Topic: Have terminal bash script act as virtual "button" for Arduino? (Read 202 times) previous topic - next topic
realdannys
I've searched quite a lot for this and tried to piece bits of code together but with no luck so far.
All i'm looking to do is have a command I can run in terminal/bash script on the Mac trigger some code to run on the Arduino (Leonardo)
It doesn't matter what data the Mac sends, I only have one command to run so it doesn't need to look like separate buttons or anything.
So far i've tried
Code: [Select]
int incomingByte = 0;   // for incoming serial data
        // send data only when you receive data:
        if (Serial.available() > 0) {
                // read the incoming byte:
                incomingByte = Serial.read();
//run commands
and then from terminal/script both
Code: [Select]
echo "1" > /dev/tty.usbmodemHIDPC1 9600
and
Code: [Select]
screen > /dev/tty.usbmodemHIDPC1 9600
I see the Arduino light flash when I run those two commands in terminal which would seem to suggest that its receiving the data, but nothing runs.
I have stripped out my code that is due to be run by the way for simplicity. I also include keyboard.h and want the Leonardo send keyboard presses.
pert
There's nothing to run in the code you posted.
Don't add that extra complexity in yet. Start by getting an LED to turn on when the serial data is received.
realdannys
Yes I know, that's why I said i've stripped my code out - the code i've got works perfectly - I just want it to be triggered my the terminal on the Mac.
GoForSmoke
I lined up the braces to make it easier to see at a glance. The baud rate and char instead of int are tips to try. Uno has 2K for heap and stack memory, if you develop good RAM habits from the start you can go far without a crash. BTW, don't use type String on Arduino.
Code: [Select]
char chr;   // for incoming serial data, type char is signed 8-bit, -128 to 127, ASCII is char codes. Save 1 byte over type int.
    Serial.begin(115200);  // set serial monitor to this, it empties the outgoing buffer 12x faster than 9600.
    // read data only when you receive data:
        // read the next char in the Serial input buffer, might be the last/latest arrived
        chr = Serial.read();
        // run commands
        //     ummmmmmm, what commands?
        Serial.println( chr, HEX );
        // if ( chr == 'D' ) // do thing if key is D
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
3) http://gammon.com.au/interrupts
Your sketch can sense ongoing process events in time.
Your sketch can make events to control it over time.
realdannys
Thanks @GoForSmoke
I've used the below code but i've still got the same issue from terminal on the Mac.
If I use
Code: [Select]
echo "1" > /dev/tty.usbmodemHIDPC1 115200
Then I see the Leonardo LED flash once, but then nothing happens. Also it locks up terminal as if it's in a state of trying to send commands. Is there a terminal command I can add to the bash script that will effectively just ping the Arduino and exit so it's not locking the terminal session up?
Here is my Arduino code now.
Code: [Select]
#include <Keyboard.h>
    Keyboard.begin();
        // run commands
        delay(3000);
  Keyboard.write('S');
  delay(100);
  Keyboard.write('Y');
  delay(100);
  delay(100);
  Keyboard.write('T');
  delay(100);
  Keyboard.write('E');
  delay(100);
  Keyboard.write('M');
  delay(100);
Code: [Select]
        // run commands
realdannys
Ah i've cracked triggering it!
It needs to be
Code: [Select]
echo "1" > /dev/cu.usbmodemHIDPC1 115200
That works and exits in terminal and triggers the command.
Now the only problem as it's in loop is that it keeps writing system over and over. Is there a way I can make it just write the command once and stop? I'm wanting to put this in a script where I have a lot of keyboard commands in just the void setup part which run once, but it seems I need to use loop for listening as it didn't work when I put this code into setup. It's just I only want it to run the code once, not loop forever once the byte is received.
Current code is
Code: [Select]
    Keyboard.begin();
        if (chr = Serial.read() > 0)
        {// run commands
        delay(3000);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
Code: [Select]
        // run commands
GoForSmoke
 after it sends the message, read all available chars and it won't send the message until you trigger it again.
while( Serial.available())  Serial.read(); // empties the serial input buffer
Maybe take more time reading the code you have to start seeing how it works and what advantages you can take.
You could code the whole thing in setup() if you really only want 1 time action. Setup is where you put what only runs once.
pert
Also posted at:
https://arduino.stackexchange.com/q/60362
If you're going to do that then please be considerate enough to add links to the other places you cross posted. This will let us avoid wasting time due to duplicate effort and also help others who have the same questions and find your post to discover all the relevant information. When you post links please always use the chain links icon on the toolbar to make them clickable.
realdannys
For me it didn't work at all if I put it in setup, and in loop as soon as I triggered it it kept repeating over and over rather than waiting for another trigger.
At the moment I did
Code: [Select]
#define EVER (;;)
and at the end of the loop
Code: [Select]
  Keyboard.write('l');
  delay(100);
 for EVER;
Probably not the cleanest way but it does make it run once and allows me to run single run code in setup.
