Topic: Things to make (Read 1 time) previous topic - next topic
larryd
Jan 12, 2019, 06:52 am Last Edit: Jan 12, 2019, 06:57 am by larryd
Some things I need to make, what are some of yours?
She will never go for this  :(
No technical PMs.
The last thing you did is where you should start looking.
Delta_G
#1
Jan 12, 2019, 07:06 am Last Edit: Jan 12, 2019, 07:07 am by Delta_G
I have a feeling that I may be starting on that one tomorrow now.  :)  I like it.
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
larryd
Rather than the power cord down the corner of the wall (as shown), I thought a simple flat black aluminum pipe in the middle of the structure to the floor.
Kinda like a tree trunk.
No technical PMs.
Robin2
Leave it in the corner and paint the cord to match the wall so the unit seems to be unsupported.
By the way they all look great.
My artistic imagination seems limited to things I can make with card using a Silhouette Portrait computer cutter - not at all Arduino related. Except that I can make card bodies for my model trains that are Arduino controlled.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
GoForSmoke
Make the rectangles leaf-shape and mask the leds to light the leaves? Hide wiring in or as branches?
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
Your sketch can sense ongoing process events in time.
Your sketch can make events to control it over time.
larryd
#5
Jan 13, 2019, 06:00 am Last Edit: Jan 13, 2019, 06:10 am by larryd
Leaves, hum, yes.
Maybe a branch with different leaves from different trees.
Neopixels going through spring summer fall colours.
No technical PMs.
Delta_G
I've never messed with any of these new fangled addressable LED strips.
Can you spread them all out like that?  How long can I run between them?  How long can I run a full strip?  Can each LED be a strip of 1 without killing the idea of using them?
Is there one that you like better than the others?
|| | ||| | || | ||  ~Woodstock
larryd
#7
Jan 13, 2019, 07:11 am Last Edit: Jan 13, 2019, 06:40 pm by larryd
Have used WS2812B  RGB pixels quite a bit.
I have mounted an Arduino ~2 meters (I believe some have had luck at 3 meters) from the 1st pixel.
You can use 'none lit' pixels as repeaters to extend the usable length.
Can run several branches on one Arduino.
A single pixel can be controlled.
Up to many meters, 3 bytes of memory per pixel.
Powering can be from either end of a string.
One could cut 2, 3 or 4 pixels from a strip (maybe tissue paper on top), place them under a translucent clear plastic leaf  with engraved veins, go a foot away then repeat . . .
Cut leaves out with a scroll saw or CNC router, sand surface with 600 grit sand paper.
Use heat gun then bend to give them a none flat appearance.
I have not tried this, you should be able to run strings in parallel.
They would light up identically.
(Just tested this, it works well)
Hell, maybe use real branch material cut in half. ;)
No technical PMs.
GoForSmoke
I'd go with leaf outlines in the way that original uses rectangles, keep it into the abstract rather than representative.
larryd
#9
Jan 13, 2019, 05:35 pm Last Edit: Jan 13, 2019, 07:00 pm by larryd
Definitely warrants some critical testing before a lot of effort is put into cutting the final version of the leaves.
A few veins would add some interest, but not too much external edge embellishment.
Maybe replace the flames in the original image with leaves and keep the rectangles.
No technical PMs.
ardly
They all look great. Do you have any links to the bird lamp?
"Facts do not cease to exist because they are ignored" - Aldous Huxley
Qdeathstar
@larry, i think you might be better off with a neopixel ring....
A creaking creeping shadow
stiff against the freezing fog
glares at a tickless watch.
Time has failed him -- all things shall pass.
GoForSmoke
I have seen 13mm addressable leds sold seperately at DealExtreme years ago. Each one had long leads, not real cheap either.
larryd
Bird lamp on eBay, expensive, thought I might try my had at wood carving. :)
https://www.ebay.com/itm/Whimsical-Unique-Ibis-Table-Lamp-Heron-Crane-Bird-Motif-Lamp-14-5-x-35-H/153326440421?epid=1179186757&hash=item23b2f7cfe5:g:c2MAAOSwlxRah1ym
Neopixel rings?
Been there done that, thought this art piece had some artistic appeal.
Trying to make something that we won't easily tire of.
I'M think cutting several pixels from a strip will work.
Maybe get 2-3 pixels on a PCB made from PCBWAY.
Have to make some leaves of different sizes and try them before cutting the whole bunch on the CNC.
No technical PMs.
GoForSmoke
Unless you're going to run them with a Tiny, why go addressable for just a few RGB leds? 328P/168P have the pins to do 6.
1 meter circumference is just over 12.53" diameter, about right for a lampshade though it'd take a lot of strips to cover one but that one could make a heck of a show, take that Tiffany and your lame colored glass!
