Author Topic: problem reading a string from ethernet shield  (Read 412 times)
Hi I have a problem with a tcp socket.
I can send a string command to arduino ethernet shield. All is OK.
But I can't read Arduino reply (it should be "200 OK").
Always there is an exception
This is the java code used to talk to Arduino
try {
            outStream.writeBytes(message);
            outStream.flush();
            outStream.close();
      } catch (Exception ex) {
            System.err.println("Unable to write " + message + " " + socket.toString()
                    + ". Maybe the device is not connected.");
      try {
            inStream = new BufferedReader(new InputStreamReader(socket.getInputStream()));
            System.out.print("Received string: '");
            while (!inStream.ready()) {}
            System.out.println(inStream.readLine()); // Read one line and output it
            System.out.print("'\n");
            inStream.close();
          } catch(Exception e) {
                     System.out.print("It didn't work!\n");
      socket.close();
The problem is with inStream section
Thanks
Freedomotic Domotica Open Source
http://freedomotic.com
We need your help. Please contact us for contributing
Netherlands
Have you confirmed that the Arduino puts that string into the socket? e.g. by printing it to Serial.println(s) too?
When reading from a socket you never know if data comes in one pieces or in many pieces. Especially from a relative slow device as an Arduino it can be split in pieces.
Can you tell us what the exception tells you?
change   System.out.print("It didn't work!\n");  ==> System.out.print(e.getMessage());
Rob Tillaart
Thanks,I'll try to print exception message.
But if I connect to Arduino by web browser I receive the correct string. All works!!
Netherlands
That implies that your webbrowser waits until all data is received, while your program doesn't.
Rob Tillaart
I receive this exception
java.net.SocketException: socket is fclose
But I close the socket after reading Arduino reply.
Can you help me?
Seattle, WA USA
Seattle, WA USA
The smippet of code you posted obviously doesn't tell the whole story. You need to post more of your code.
This is the complete code for my function sending a message to arduino ethernet shield. It is part of a domotic project more complex
public class ETHArduinoBoard extends Actuator {
    Properties protocol = new Properties(); //defines the protocol using a hashmap
    Socket socket = null;
    DataOutputStream outStream = null;
    BufferedReader inStream = null;
    String response = null;
    public ETHArduinoBoard() {
        super("ETH Arduino Board");
        //fillProtocolData();
        //connect(); //connects to eth device
        start(); //starts the plugin
  private void connect(Command c) {
      try {
            socket = new Socket(c.getProperty("socket-host"), new Integer(c.getProperty("socket-port")));
            BufferedOutputStream buffOut = new BufferedOutputStream (socket.getOutputStream ());
            outStream = new DataOutputStream (buffOut);
          } catch (UnknownHostException e) {
            System.err.println("Unable to connect to host '" + configuration.getProperty("socket-host") + "' on port " + configuration.getProperty("socket-port"));
        } catch (IOException e) {
            System.err.println("Couldn't get I/O for "
                    + "the connection to " + c.getProperty("socket-host") + "' on port " + c.getProperty("socket-port"));
//        BufferedReader stdIn = new BufferedReader(new InputStreamReader(System.in));
    @Override
   public void onCommand(Command c) throws IOException, UnableToExecuteException {
      ElectricDevice dev = getDevice(c);
      connect(c); // called here to interact with arduino
      String message = createMessage(c);
      try {
            outStream.flush();
            outStream.close();
            //in = new BufferedReader(new InputStreamReader(socket.getInputStream()));
            //String response = in.readLine();
            //System.out.println("Device answer:"+response+"\n");
            //in.close();
            //socket.close();
      try {
            inStream.close();
                     //System.out.print("It didn't work!\n");
                     System.out.print(e);
      socket.close();
   // create message to send to Arduino
   public String createMessage(Command c) {
     String message=null;
        message="GET /" + c.getProperty("code") + " HTTP 1.0\r\n\r\n";
        return(message);
    private ElectricDevice getDevice(Command c) {
        //getting a safe reference to the targer object if exist
        ElectricDevice dev = null;
        try {
            dev = c.getTargetObject(ElectricDevice.class);
        } catch (NoObjectFoundException ex) {
            System.err.println("Undefined target object '" + c.getProperty("object") + "' in command '" + c.getName() + "'");
        } catch (ClassCastException classEx) {
            System.err.println("Attempt to handle an '" + c.getProperty("object") + "' as an 'ElectricDevice' -> " + classEx.getLocalizedMessage());
        return dev;
     * used only to update the state of the object in Freedom
    protected void setTargetObjectBehavior(Command c) {
        //getting the behavior to apply
        String state = c.getBehavior();
        try {
            if (state.equalsIgnoreCase("on")) {
                dev.switchOn(c.getProperties());
            if (state.equalsIgnoreCase("off")) {
                dev.switchOff(c.getProperties());
            if (state.equalsIgnoreCase("dim")) {
                Light light = (Light) dev;
                light.dim(c.getProperties());
        } catch (Exception e) {
            System.err.println("Unable to change behavior");
    public void onDataAvailable(String data) {
        //do nothing
    public boolean canExecute(Command c) {
        throw new UnsupportedOperationException("Not supported yet.");
Seattle, WA USA
Seattle, WA USA
What triggers the onCommand() callback?
What happens if you don't close outStream until just before you close the socket?
Thanks PaulS!! You're a genius!!
I solved moving outStream.close() after reading from inStream:
 inStream.close();
 outStream.close();
 socket.close();
