Topic: using a permanent switch (Read 904 times) previous topic - next topic
Rupertt
Hello,
how do I have to wire a switch that has 3 pins instead of a switch that has the 4 pins in
this example? http://arduino.cc/en/Tutorial/Button
I would like to use such a switch: http://www.conrad.de/medias/global/ce/7000_7999/7000/7010/7013/701343_ZB_00_FB.EPS_250.jpg
greetings
robtillaart
Most important is - http://arduino.cc/en/uploads/Tutorial/button_schem.png -
The switch is in the upper corner of the schema. The fact it has four pins is for mechanical stability, but it is just an on off switch. The witch you provide is a ON/ON switch, either left or right is connected. You need to use the middle and the left pin of your switch. The right pin can be left not connected.
Hopes this helps.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Rupertt
that helped, thnx.
I have that working now
robtillaart
you could connect the right pin of the switch to another input pin of the Arduino ...
Rob Tillaart
liuzengqiang
BTW, the switch pictured is a panel-mount. You drill a hole in a panel, stick it through, and secure it with the included nut tightly. That's the only way it will work, stable enough, besides connecting it. You can also buy sliding switches for PCB through holes to easily prototype on a breadboard.
Like this I found on google: http://www.directindustry.com/prod/nkk-switches/slide-micro-switches-9308-39132.html
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
