Loading...
Pages: 1 2 [3]   Go Down
Author Topic: Real Time Plotting Tool ( Oscilloscope )  (Read 15501 times)
Belgium
Offline Offline
Edison Member
Arduino rocks; but with my plugin it can fly rocking the world ;-)
View Profile
WWW
Brijesh
This SimPlot looks interesting to me.
Is there a reason why there are only 4 channels? I mean my mega has 50+ pins. So 4 is a little little.
Best regards
Jantje
Logged
Do not PM me a question unless you are prepared to pay for consultancy.
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
USA
Offline Offline
Newbie
Arduino rocks
View Profile
WWW
SimPlot was intended to be similar to Oscilloscope than a Logic Analyzer. The 50 pins on mega are all digital pins and plotting the state of those pins is functionality of Logic analyzer. SimPlot is intended to plot analog values like output of sensors sampled by ADC, or values of internal variables etc.
That being said, it looks like there is interest for more number of channels. I will put in my to do list and increase the number of channels to 8. If there is interest in Logic analyzer capability I will look into adding that as well. Not sure how much interest is there.
Cheers
Logged
Belgium
Offline Offline
Edison Member
View Profile
WWW
Thanks for the positive response.
I referred to the 50 pins of the mega because in practice you need to do some calculations to decide whether you turn the pin on or of.
Simplifying you could say that each pin has some integer value that will put the pin high or low. When you read the pin itself you do not know the integer value.
With your scope it is possible to know the calculation steps. And then 4 is kind of limiting.
For instance currently I have a buggy project that reads 2 potmeters and a distance sensor and a light dependent resistor to decide to activate a motor.
That is already 4 scopes for the inputs. If I also want some inbetween values (or the motor speed) I need to drop a scope line.
Anyways I'll instal the tool now and do some tests tomorrow.
Best regards
Jantje
Logged
Belgium
Offline Offline
Edison Member
View Profile
WWW
Wauw
That was quick.
It works like a charm. To bad it is written in .net. Otherwise I would add the additional channels myself.
Great work.
Best regards
Jantje
Logged
Belgium
Offline Offline
Edison Member
View Profile
WWW
I must say I'm really impressed with the effectiveness of this functionality.
Using your tool I succeeded in fixing several bugs in my software which could have cost me several hours to find and fix without it.
Basically I saw that the scrolling halted for a while indicating a "extra delay". Because of the other channels it was easy for me to locate the delay.
I also saw the wrong line moving when I changed something; indicating reading the wrong pins.
And I saw the lines being stable meaning that the analog reads are reliable even when my motor is running. Increasing my thrust in the hardware.
In short: You have made a great tool which allows fast (quickly installed and very basic code changes) and appropriate action.
Thanks a lot
Jantje
Logged
Offline Offline
Newbie
View Profile
I'm getting values displayed in my serial monitor, now  I want it to be printed in the interface of my VB specifically in my Richtext
    Code:
         Private Sub DisplayCharacter(ByVal displayChar As String)
            RichTextBox1.Text = displayChar
        End Sub
        Private Sub SerialPort1_DataReceived(ByVal sender As Object, ByVal e As System.IO.Ports.SerialDataReceivedEventArgs)
            Dim RxData As String
            System.Threading.Thread.Sleep(300)
            RxData = SerialPort1.ReadExisting()
            RichTextBox1.Invoke(New DisplayDelegate(AddressOf DisplayCharacter), New Object() {RxData})
        End Sub
    But it wont display :c
    Logged
    Seattle, WA USA
    Offline Offline
    Brattain Member
    Seattle, WA USA
    View Profile
    Quote
    But it wont display
    Are you sure that the method is even called?
    If it is, why are you sleeping in the serial data callback? Doing so makes no sense.
    Logged
    Offline Offline
    Newbie
    View Profile
    Is the VB source code available for SimPlot. I might like to modify. Will share any changes...
    Logged
    Offline Offline
    Newbie
    View Profile
    How am i gonna re scale the plot for the Square Wave?
    Logged
    Offline Offline
    Newbie
    View Profile
    Awesome work! We have been working on something very similar called MegunoLink. Does a similar job of monitoring and plotting arduino data. Can also log data and use it to upload hex files. Check it out at http://www.MegunoLink.com would love to hear any feature suggestions.
    Logged
    USA
    Offline Offline
    Newbie
    Arduino rocks
    View Profile
    WWW
    Thanks a lot
    Glad you found the tool useful. Sorry for late reply. I am having difficulty with new reply notifications. For some reason the message board does not send me notifications all the time.
    Logged
    Offline Offline
    Newbie
    View Profile
    I am only sending 1 string of data -- I have the baud rate configured correctly but I am just getting the same character printed over and over again. Did not modify your code in anyway. Screenshot is attached.
    Any help would be appreciated.
    Logged
    USA
    Offline Offline
    Newbie
    Arduino rocks
    View Profile
    WWW
    apiet,
    You should send data in a proper packet, which has header and size. If you send any data without a packet then it just prints it to text area. This feature is there so that you can print helpful debug and other messages as well as plot data.
    Please read the description of packet on the website and use the library that I have provided.
    cheers
    Logged
    Pages: 1 2 [3]   Go Up
    Print
    Jump to:
