Global Moderator
UK
Offline
Brattain Member
I don't think you connected the grounds, Dave.
« Reply #15 on: April 18, 2011, 03:07:29 am » |
and the text will get centered in the midle of the LCD, so it gets different yes. I think you may have got into an HTML, not programming, mindset.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline
Newbie
« Reply #16 on: April 18, 2011, 03:11:40 am » |
Well i have to make this and it should work!
But i think i got the problem
Arduino Uno An ATmega328 running at 16 MHz with auto-reset, using the optiboot bootloader (115200 baud, 0.5 KB).
When checking in Bascom AVR what the error rate is.. it is almost 8%.
Can i change it somewhere?
Logged
Offline
Newbie
« Reply #17 on: April 18, 2011, 03:16:40 am » |
I do an Electric, Installatin, Designer and construction education.
Now i have to work for my education and get to learn more than i need.
so ive created all this for an easy work and everyone can program.
Logged
Global Moderator
UK
Offline
Brattain Member
« Reply #18 on: April 18, 2011, 03:18:25 am » |
so ive created all this for an easy work and everyone can program Imagine how much more work you could get done, if you didn't have to do all that typing.
Logged
Offline
Newbie
« Reply #19 on: April 18, 2011, 03:21:28 am » |
I only have to change some values in the HTML page and simply press convert and done.
But i cant get it right now, cus it fails.
Logged
Global Moderator
Melbourne, Australia
Offline
Shannon Member
Lua rocks!
« Reply #20 on: April 18, 2011, 03:26:39 am » |
Centering text at runtime is pretty trivial stuff. When checking in Bascom AVR what the error rate is.. it is almost 8%.
Can i change it somewhere? Can you quote the documentation on that? I only have to change some values in the HTML page and simply press convert and done.
And then what? You deploy these gadgets? I was hoping for a picture of the end-product. Whatever it does. I do an Electric, Installatin, Designer and construction education. That's great that you are doing all this. But if I may humbly suggest, a bit more practice on the programming side before you write HTML code that produces C++ code that runs on a microprocessor.
Logged
Global Moderator
UK
Offline
Brattain Member
« Reply #21 on: April 18, 2011, 03:30:02 am » |
But i cant get it right now, cus it fails Time for a new approach.
Logged
Offline
Newbie
« Reply #22 on: April 18, 2011, 03:41:51 am » |
Can i change it somewhere? Can you quote the documentation on that? Documentation for Error % can be found at: http://www.wormfood.net/avrbaudcalc.phpBAscom AVR has a built-in error shown, just set it to 16MHZ and baudrate you have an the rror % is shown. I only have to change some values in the HTML page and simply press convert and done.
And then what? You deploy these gadgets? I was hoping for a picture of the end-product. Whatever it does. I do an Electric, Installatin, Designer and construction education. That's great that you are doing all this. But if I may humbly suggest, a bit more practice on the programming side before you write HTML code that produces C++ code that runs on a microprocessor. The HTML form only generates the cade ATM. su copy paste compile and upload.
