Loading...
Pages: [1]   Go Down
Author Topic: Combining an LDR sensor with random blinking  (Read 643 times)
Offline Offline
Newbie
View Profile
WWW
Hi Guys,
The bigger picture - I want a few LED's to randomly blink on/off as a general state (without using delay), untill someone gets close to them. (SEE CODE BELOW)
Then set a limit on an LDR sensor, so that when people approach the light, the LED's stop flickering, and stay on - dimmed, gradually getting brighter, the closer (less light) someone gets.
I've got the stages in separate codes, but I'm having trouble combining them together.
 This is the blink randomly without delay code:
Code:
//* Blink without Delay
// Turns on and off a light emitting diode(LED) connected to a digital
// pin, without using the delay() function.  This means that other code
// can run at the same time without being interrupted by the LED code.
//The circuit:
// * LED attached from pin 13 to ground.
// * Note: on most Arduinos, there is already an LED on the board
// that's attached to pin 13, so no hardware is needed for this example.
// http://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
// constants won't change. Used here to
// set pin numbers:
#define LED =  9;      // the number of the LED pin
// Variables will change:
int ledState = LOW;             // ledState used to set the LED
long previousMillis = 0;        // will store last time LED was updated
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long randNumber;
  // set the digital pin as output:
  pinMode(9, OUTPUT);
randomSeed(analogRead(2));
  // here is where you'd put code that needs to be running all the time.
  // check to see if it's time to blink the LED; that is, if the
  // difference between the current time and last time you blinked
  // the LED is bigger than the interval at which you want to
  // blink the LED.
  randNumber = random(0, 1000000);
  if(currentMillis - previousMillis > randNumber) {
    // save the last time you blinked the LED
    // if the LED is off turn it on and vice-versa:
    if (ledState == LOW)
      ledState = HIGH;
      ledState = LOW;
    // set the LED with the ledState of the variable:
    digitalWrite(9, ledState);
And this is the LDR sensor code I've been using
Code:
//Example 06B: Set the brightness of the LED at a rate specified by the value of the analogue input
#define LED 9       // pin that the LED is attached to
int val = 0;   // variable used to store the value coming from the sensor
  pinMode(LED, OUTPUT);   //LED is as an OUTPUT
                     // Note: Analogue pins are automatically set as inputs
  val = analogRead(0);   // read the value from the sensor
  analogWrite(LED, val/4);     // turn the LED on at the brightness set by the sensor
  delay(10);             // stop the program for some time
Do you know if this is possible? If so, any tips or tricks would be greatly appreciated? smiley
Cheers
Logged
UK
Offline Offline
God Member
Twitter: @simonmonk2
View Profile
WWW
You can try doing something like looking for the LDR signal to suddenly reduce by a lot.
So, keep the old reading and each time round the loop, you see how much the reading has changed.
Or, you could consider using a PIR sensor like this:
http://www.sparkfun.com/products/8630
Logged
My New Arduino Book: http://www.arduinobook.com
Offline Offline
Newbie
View Profile
WWW
thanks, it's going to be used in a live installation, so a motion detector wouldn't be suitable...
I've managed to use the if and else functions to put a threshold on the ldr sensor, so it randomly blinks, then when a set low amount of light is recieved, the lights stays on, however it doesn't fade in like it used to..
any ideas?
Code:
// Randomly blink - LED gets brighter the less light the LDR recieves
#define LED1 9 // pin that LED is attached to
#define LED2 10
int Val = 0; // variable used to store the value coming from the sensor
long randNumber;
  pinMode(LED1, OUTPUT);  // LED is an OUTPUT
    pinMode(LED2, OUTPUT);  // LED is an OUTPUT
                        // Analogue pins are autmatically set as inputs
 if (Val = analogRead(0) < 800)    // read the value from the sensor
 analogWrite(LED1, 255-Val/4);  // turn LED on at brightness set by sensor value
  analogWrite(LED2, 255-Val/4);  // turn LED on at brightness set by sensor value
 else if (Val = analogRead(0) > 800)
  randNumber = random(0, 150000);
      ledState = HIGH;
      ledState = LOW;
    digitalWrite(LED1, ledState);
        digitalWrite(LED2, ledState);
Logged
New Jersey
Offline Offline
Edison Member
View Profile
This construct is your problem:
Code:
It should have more brackets:
Code:
if ((Val = analogRead(0)) < 800)
This is because the assignment operator has low precedence, which means that your original version is equivalent to this:
Code:
if (Val = (analogRead(0) < 800))
Which means that you're assigning the value of a boolean to val, which is clearly not what you intend.
Logged
Sussex UK / CT USA
Offline Offline
Edison Member
Forums forever
View Profile
WWW
Another "answer" would be to use an ultrasonic proximity detector...
http://sheepdogguides.com/arduino/aht1a.htm
Logged
Offline Offline
Newbie
View Profile
WWW
The extra brackets seem to have worked. It does now fade in - but only very slightly...
Is there a way to start the LED's much dimmer, for a more overt fade in rather than subtle??
This is the code as it stands..
Code:
// LED gets brighter the less light the LDR recieves
#define LED2 10
long randNumber;
 if ((Val = analogRead(0)) < 500)    // read the value from the sensor
 else if ((Val = analogRead(0)) > 500)
      ledState = HIGH;
      ledState = LOW;
cheers for the help!
Logged
Pages: [1]   Go Up
Print
Jump to:
