Topic: How to store certain information into the memory of Arduino Uno R3.  (Read 126 times) previous topic - next topic
ArduinoKer
Hello Everyone, i am trying to store some information ( for my case coordinates ), into a memory in the Arduino Uno board. Does anyone know how.?
As you can see from my code below , my x,y,z coordinates are in the variables coor.x, coor.y and coor.z respectively. So i am trying to store the coordinates into the memory of the board so that the board can remember where it was before and maybe trace back its own path...
Your help is much appreciated
Code: [Select]
void printCoordinates(coordinates_t coor){
  uint16_t network_id = remote_id;
  if (network_id == NULL){
    network_id = 0;
  if(!use_processing){
    Serial.print("POS ID 0x");
    Serial.print(network_id, HEX);
    Serial.print(", x(mm): ");
    Serial.print(coor.x);
    Serial.print(", y(mm): ");
    Serial.print(coor.y);
    Serial.print(", z(mm): ");
    Serial.println(coor.z);
    //delay(10);
  }else{
    Serial.print("POS,0x");
    Serial.print(network_id,HEX);
    Serial.print(",");
    Serial.print(",");
    Serial.print(",");
    //delay(10);
Delta_G
They're already in memory in the variables coor.x and coor.y and coor.z.  Using variables is how you normally store things in memory.
Do you want this to be remembered even if the board is turned off and on again?  Then you copy to EEPROM or an SD card.
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
ArduinoKer
Hello, Sorry i think maybe my question was a little ambiguous. As you can see coor.x, coor.y and coor.z are my variables for my coordinates actually. x y and z axis. But i was thinking because it displays 1 set of data ( x y z ) and then it updates and displays another set of data. to show the position for a certain object.  So i was thinking of like is it possible to remember the the sets of data instead of just one axis.? like for eg
 it moves from ( 0,0,0 ) to (150,110,100).
what will be shown in the serial monitor is just a (0,0,0) to a (150,110,100). is it possible to make it remember in one of the internal memory ( maybe the Flash memory .?) that its original position was ( 0,0,0 ) like i want the board to remember a set of data and not just a particular axis
Delta_G
Code: [Select]
int lastPositionX = coor.x;
int lastPositoinY = coor.y;
int lastPositionZ = coor.z;
//  now update coor with new values and you have the old values saved in variables.
Or maybe copy the whole structure.
Code: [Select]
coordinates_t myLastCoordinates = coor;
Assuming that type has a good copy constructor.  I can't guarantee that because you didn't share all the code with me.  So there is a little guesswork there.
|| | ||| | || | ||  ~Woodstock
ArduinoKer
Hello im so sorry i couldn't put my entire code here because of the word limit.. so i have taken out a little of the functions below, but it doesn't really affect the question that i am asking so it should be ok.
Sorry i am a beginner in Arduino programming you see..
Code: [Select]
#include <Pozyx.h>
#include <Pozyx_definitions.h>
#include <Wire.h>
#define FILTER_TYPE_NONE 0x00               // no filter applied ( default )
#define FILTER_TYPE_FIR 0x01                // a LPF is appliled to filter out HF jitters
#define FILTER_TYPE_MOVINGAVERAGE 0x03      // moving avg is applied to smoothen trajectory
#define FILTER_TYPE_MOVINGMEDIAN 0x04       // moving median is applied filter out outliers
////////////////// PARAMETERS //////////////////
uint16_t remote_id = 0x6000;                            // set this to the ID of the remote device
bool remote = true;                                    // set this to true to use the remote ID
uint32_t last_millis;
boolean use_processing = true;                         // set this to true to output data for the processing sketch
                                                       // the number of anchors
const uint8_t num_anchors = 4;                                    // the number of anchors
uint16_t anchors[num_anchors]  = {0x6969, 0x6961, 0x6e6d,   0x6923   };     // the network id of the anchors: change these to the network ids of your anchors.
