Topic: Yun Rev 2 and RRDTool missing Version 1.2.30-3 (Read 26553 times) previous topic - next topic
ottsm
The packages in Yun Rev 2 only have version 1.0.x versus what use to be their in other Yun's I've had in the past.
I found the following by "googling" around;
I found a copy of rrdtool_1.2.30-3_ar71xx.ipk at the following location;
https://archive.openwrt.org/barrier_breaker/14.07/ar71xx/generic/packages/oldpackages/rrdtool_1.2.30-3_ar71xx.ipk
I also found for the Artheros version (which is what the Yun is AR9331);
https://archive.openwrt.org/barrier_breaker/14.07/atheros/generic/packages/oldpackages/rrdtool_1.2.30-3_atheros.ipk
Both repositories are missing the Packages.sig file and probably other files that are in the newer repositories that I see.  Anyway to install the ipk file directly or was it complied under an older release and isn't going to work?