Logged
Netherlands
Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
« Reply #23 on: April 18, 2011, 03:49:16 am » |
Hi Grootvalk, I had a quick look at your code and I think you are running out of variable RAM, an Arduino has only 2K. You need to use functions to eleminate double typing as Nick said. As I am in a very good mood today I did that for you (also to move the discussion forward). The code below is ~100 lines iso 2000(?), it compiles and as far as I can see it does almost the same as yours (the leading zero's in the display are missing). So try this code and let us know if it works for you. Succes, Rob #include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins LiquidCrystal lcd( 7, 6, 5, 4, 3, 2);
int A = 0; int B = 0; int C = 1;
void displayError(int code) { lcd.setCursor (0 , 0 ); lcd.print("Error 01"); lcd.setCursor (0 , 1 ); lcd.print("Code "); lcd.print(code); C = code; }
void setup() { // Define Output pinMode(13, OUTPUT); // sets the digital pin as output LED // Define Input pinMode(A0, INPUT); // input A0 - Bit 0 pinMode(A1, INPUT); // input A1 - Bit 1 pinMode(A2, INPUT); // input A2 - Bit 2 pinMode(A3, INPUT); // input A3 - Bit 3 pinMode(A4, INPUT); // input A4 - Bit 4 pinMode(A5, INPUT); // input A5 - Bit 5 pinMode( 8, INPUT); // input D8 - Bit 6 pinMode( 9, INPUT); // input D9 - Bit 7 // Pull up Resistors digitalWrite(A0, HIGH); // Pull up resistor for A0 - Bit 0 digitalWrite(A1, HIGH); // Pull up resistor for A1 - Bit 1 digitalWrite(A2, HIGH); // Pull up resistor for A2 - Bit 2 digitalWrite(A3, HIGH); // Pull up resistor for A3 - Bit 3 digitalWrite(A4, HIGH); // Pull up resistor for A4 - Bit 4 digitalWrite(A5, HIGH); // Pull up resistor for A5 - Bit 5 digitalWrite( 8, HIGH); // Pull up resistor for D8 - Bit 6 digitalWrite( 9, HIGH); // Pull up resistor for D9 - Bit 7
// set up the LCD's & Company Logo: lcd.begin(40, 2); Serial.begin(9600); }
void loop() { if (A == 0 ) { B = 0; if (digitalRead(14) == LOW){ B = B + 1; } if (digitalRead(15) == LOW){ B = B + 2; } if (digitalRead(16) == LOW){ B = B + 4; } if (digitalRead(17) == LOW){ B = B + 8; } if (digitalRead(18) == LOW){ B = B + 16; } if (digitalRead(19) == LOW){ B = B + 32; } if (digitalRead( 8) == LOW){ B = B + 64; } if (digitalRead( 9) == LOW){ B = B + 128; }
if (B == C) { A = 10; } else { lcd.clear(); A = 5; } } // End A == 0
if (A == 5 ) { displayError(B); // call to function above A = 10; } // End A == 5
if (A == 10 ) { delay(100); Serial.println(); Serial.println(A); Serial.println(B); Serial.println(C); A = 0; } // End A == 10
} // End of Loop
Compiles smoothly => Binary sketch size: 4846 bytes (of a 30720 byte maximum) Thats far less than the 27K --- UPDATE --- If the C++ code is generated from somewhere you must modify the codegenerator accordingly ..
« Last Edit: April 18, 2011, 03:51:37 am by robtillaart »
Logged
Offline
Newbie
« Reply #24 on: April 18, 2011, 03:54:56 am » |
} // End of Loop
Compiles smoothly => Binary sketch size: 4846 bytes (of a 30720 byte maximum) Thats far less than the 27K --- UPDATE --- If the C++ code is generated from somewhere you must modify the codegenerator accordingly .. Thanks for that code, but its just without my error code thins which i must have. with yours i can only use 1 error. but checking out the RAM. Worst case is that i have to send characters manually?
Logged
Netherlands
Offline
Tesla Member
« Reply #25 on: April 18, 2011, 03:59:21 am » |
Thanks for that code, but its just without my error code thins which i must have. What are thins? (I'm not native English, sorry)
Logged
Netherlands
Offline
Tesla Member
« Reply #26 on: April 18, 2011, 04:02:56 am » |
with yours i can only use 1 error. No the function displayError() takes care of all your errors defined with the value B (which is set by means of 8 switches)
Logged
Offline
Newbie
« Reply #27 on: April 18, 2011, 04:04:40 am » |
You mean i must make a lot of Void ?
Logged
Netherlands
Offline
Tesla Member
« Reply #28 on: April 18, 2011, 04:06:09 am » |
Worst case is that i have to send characters manually? Have you tried running my sample code? If so where did it go wrong?
Logged
Netherlands
Offline
Tesla Member
« Reply #29 on: April 18, 2011, 04:07:39 am » |
You mean i must make a lot of Void ? Don't understand your question.. please rephrase
Logged
