline Offline
Newbie
View Profile
I tried BoolBtnUp = false; but they just keep on coming.
This is way harder than I thought. smiley-roll-sweat
Logged
Offline Offline
Newbie
View Profile
Thanks for all of your help I got it to work.
This is my finished code
const int pinBtnDown= 1;
boolean boolBtnUp;
boolean boolBtnDown;
  boolBtnUp = false;
  boolean boolBtnDown = !digitalRead(pinBtnDown);
  if ( boolBtnUp )
    if ( boolBtnDown )
    Keyboard.set_key2( KEY_D );
    Keyboard.set_key2( 0 );
 smiley-grin smiley-grin smiley-grin smiley-grin smiley-grin smiley-grin smiley-grin smiley-grin smiley-grin smiley-grin smiley-grin
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Code:
When you are going to have useless comments, at least they should be correct useless comments...
Logged
Pages: [1]   Go Up
Print
Jump to:
