Topic: The best way to create wifi connection between 2 devices (Read 1 time) previous topic - next topic
ashkan00
I'm pretty new and can't figure out how to make a wifi Arduino controller to control another Arduino Board. I don't want to use a bluetooth phone app or web browser. I want to use a joystick that connects.
I want to create a connection so that I can make a joystick controller that connects to the web, and controls the other device that is also connected to the web.
I have UNO, MEGA, NANO, MKR1000, ESP-01, ESP-12, nRFl01... I'm able to get wifi devices connect to my router, but can't figure out how to connect them together so that I can control one with the other.
KASSIMSAMJI
two esp's can talk to one another over WiFi
one in STA mode connects to another in AP mode, then when sending ,
you normally use
Code: [Select]
    HTTPClient http;
    http.begin("http:192.168.4.1/data");  // IP of receiving end goes here
    int httpCode = http.GET();
upon receiving you invoke
Code: [Select]
server.on("/data", []()
Electrical Engineer
Juraj
you normally use
Code: [Select]
    HTTPClient http;
Code: [Select]
with HTTP overhead it would be a very slow joystick control
You can't write an Arduino sketch if you didn't learn programming. Not the language, but the concepts of programming - algorithms and data types.
