Topic: Randomly blink without delay? (Read 915 times) previous topic - next topic
SJK70
Hi Guys,
I've been searching for a way to randomly blink without using delay.
Theres a few codes about to blink without delay, but it seems the only way to randomize this blinking (randomly on/off between a set of values) is with the delay function.
This is the blink without delay code: // http://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
Code: [Select]
// constants won't change. Used here to
// set pin numbers:
const int ledPin =  9;      // the number of the LED pin
// Variables will change:
int ledState = LOW;             // ledState used to set the LED
long previousMillis = 0;        // will store last time LED was updated
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval = 1000;           // interval at which to blink (milliseconds)
  // set the digital pin as output:
  pinMode(ledPin, OUTPUT);
  // here is where you'd put code that needs to be running all the time.
  // check to see if it's time to blink the LED; that is, if the
  // difference between the current time and last time you blinked
  // the LED is bigger than the interval at which you want to
  // blink the LED.
  if(currentMillis - previousMillis > interval) {
    // save the last time you blinked the LED
    // if the LED is off turn it on and vice-versa:
    if (ledState == LOW)
      ledState = HIGH;
      ledState = LOW;
    // set the LED with the ledState of the variable:
    digitalWrite(ledPin, ledState);
Do you know if this is possible? If so, how?
For the bigger picture - I want a few LED's to randomly blink on/off as a general state, untill someone gets close to them. Then have an LDR sensor, so that when people approach the light, they stop flickering, and stay on dimmed, gradually getting brighter, the closer (less light) someone gets.
I've got the stages in separate codes, but I'm having trouble combining them together.
Cheers
AWOL
Quote
Use the blink-without delay tutorial, but instead of the fixed interval ("interval = 1000"), use a value returned (and possibly scaled) by "random".
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
SJK70
oh thanks,
so how would this be written?
sorry - having trouble getting to grips with the arduino language...
AWOL
http://arduino.cc/en/Reference/Random
SJK70
