#include <SPI.h>
#include <MFRC522.h>
#include <LiquidCrystal.h>
#include <Servo.h>
#define RST_PIN 9
#define SS_PIN 10
byte readCard[4];
int myTags[100] = {};
int tagsCount = 0;
String tagID = "";
boolean successRead = false;
boolean correctTag = false;
int proximitySensor;
boolean doorOpened = false;
// Create instances
MFRC522 mfrc522(SS_PIN, RST_PIN);
LiquidCrystal lcd(2, 3, 4, 5, 6, 7); //Parameters: (rs, enable, d4, d5, d6, d7)
Servo myServo; // Servo motor
// Initiating
SPI.begin(); // SPI bus
mfrc522.PCD_Init(); // MFRC522
lcd.begin(16, 2); // LCD screen
myServo.attach(8); // Servo motor
myServo.write(10); // Initial lock position of the servo motor
// Prints the initial message
lcd.print("-Pas De Carte Principale!-");
lcd.setCursor(0, 1);
lcd.print(" SCANNE MAINTENANT");
// Waits until a master card is scanned
while (!successRead) {
successRead = getID();
if ( successRead == true) {
myTags[tagsCount] = strdup(tagID.c_str()); // Sets the master tag into position 0 in the array
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Configurer La Carte Principale!");
tagsCount++;
printNormalModeMessage();
int proximitySensor = analogRead(A0);
// If door is closed...
if (proximitySensor > 200) {
if ( ! mfrc522.PICC_IsNewCardPresent()) { //If a new PICC placed to RFID reader continue
return;
if ( ! mfrc522.PICC_ReadCardSerial()) { //Since a PICC placed get Serial and continue
return;
tagID = "";
// The MIFARE PICCs that we use have 4 byte UID
for ( uint8_t i = 0; i < 4; i++) { //
readCard[i] = mfrc522.uid.uidByte[i];
tagID.concat(String(mfrc522.uid.uidByte[i], HEX)); // Adds the 4 bytes in a single String variable
tagID.toUpperCase();
mfrc522.PICC_HaltA(); // Stop reading
correctTag = false;
// Checks whether the scanned tag is the master tag
if (tagID == myTags[0]) {
lcd.clear();
lcd.print("Mode programme:");
lcd.print("Ajouter / supprimer une Carte");
for (int i = 0; i < 100; i++) {
if (tagID == myTags[i]) {
myTags[i] = "";
lcd.clear();
lcd.print(" Carte Enlevée!");
return;
lcd.clear();
lcd.print(" Carte Ajoutée!");
tagsCount++;
return;
// Checks whether the scanned tag is authorized
lcd.clear();
lcd.print(" Accès Autorisé!");
myServo.write(170); // Unlocks the door
correctTag = true;
if (correctTag == false) {
lcd.clear();
lcd.print(" Accès Refusé!");
// If door is open...
else {
lcd.clear();
lcd.print(" Porte Ouverte!");
while (!doorOpened) {
doorOpened = true;
doorOpened = false;
myServo.write(10); // Locks the door
uint8_t getID() {
// Getting ready for Reading PICCs
return 0;
return 0;
tagID = "";
for ( uint8_t i = 0; i < 4; i++) { // The MIFARE PICCs that we use have 4 byte UID
return 1;
void printNormalModeMessage() {
delay(1500);
lcd.clear();
lcd.print("-Contrôle D'accès-");
lcd.print(" Scannez Votre Carte!");