int32_t anchors_x[num_anchors] = {0,        0 ,    1470,     3060   };               // anchor x-coorindates in mm
int32_t anchors_y[num_anchors] = {0,       2350,    0,       1590    };                  // anchor y-coordinates in mm
int32_t heights[num_anchors]   = {-750,      0 ,    0,       1150   };               // anchor z-coordinates in mm
uint8_t algorithm = POZYX_POS_ALG_UWB_ONLY;             // positioning algorithm to use. try POZYX_POS_ALG_TRACKING for fast moving objects. POZYX_POS_ALG_UWB_ONLY
uint8_t dimension = POZYX_3D;                           // positioning dimension
int32_t height = 0;                                  // height of device, required in 2.5D positioning
void setup(){
   if(Pozyx.begin(false, MODE_INTERRUPT, POZYX_INT_MASK_IMU) == POZYX_FAILURE){
    Serial.println(F("ERROR: Unable to connect to POZYX shield"));
    Serial.println(F("Reset required"));
    delay(100);
    abort();
  if(!remote){
    remote_id = NULL;
  last_millis = millis();
  delay(10);
  Serial.println(F("----------POZYX POSITIONING V1.1----------"));
  Serial.println(F("NOTES:"));
  Serial.println(F("- No parameters required."));
  Serial.println(F("- System will auto start anchor configuration"));
  Serial.println(F("- System will auto start positioning"));
  Serial.println(F("Performing manual anchor configuration:"));
  // clear all previous devices in the device list
  Pozyx.clearDevices(remote_id);
  // sets the anchor manually
  setAnchorsManual();
  // sets the positioning algorithm
  Pozyx.setPositionAlgorithm(algorithm, dimension, remote_id);
  printCalibrationResult();
  delay(2000);
  Serial.println(F("Starting positioning: "));
void loop(){
  coordinates_t position;
  int status;
   int dt;
    uint8_t calibration_status = 0;
    sensor_raw_t sensor_raw;
  if(remote){
      status = Pozyx.getRawSensorData(&sensor_raw, remote_id);
      status &= Pozyx.getCalibrationStatus(&calibration_status, remote_id);
      status = Pozyx.doRemotePositioning(remote_id, &position, dimension, height, algorithm);
    printOrientationAcceleration();
    //Pozyx.setPositionFilter(FILTER_TYPE_MOVINGAVERAGE, 10 , remote_id );  // filter_type, filter_strength, remote. Strength 0-15 ( position will be delayed by the number of samples that = to the strength )
  if (status == POZYX_SUCCESS){
    dt = millis() - last_millis;
  last_millis += dt;
  // print time difference between last measurement in ms, sensor data, and calibration data
  Serial.print(dt, DEC);
  Serial.print(",");
  printRawSensorData(sensor_raw);
  Serial.print(",");
  // will be zeros for remote devices as unavailable remotely.
  printCalibrationStatus(calibration_status);
    // prints out the result
    printCoordinates(position);
  else{
    // prints out the error code
    printErrorCode("positioning");
// prints the coordinates for either humans or for processing
    network_id = 0;
    //delay(10);
  }else{
    Serial.print(",");
    Serial.print(",");
    Serial.print(",");
    //delay(10);
// error printing function for debugging
void printErrorCode(String operation){
  uint8_t error_code;
  if (remote_id == NULL){
    Pozyx.getErrorCode(&error_code);
    Serial.print("ERROR ");
    Serial.print(operation);
    Serial.print(", local error code: 0x");
    Serial.println(error_code, HEX);
    return;
  int status = Pozyx.getErrorCode(&error_code, remote_id);
  if(status == POZYX_SUCCESS){
    Serial.print(" on ID 0x");
    Serial.print(remote_id, HEX);
    Serial.print(", error code: 0x");
  }else{
    Serial.print(", couldn't retrieve remote error code, local error: 0x");
// print out the anchor coordinates (also required for the processing sketch)
void printCalibrationResult(){
  uint8_t list_size;
  int status;
  status = Pozyx.getDeviceListSize(&list_size, remote_id);
  Serial.print("list size: ");
  Serial.println(status*list_size);
  if(list_size == 0){
    printErrorCode("configuration");
    return;
  uint16_t device_ids[list_size];
  status &= Pozyx.getDeviceIds(device_ids, list_size, remote_id);
  Serial.println(F("Calibration result:"));
  Serial.print(F("Anchors found: "));
  Serial.println(list_size);
  coordinates_t anchor_coor;
  for(int i = 0; i < list_size; i++)
    Serial.print("ANCHOR,");
    Serial.print("0x");
    Serial.print(device_ids[i], HEX);
    Serial.print(",");
    Pozyx.getDeviceCoordinates(device_ids[i], &anchor_coor, remote_id);
    Serial.print(anchor_coor.x);
    Serial.print(",");
    Serial.print(anchor_coor.y);
    Serial.print(",");
    Serial.println(anchor_coor.z);
// function to manually set the anchor coordinates
void setAnchorsManual(){
  for(int i = 0; i < num_anchors; i++){
    device_coordinates_t anchor;
    anchor.network_id = anchors[i];
    anchor.flag = 0x1;
    anchor.pos.x = anchors_x[i];
    anchor.pos.y = anchors_y[i];
    anchor.pos.z = heights[i];
    Pozyx.addDevice(anchor, remote_id);
  if (num_anchors > 4){
    Pozyx.setSelectionOfAnchors(POZYX_ANCHOR_SEL_AUTO, num_anchors, remote_id);
MorganS
Usually when you move across a room you don't teleport from 0 to 150 instantly. You spend some time at 2, then maybe less time at 3 because you are accelerating when you start moving. And you may not be moving in a straight line, so you go from (0,0,0) to (1,0,1) before going to (1,1,1).
This movement could be called a "path" and it is necessary to record both x,y,z AND the time that you were at each of those positions. One way to make that easier is to record at regular intervals, like maybe 10 times per second. That will create a lot more data than the tiny Arduino memory can hold. It might fill up in just a few seconds. But an 8GB SD card could record data like this for more than a year.
I suggest you work on recording the position to an SD card at a regular interval.
"The problem is in the code you didn't post."
