« on: October 08, 2010, 08:20:36 am » |
I'm fairly new to Arduino and I am currently working with a Serial GPS receiver.
I receive some returned bytes such as firmware versions as a byte, however the higher 2 bits form the major revision, then there should be a decimal place, then the lower 2 bits form the minor revision number.
Please can anyone help me or point me in the right direction to split bytes in 2? The bit() command only seems to allow you to look at individal bits, when I need a 'nibble', 2 bit size.
Many Thanks, Morrolan
UK
Gorm deficient
« Reply #1 on: October 08, 2010, 08:27:15 am » |
I always thought of nibbles (or nybbles) as being half a byte, or four bits.
hint: if you can read a single bit, you're halfway there.
Per Arduino ad Astra
« Reply #2 on: October 08, 2010, 08:31:53 am » |
Groove,
I'm sorry you are correct, a nibble is 4 bits, allowing values between 0 - 15.
Maybe it is my lack of understanding of C++, but how would one add the four individual bits together form 1 single nibble-sized number?
Norway@Oslo
loveArduino(true);
« Reply #3 on: October 08, 2010, 08:47:08 am » |
typedef struct { unsigned low:4; unsigned high:4; } nibble;
nibble test = { 3, 6 };
void setup() { Serial.begin(9600); Serial.println(test.low); Serial.println(test.high); } void loop(){}
« Reply #4 on: October 08, 2010, 03:25:36 pm » |
Assuming you are trying to decompose a received byte into two nibbles: byte data;
byte lownibble = data & B00001111;
byte highnibble = data >> 4;
« Last Edit: October 08, 2010, 04:50:51 pm by lefstin »
what?
« Reply #5 on: October 08, 2010, 06:58:28 pm » |
Im with Professor Chaos on this one, you could use some inline asm also such as swapf, data which swaps the high nib and low nib in a byte, it is useful when talking to 4bit lcd's
Van Alstyne, TX
Haven't smoked an Arduino... yet.
« Reply #6 on: October 08, 2010, 10:07:33 pm » |
And I don't believe that there's anything in the C or C++ language references that would guarantee that the 'high' bitfield would be aligned with the four most significant bits nor the 'low' bitfield being aligned with the four least significant bits. Maybe on the Arduino it might work....
Dallas
Shannon Member
« Reply #7 on: October 09, 2010, 12:09:31 am » |
Maybe on the Arduino it might work.... It does. It works well. For those concerned with performance... certain combinations of bit fields will generate several machine instructions. AlphaBeta's example is fairly lean. I think it's the same as using shift-and.
« Last Edit: October 09, 2010, 12:14:01 am by bcook »
England
« Reply #9 on: October 09, 2010, 06:28:13 am » |
« Last Edit: October 09, 2010, 06:29:09 am by UltraMagnus »
UK
« Reply #10 on: October 09, 2010, 06:57:40 am » |
bitfields and unions are incredibly useful in uC programming And also incredibly irritating if you inadvertently use the same union at opposite ends of a link with different endianness.
England
« Reply #11 on: October 09, 2010, 07:23:48 am » |
And also incredibly irritating if you inadvertently use the same union at opposite ends of a link with different endianness. perhaps, but that is nothing that cannot be solved by a quick lookup table.
SF Bay Area (USA)
Strongly opinionated, but not official!
« Reply #12 on: October 11, 2010, 06:13:17 pm » |
nothing that cannot be solved by a quick lookup table. IIRC, the IP "Fragment offset" field can not be represented as a C bitfield on a little-endian CPU/compiler. It spans the byte boundry on a big-endian system, but ends up discontiguous on little-endian systems. So there are things that can't be solved with a lookup table... :-)
